Home » Modeling » Epsilon » EWL and reserved word as metaclass name (Integer) and instanciation
EWL and reserved word as metaclass name (Integer) and instanciation [message #19504] Wed, 03 June 2009 21:15 Go to next message
Hi list,
I'm trying to get something like creating an Integer instance (which is an
EClass, part of my meta-model) working with a dynamic model which is
registered using right-click->Register EPackage, but I get an error.
Here is the ewl:
wizard addIdentifierAsPrimaryKeyToClass {
guard : self.isTypeOf(Class) and not
self.column.exists(c|c.name.matches('id'))
title : 'Add an Id column as primary key to ' + self.name
do {
self.column.add( self.generateIdPKUnikColumn() );
wizard addIdentifiersAsPrimaryKeyToClasses {
title : 'Add an Id column as primary key to classes (Model-wide)'
do {
for( class in Class.allInstances() )
if( not class.column.exists(c|c.name.matches('id') ) )
class.column.add( class.generateIdPKUnikColumn() );
operation Class generateIdPKUnikColumn () : Column {
var idcolumn : Column;
idcolumn := Column.createInstance();
idcolumn.name := 'id';
idcolumn.primary := true;
idcolumn.unique := true;
var idtype : sfdoctrine!Integer; <----------- problem here
idtype := sfdoctrine!Integer.createInstance();
idcolumn.type = idtype;
return idcolumn;
I have replaced sfdoctrine!Integer; by sfDoctrine and with Integer alone
but none does works.
Here is the emfatic head of my meta-model :
@namespace(uri=" http://stephaneerard.wordpress.com/meta-models/sfDoctrine/1. 2",
prefix="sfdoctrine")
package sfDoctrine;
And the error with sfDoctrine (same with sfdoctrine) :
Type 'sfdoctrine!Integer' not found
(D:\e_workspaces\modeling\sfDoctrine-1.2\tools\wizards\addIdentifierAsPrimaryKeyAndUniqueToClass.ewl@36:28)
org.eclipse.epsilon.eol.execute.TypeExecutor.execute(TypeExe cutor.java:90)
org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:184)
org.eclipse.epsilon.eol.execute.VarStatementExecutor.execute (VarStatementExecutor.java:48)
org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:33)
at org.eclipse.epsilon.eol.EolOperation.executeBody(EolOperatio n.java:257)
at org.eclipse.epsilon.eol.EolOperation.execute(EolOperation.ja va:230)
at org.eclipse.epsilon.eol.EolOperation.execute(EolOperation.ja va:188)
at org.eclipse.epsilon.eol.EolOperations.execute(EolOperations. java:143)
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:160)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:66)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:36)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:122)
org.eclipse.epsilon.eol.execute.ParametersExecutor.execute(P arametersExecutor.java:29)
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:154)
at org.eclipse.epsilon.ewl.EwlWizard.process(EwlWizard.java:78)
org.eclipse.epsilon.ewl.EwlWizardInstance.process(EwlWizardI nstance.java:66)
org.eclipse.epsilon.ewl.emf.ExecuteWizardInstanceCommand.exe cute(ExecuteWizardInstanceCommand.java:42)
org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:84)
org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction. execute(AbstractContributeWizardsAction.java:235)
org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction$ 1.widgetSelected(AbstractContributeWizardsAction.java:223)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
And the error with Integer alone (which is not really surprising me,
anyway) :
Internal error: java.lang.ClassCastException: java.lang.Integer cannot be
cast to org.eclipse.emf.ecore.InternalEObject
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSe ttingDelegateSingleEObject.dynamicSet[EStructuralFeatureImpl .java:2413]
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet[Basi cEObjectImpl.java:1126]
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet[BasicEObjec tImpl.java:1100]
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet[BasicEObjec tImpl.java:1071]
org.eclipse.epsilon.emc.emf.EmfPropertySetter.invoke[EmfProp ertySetter.java:53]
