Home » Eclipse Projects » Subversive » Compare file in workspace with revision?
Compare file in workspace with revision? [message #19480] Fri, 23 May 2008 04:29 Go to next message
Originally posted by: joerg.von.frantzius.artnology.com
probably I didn't see the obvious, but how can I compare a file in my
workspace with a certain revision in SVN? At least right-click "Compare
with..." on the file doesn't offer that option.
Jörg
Re: Compare file in workspace with revision? [message #19530 is a reply to message #19480] Fri, 23 May 2008 05:13 Go to previous messageGo to next message
Jörg von Frantzius <joerg.von.frantzius@artnology.com> writes:
> "Compare with..." on the file doesn't offer that option.
Right-click "Team/Show History" and you will get a History view
showing the revisions for that file. Right click on a history item
offers "Compare current with n" (where n is whatever revision you
chose).
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: Compare file in workspace with revision? [message #19575 is a reply to message #19530] Fri, 23 May 2008 06:46 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Owen Rees schrieb:
<blockquote cite="mid:m3wsll8jss.fsf@orees.hpl.hp.com" type="cite">
<pre wrap="">Jörg von Frantzius <a class="moz-txt-link-rfc2396E" href="mailto:joerg.von.frantzius@artnology.com">&lt;joerg.von.frantzius@artnology.com&gt;</a> writes:
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap=""><!---->
chose).
</pre>
</blockquote>
Thanks! Now that wasn't really <i>so</i> obvious I could say in my
defense :)<br>
</body>
</html>
Re: Compare file in workspace with revision? [message #19665 is a reply to message #19575] Fri, 23 May 2008 06:59 Go to previous messageGo to next message
> Thanks! Now that wasn't really so obvious I could say in my
> defense :)
It is different from CVS which has a "Compare with/History..." item
on the context (right click) menu - that just opens the History view
so it is the same as "Team/Show History..." but perhaps easier to
find.
Subversive provides a "Compare with/Local history..." which just told
me there was no local history for th exampe I tried.
Re: Compare file in workspace with revision? [message #19710 is a reply to message #19480] Fri, 23 May 2008 11:37 Go to previous messageGo to next message
Hi, Jorg.
You just have to click Team->Compare With URL...
The default URL will be the URL of the selected in the workspace resource
repository copy. Then you can select a revision of it in a appropriate
groupbox of the dialog and get Compare With Revision:).
Best regards, Alexei Goncharov.
Subversive Team.
Re: Compare file in workspace with revision? [message #19850 is a reply to message #19665] Mon, 26 May 2008 05:50 Go to previous messageGo to next message
Hello. And is it possible to compare a file in a branch with the current
version in the trunk? I've not been able to find this option.
Thanks!
César
Re: Compare file in workspace with revision? [message #19906 is a reply to message #19850] Mon, 26 May 2008 09:36 Go to previous messageGo to next message
> Thanks!
> César
Just "copare with url". Then "Browse" and manually find and select the
file in the trunk.
Subversive Team
Re: Compare file in workspace with revision? [message #1716383 is a reply to message #19906] Thu, 03 December 2015 06:58 Go to previous message
I do so as suggested but the question is really why there are in the "Compare with" popup all thinkable variants but not even the trunk. Why is even this case excluded? In 100 cases off calling "Compare with" from a branch workspace it is 99 times the case that I want to compare with trunk.
Previous Topic:svn+ssh not working at all
Next Topic:How to properly move a project inside a SVN repository?
Current Time: Fri Jul 18 03:28:51 EDT 2025
Powered by FUDForum. Page generated in 0.09024 seconds
