Home » Archived » BIRT » How can I use the refreshRate Property
How can I use the refreshRate Property [message #203470] Wed, 29 November 2006 03:59 Go to next message
Originally posted by: oliver.zein.email.de
I want to refresh a report in the report viewer by using the refreshRate
Property of the ReportDesign Element. So i added the following tag inside
the report group:
<property name="refreshRate">10</property>
But after 10 seconds nothing happens. What's wrong with this?
Thanks!
Re: How can I use the refreshRate Property [message #203893 is a reply to message #203470] Wed, 29 November 2006 21:25 Go to previous messageGo to next message
I do not believe the engine supports that property yet.
You can add a script in a text control that uses a script tag.
This will only work in HTML. In order for this to work in the Web Viewer,
you will need to make modifications to the js code.
For the script look at this:
http://www.netlobo.com/javascript_location_reload.html
simple example attached:
Jason
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.1.1.v20060922-1058 Build &lt;20060926-0959></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 &lt;&lt;Your Company Name
here>></property>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<text id="6">
<text-property name="content"><![CDATA[<P>
<script defer="true">
var reloadTimer = null;
window.onload = function()
setReloadTime(5);
function setReloadTime(secs)
if (arguments.length == 1) {
if (reloadTimer) clearTimeout(reloadTimer);
reloadTimer = setTimeout("setReloadTime()", Math.ceil(parseFloat(secs) *
1000));
else {
window.location.replace(window.location.href);
function disableReload()
if (reloadTimer)
document.form1.reloadTime.value = 'Disabled';
</script>
</P>]]></text-property>
</text>
</body>
</report>
"Oliver Zein" <oliver.zein@email.de> wrote in message
news:4acf2daf7117833067c1453342b113a0$1@www.eclipse.org...
>the report group:
> Thanks!
Re: How can I use the refreshRate Property [message #204347 is a reply to message #203893] Fri, 01 December 2006 08:15 Go to previous messageGo to next message
Jason
many thanks for your help. The example works very well in HTML. Why does
it not work in the Web Viewer? Which jsp file(s) do I have to change to
make it work in the Web Viewer?
- Oliver
Re: How can I use the refreshRate Property [message #204404 is a reply to message #204347] Fri, 01 December 2006 11:53 Go to previous message
There is a bug with the script tag and the web viewer. It may work with the
latest milestone build of 2.2.
You could look at adding it to FramesetFragment.jsp. I havent tried it
though.
Jason
news:a760026ac642bfef6611e5be6de94f0d$1@www.eclipse.org...
> Jason
> - Oliver
Previous Topic:Persistent Reports -- where do I find information?
Next Topic:BIRT Tomcat Integration Problem
Current Time: Sat Aug 23 01:41:53 EDT 2025
Powered by FUDForum. Page generated in 0.06612 seconds
