Home » Language IDEs » Java Development Tools (JDT) » Refactor > Rename
Refactor > Rename [message #19464] Sun, 11 May 2003 22:19 Go to next message
I try refactor > rename for class, field, method and it don't work.
I don't get Compilation unit,I have nothing in source,nothing in log.
Command do nothing.
What is a problem ?
My system : linux-gtk (rh 8.0), eclipse 2.1
regards
Haris Peco
Re: Refactor > Rename [message #19511 is a reply to message #19464] Mon, 12 May 2003 03:11 Go to previous messageGo to next message
Originally posted by: sbernatsky.ukr.net
Hello.
> Command do nothing.
> What is a problem ?
I've found the same behaviour when I compiled eclipse from sources with
javac target '1.3' (this is default for javac from j2sdk 1.4.1) or '1.4'.
best regards,
Stanislav V. Bernatsky
Re: Refactor > Rename [message #19908 is a reply to message #19511] Mon, 12 May 2003 14:06 Go to previous messageGo to next message
I compile eclipse from source (CVS) too.
I try window xp build (cvs build 2.1).
Refactor -> rname don't work, too
regards
Haris Peco
Stanislav V. Bernatsky wrote:
> Hello.
>> Command do nothing.
>> What is a problem ?
> best regards,
Re: Refactor > Rename [message #19954 is a reply to message #19908] Mon, 12 May 2003 11:46 Go to previous messageGo to next message
can you try searching for references (to the element that you'd like to rename) and tell me if that works
thanks
a.
eclipse.org
Re: Refactor > Rename [message #20039 is a reply to message #19954] Mon, 12 May 2003 14:27 Go to previous messageGo to next message
> rename) and tell me if that works thanks
I try Search - references - workspace for this field
I get all reference for this field.It works.
I don't know if You want that.
regards
Haris Peco
Re: Refactor > Rename [message #20195 is a reply to message #19954] Mon, 12 May 2003 16:24 Go to previous messageGo to next message
Hello Adam,
If I try rename when have bad selection (nothing select or complete line
select) I get error
regards
Haris Peco
Re: Refactor > Rename [message #20813 is a reply to message #20195] Tue, 13 May 2003 05:36 Go to previous messageGo to next message
> Hello Adam,
> select) I get error
what kind of error?
can you post a simple example here?
a.
eclipse.org
Re: Refactor > Rename [message #20861 is a reply to message #20813] Tue, 13 May 2003 09:31 Go to previous messageGo to next message
If I select nothing and call refactor -> rename I get dialog with error :
Operation unavailable on the current selection.
Select a java project, source folder, resource package,
completion unit, type , field, method, parameter or a local variable.
If I select a java project or anything I get nothing.
It haven't message, error ...
I am try on win xp (cvs eclipse 2.1), too.It is same.
regards
Haris Peco
Adam Kiezun wrote:
>> Hello Adam,
>> line
>> select) I get error
> what kind of error?
> a.
> eclipse.org
Re: Refactor > Rename [message #20886 is a reply to message #20861] Tue, 13 May 2003 07:30 Go to previous messageGo to next message
then i guess that's expected if you select something that is not
a reference to anything that could be renamed.
do you mean that you cannot rename a java project?
a.
eclipse.org
Re: Refactor > Rename [message #20892 is a reply to message #20886] Tue, 13 May 2003 10:44 Go to previous messageGo to next message
yes, I can't rename java project, field, class, method.
I can rename nothing
regards
Haris Peco
Re: Refactor > Rename [message #21323 is a reply to message #20892] Tue, 13 May 2003 08:32 Go to previous messageGo to next message
even when you select a field in the outline view?
or a package in the package explorer?
what do you get then? what error?
a.
eclipse.org
Re: Refactor > Rename [message #21337 is a reply to message #21323] Tue, 13 May 2003 11:13 Go to previous messageGo to next message
Yes.I select a field in the outline or a package or source and refactor
->rename
I get nothing, no error, no log, nothing
regards
Haris Peco
Re: Refactor > Rename [message #21427 is a reply to message #21323] Tue, 13 May 2003 14:07 Go to previous messageGo to next message
Hi Adam,
Can You refactor -> rename and if You can what is Your OS and eclipse
version
regards
Haris Peco
> a.