org.eclipse.epsilon.eol.execute.AssignExecutor.execute[Assig nExecutor.java:55]
org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST[E xecutorFactory.java:184]
org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te[StatementBlockExecutor.java:33]
at org.eclipse.epsilon.eol.EolOperation.executeBody[EolOperatio n.java:257]
at org.eclipse.epsilon.eol.EolOperation.execute[EolOperation.ja va:230]
at org.eclipse.epsilon.eol.EolOperation.execute[EolOperation.ja va:188]
at org.eclipse.epsilon.eol.EolOperations.execute[EolOperations. java:143]
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on[PointExecutor.java:160]
org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:66]
org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:36]
org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:122]
org.eclipse.epsilon.eol.execute.ParametersExecutor.execute[P arametersExecutor.java:29]
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on[PointExecutor.java:154]
at org.eclipse.epsilon.ewl.EwlWizard.process[EwlWizard.java:78]
org.eclipse.epsilon.ewl.EwlWizardInstance.process[EwlWizardI nstance.java:66]
org.eclipse.epsilon.ewl.emf.ExecuteWizardInstanceCommand.exe cute[ExecuteWizardInstanceCommand.java:42]
org.eclipse.emf.common.command.BasicCommandStack.execute[Bas icCommandStack.java:84]
org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction. execute[AbstractContributeWizardsAction.java:235]
org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction$ 1.widgetSelected[AbstractContributeWizardsAction.java:223]
org.eclipse.swt.widgets.TypedListener.handleEvent[TypedListe ner.java:228]
at org.eclipse.swt.widgets.EventTable.sendEvent[EventTable.java :84]
at org.eclipse.swt.widgets.Widget.sendEvent[Widget.java:1003]
at org.eclipse.swt.widgets.Display.runDeferredEvents[Display.ja va:3823]
at org.eclipse.swt.widgets.Display.readAndDispatch[Display.java :3422]
at org.eclipse.ui.internal.Workbench.runEventLoop[Workbench.jav a:2384]
at org.eclipse.ui.internal.Workbench.runUI[Workbench.java:2348]
at org.eclipse.ui.internal.Workbench.access$4[Workbench.java:22 00]
at org.eclipse.ui.internal.Workbench$5.run[Workbench.java:495]
org.eclipse.core.databinding.observable.Realm.runWithDefault [Realm.java:288]
org.eclipse.ui.internal.Workbench.createAndRunWorkbench[Work bench.java:490]
at org.eclipse.ui.PlatformUI.createAndRunWorkbench[PlatformUI.j ava:149]
org.eclipse.ui.internal.ide.application.IDEApplication.start [IDEApplication.java:113]
org.eclipse.equinox.internal.app.EclipseAppHandle.run[Eclips eAppHandle.java:193]
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication[EclipseAppLauncher.java:110]
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start[EclipseAppLauncher.java:79]
org.eclipse.core.runtime.adaptor.EclipseStarter.run[EclipseS tarter.java:386]
org.eclipse.core.runtime.adaptor.EclipseStarter.run[EclipseS tarter.java:179]
at sun.reflect.NativeMethodAccessorImpl.invoke0[Native Method]
at sun.reflect.NativeMethodAccessorImpl.invoke[Unknown Source]
at sun.reflect.DelegatingMethodAccessorImpl.invoke[Unknown Source]
at java.lang.reflect.Method.invoke[Unknown Source]
at org.eclipse.equinox.launcher.Main.invokeFramework[Main.java: 549]
at org.eclipse.equinox.launcher.Main.basicRun[Main.java:504]
at org.eclipse.equinox.launcher.Main.run[Main.java:1236]
(D:\e_workspaces\modeling\sfDoctrine-1.2\tools\wizards\addIdentifierAsPrimaryKeyAndUniqueToClass.ewl@38:18)
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSe ttingDelegateSingleEObject.dynamicSet(EStructuralFeatureImpl .java:2413)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(Basi cEObjectImpl.java:1126)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1100)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1071)
org.eclipse.epsilon.emc.emf.EmfPropertySetter.invoke(EmfProp ertySetter.java:53)
org.eclipse.epsilon.eol.execute.AssignExecutor.execute(Assig nExecutor.java:55)
I have two other evl scripts running well (but still they dont make use of
such syntax-need).