> eclipse.org
Re: Refactor > Rename [message #21434 is a reply to message #21427] Tue, 13 May 2003 11:55 Go to previous messageGo to next message
i can now and i've always been able to
now, i'm running the I-build 20030507+latest jdt plugins+latest text plugins
but it did work for me (and everybody else i know) in any stable or release build of eclipse 1.0, 2.0 or 2.1
my os is winXp
a.
eclipse.org
Re: Refactor > Rename [message #21456 is a reply to message #21434] Tue, 13 May 2003 14:36 Go to previous messageGo to next message
> plugins
> release build of eclipse 1.0, 2.0 or 2.1 my os is winXp
> a.
Is it possible that any plugin crash refactor - I have next plugins (except
default) :
xml buddy 0.2.8
assisi v4e 1.0.37
emf 1.0.2
gef 2.1.0
metrics 1.0.10
jboss ide 1.0.2
dbedit 0.9.9
lomboz j2ee 0.
eclipseuml 1.2.1
CodeLogic 1.4.0
thanks
Haris Peco
Re: Refactor > Rename [message #21545 is a reply to message #21456] Tue, 13 May 2003 12:16 Go to previous messageGo to next message
> default) :
it sure is
i never used any of these plugins, though, so i have no idea
a.
eclipse.org
Re: Refactor > Rename [message #21632 is a reply to message #21545] Tue, 13 May 2003 15:11 Go to previous messageGo to next message
>> (except default) :
> it sure is
I delete all plugins from plugins and features dir, delete workspace and try
again with one class like
public class hello {
I select hello class and try :
refactor - move work
refactor - extract interface work
refactor - use supertype where possible work
refactor - change method signature work
refactor - push down work
refactor - push up work
refactor - inline - work
refactor - rename don't work again
All except rename work.
Can I try anuthing else.
regards
Haris Peco
Re: Refactor > Rename [message #21767 is a reply to message #21337] Tue, 13 May 2003 13:45 Go to previous messageGo to next message
Originally posted by: vkyr.nospam-ision.net
I see *absolutely* the same behaviour as "snpe" described in this thread on
several University computers which all run Eclipse 2.1 final under W2K.
Valentino
"snpe" <snpe@snpe.co.yu> schrieb im Newsbeitrag
news:b9qplh$nmj$1@rogue.oti.com...
> ->rename
> regards
> Haris Peco
Re: Refactor > Rename [message #21812 is a reply to message #21545] Tue, 13 May 2003 13:53 Go to previous messageGo to next message
NO, it isn't! We don't have any third party plugins installed on our
University dev machines, just Eclipse 2.1 and our own actual plugin projects
which we have under development. - BTW, at home on my own two computers
(same OS same Eclipse version with plenty third party addon plugins...) I
don't get this behahaviour.
Hmmm, maybe for the Univerity computers it has something todo with access
rights or the like (I don't really know, just a guess into the blue), or
Eclipse makes somewhere some broken entry which yields any future rename
usage...? Absolutely strage related to this is, that there is always *no*
error message in the error log, console or somewhere else. - It just doesn't
do nothing in these strange and odd "rename behaviour" cases!
Valentino
"Adam Kiezun" <adam_kiezun@ch.ibm.spam.protection.com> schrieb im
Newsbeitrag news:b9r5ou$4h2$1@rogue.oti.com...
(except
> > default) :
> it sure is
> a.
> eclipse.org
Re: Refactor > Rename [message #21903 is a reply to message #21812] Tue, 13 May 2003 17:39 Go to previous messageGo to next message
Originally posted by: adam.kiezun.gmx.net.remove
Valentino, Haris
do you guys have a small workspace in which you can reproduce that behavior?
if so, this bug would definitely be Priority 1 for the 2.1.1 release (june/july)
a.
eclipse.org
Re: Refactor > Rename [message #21948 is a reply to message #21903] Tue, 13 May 2003 20:26 Go to previous messageGo to next message
Adam Kiezun wrote:
> Valentino, Haris
> behavior? if so, this bug would definitely be Priority 1 for the 2.1.1
> release (june/july)
I don't understand.I delete all plugins, and workspace dir, start new
eclipse (with new enviroment), add project and class
class Hello {
I don't rename class Hello.I can another refactoring, but not rename
Question for Valentino :
Are You build eclipse from CVS ?
regards
Haris Peco
Re: Refactor > Rename [message #22165 is a reply to message #19908] Wed, 14 May 2003 04:13 Go to previous messageGo to next message
Hello again.
Which j2sk did you use for compiling?
Here are my steps to reproduce the bug.
1) get sources from cvs;
2) get build scripts from eclipse download site;
3) replace '<javac ' to '<javac target="1.3"' in build.xml files;
4) comlipe eclipse;
5) run eclipse and try to rename something. -> you couldn't do it.
But if you replace '<javac ' to '<javac target="1.1"' in 3) then you'll be
able to rename anything.
best regards,
Re: Refactor > Rename [message #22289 is a reply to message #21903] Wed, 14 May 2003 06:25 Go to previous messageGo to next message
Adam, I will not be before next monday in the University, so you will have
to wait till monday for that. Next monday I can then check the Java SDK
version on one of those odd behaving machines and try to send you a
minimalistic workspace which might indicate what we are talking about in a
reproducable manner (well, I don't really know if it is reproducable from a
workspace, but maybe you can see enough out of this?).
Valentino
"Adam Kiezun" <adam.kiezun@gmx.net.remove> schrieb im Newsbeitrag
news:b9rom9$luq$1@rogue.oti.com...
> Valentino, Haris
behavior?
(june/july)
> a.
> eclipse.org
Re: Refactor > Rename [message #22964 is a reply to message #22165] Wed, 14 May 2003 13:37 Go to previous messageGo to next message
> Hello again.
> 4) comlipe eclipse;
I use java 1.4.0 on WinXp and 1.4.1 on linux.
I don't rename javac in build scripts (javac target=1.3) and this is a
problem, probably.
Thanks!
Adam ?
regards
Haris Peco
Re: Refactor > Rename [message #23049 is a reply to message #22165] Wed, 14 May 2003 13:56 Go to previous messageGo to next message
> Hello again.
> 4) comlipe eclipse;
Hi Stanislav,
I have yet any problem with Eclipse.It is maybe same reason.
Update manager don't work - I haven't directory for update and I can't add
any dir. - I get NullException.
Is it same problem (jdk 1.1) ?
Haris Peco
Re: Refactor > Rename [message #23093 is a reply to message #22964] Wed, 14 May 2003 11:36 Go to previous messageGo to next message
> Adam ?
guys, do you also see the problem if you use the normal, pre-build eclipse distribution?
a.
eclipse.org
Re: Refactor > Rename [message #23235 is a reply to message #23093] Wed, 14 May 2003 14:56 Go to previous messageGo to next message
Adam Kiezun wrote:
>> Adam ?
> distribution? a.
> eclipse.org
No, I don't use pre-build eclipse.
I can't download eclipse every times from begining
I upgrade eclipse with CVS and next time download build scripts
and call 'build os=linux ...'.
I download eclipse last build M20030507 and I have same problem with
refactor -> rename.
I see that build id (from help about) is same for eclipse 2.1 final
and M20030507.I don't know is it a problem.
If I must download every times from begining, why cvs ?
If eclipse cvs don't work then a problem is cvs, but I don't think so.
regards
Haris Peco
Re: Refactor > Rename [message #23424 is a reply to message #21948] Wed, 14 May 2003 11:22 Go to previous messageGo to next message
news:b9rq32$mrh$1@rogue.oti.com...
Well, I believe you mean with "You build Eclipse from CVS", if I use the
Eclipse sources from an eclipse.org cvs server or the like (?).
NO, I don't. - I use instead the Eclipse "jdt.ui" sources which are coming
along with the Eclipse 2.1 SDK. I always import the Eclipse "jdt.ui" plugin
with sources into my dev workspace and the I'am recompiling these. The
reason I usually tend to use a source import of the whole "jdt.ui" inside my
workspace is, that I'am adapting/combining foreign source model refactoring
plugins with the standard Eclipse Java refactorings which come along inside
the jdt.ui.
However, I now always have the effect, that after importing the Eclipse
"jdt.ui" plugin sources in the above described way (even I leave the jdt.ui
clean/unmodified by me), the rename refactorings don't work inside any
"runtime-workbench" launch. All other refactorings in contrast seem to work
instead. - I can only fix this odd "runtime-workbench" rename refactoring
behaviour, by deleting the imported "jdt.ui" and it's sources completely
from the dev workspace. Since thus the next time when the runtime-workspace
is launched it uses again the default Eclipse deployed "jdt.ui" plugin from
the Eclipse plugin directory and not the imported and deleted stuff I had
before in the workspace.