Thanks for all guys !!
Re: EWL and reserved word as metaclass name (Integer) and instanciation [message #19550 is a reply to message #19504] Thu, 04 June 2009 04:33 Go to previous messageGo to next message
Hi Stephane,
The implicit name of the model behind the tree/GMF editor is Model. As
such, Model!Integer instead of sfdoctrine!Integer should do what you want.
Two minor comments by looking at your code (if I may): you can use "new"
instead of "createInstance". e.g.
can be replaced with
idcolumn = new Column;
or (even simpler)
var idcolumn : new Column;
Also, you could just use = instead of := since 0.8.5 (see
http://epsilonblog.wordpress.com/2009/05/24/new-in-epsilon-0 -8-5/)
For example
can now be replaced with
idcolumn.name = 'id';
Dimitris
Stephane wrote:
> Hi list,
> an EClass, part of my meta-model) working with a dynamic model which is
> Here is the ewl:
> do {
> do {
> return idcolumn;
> package sfDoctrine;
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> anyway) :
> be cast to org.eclipse.emf.ecore.InternalEObject
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> of such syntax-need).
Re: EWL and reserved word as metaclass name (Integer) and instanciation [message #19595 is a reply to message #19550] Thu, 04 June 2009 06:43 Go to previous messageGo to next message
Really, Dimitris, you're genius ! ;-)
I'm writting blog tickets in french to spread the word about what you are
all doing here, got lots of good feedbacks from my friends whoses aren't
developers, as I'm writting tool to develop easily data-models using
symfony (php framework) but for now sfDoctrine (php orm) ! Very very very
handy tools you gave us !!!
I've been using oAW, Acceleo and AndroMDA but for sure, well, in my case,
Epsilon fits best !
Thanks for all !!!!
Re: EWL and reserved word as metaclass name (Integer) and instanciation [message #19640 is a reply to message #19595] Thu, 04 June 2009 06:52 Go to previous message
Hi Stéphane,
Glad it worked and many thanks for your kind words! It's both refreshing
and encouraging to get some positive feedback every now and then among
problems and bug reports :)
Dimitris
> are all doing here, got lots of good feedbacks from my friends whoses
> aren't developers, as I'm writting tool to develop easily data-models
> using symfony (php framework) but for now sfDoctrine (php orm) ! Very
> very very handy tools you gave us !!!
> case, Epsilon fits best !
> Thanks for all !!!!
Re: EWL and reserved word as metaclass name (Integer) and instanciation [message #568813 is a reply to message #19504] Thu, 04 June 2009 04:33 Go to previous message
Hi Stephane,
or (even simpler)
For example
Dimitris
Stephane wrote:
> Hi list,
> Here is the ewl:
> do {
> do {
> return idcolumn;
> package sfDoctrine;
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> anyway) :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: EWL and reserved word as metaclass name (Integer) and instanciation [message #568840 is a reply to message #19550] Thu, 04 June 2009 06:43 Go to previous message
Epsilon fits best !
Thanks for all !!!!
Re: EWL and reserved word as metaclass name (Integer) and instanciation [message #568868 is a reply to message #19595] Thu, 04 June 2009 06:52 Go to previous message
Hi Stéphane,
Dimitris
> Thanks for all !!!!
Previous Topic:EWL and reserved word as metaclass name (Integer) and instanciation
Next Topic:EMC
Current Time: Tue Jul 15 12:30:31 EDT 2025
Powered by FUDForum. Page generated in 0.08019 seconds