Valentino
Re: Refactor > Rename [message #23467 is a reply to message #23093] Wed, 14 May 2003 13:55 Go to previous messageGo to next message
Yes, I use instead the Eclipse "jdt.ui" sources which are coming along with
the Eclipse 2.1 SDK. I always import the Eclipse "jdt.ui" plugin with
sources into my dev workspace and the I'am recompiling these. The reason I
the jdt.ui.
Valentino
Newsbeitrag news:b9tnov$8jt$1@rogue.oti.com...
> > Adam ?
distribution?
> a.
> eclipse.org
Re: Refactor > Rename [message #23765 is a reply to message #23467] Wed, 14 May 2003 19:09 Go to previous messageGo to next message
It is a problem that jdt.ui isn't compatible with jdk 1.3+
Haris Peco
> with the Eclipse 2.1 SDK. I always import the Eclipse "jdt.ui" plugin with
> refactoring plugins with the standard Eclipse Java refactorings which come
> along inside the jdt.ui.
> jdt.ui clean/unmodified by me), the rename refactorings don't work inside
> any "runtime-workbench" launch. All other refactorings in contrast seem to
> work instead. - I can only fix this odd "runtime-workbench" rename
> refactoring behaviour, by deleting the imported "jdt.ui" and it's sources
> completely from the dev workspace. Since thus the next time when the
> runtime-workspace is launched it uses again the default Eclipse deployed
> "jdt.ui" plugin from the Eclipse plugin directory and not the imported and
> deleted stuff I had before in the workspace.
> Valentino
>> > Adam ?
>> eclipse
> distribution?
>> a.
>> eclipse.org
Re: Refactor > Rename [message #23809 is a reply to message #23765] Wed, 14 May 2003 17:47 Go to previous messageGo to next message
AFAIK we only have JDK 1.4 versions on those computers in the University,
even I'am not absolutely sure for this, so I will check this on monday when
I'am again there. - However, at home I use Eclipse 2.1 final on two
computers, both running W2K and the JDK 1.4.1 and here I don't have these
problems. At home it works so far.
Valentino
news:b9u9uj$qq9$1@rogue.oti.com...
> Thanks
> Haris Peco
with
I
come
inside
to
sources
and
> > Valentino
> >> > Adam ?
> >> eclipse
> > distribution?
> >> a.
> >> eclipse.org
Re: Refactor > Rename [message #24009 is a reply to message #23049] Thu, 15 May 2003 04:05 Go to previous messageGo to next message
Hello.
I don't know. I rolled back to '<javac target="1.1"' just because it
solved my problems.
Stanislav V. Bernatsky.
Re: Refactor > Rename [message #24073 is a reply to message #23093] Thu, 15 May 2003 04:13 Go to previous messageGo to next message
Hello, Adam.
distribution?
Well, as far as I remember, I had no problem with the 2.0 pre-build
eclipse distribution. It was the last one which I downloaded from eclipse
site. Other versions were build from cvs sources.
Now I use 2.1.1 (M20030430) build from cvs source with '<javac
target="1.1"' and 'refactor->rename' works fine.
I'll recompile with '<javac target="1.3"' option and post result a bit
later.
Stanislav Bernatsky.
Re: Refactor > Rename [message #24319 is a reply to message #24073] Thu, 15 May 2003 09:31 Go to previous messageGo to next message
Stanislav Bernatsky wrote:
> Hello, Adam.
>> eclipse
> distribution?
> later.
Hi Stanislav,
I try recompile with <javac target="1.1".
I set <javac target="1.1" in build.xml files and :
ant -Dos=linux -Dws=gtk clean
ant -Dos=linux -Dws=gtk compile
ant -Dos=linux -Dws=gtk buildDoc
ant -Dos=linux -Dws=gtk install
Refactor -> rename don't work.I use jdk 1.4.1 for Linux (eclipse M20030507)
Is it enough ?
I try with JDK 1.3.1 (ant javac default target is "1.1" for <= 1.3), but I
get 'out of memory error'
Haris Peco
Re: Refactor > Rename [message #24361 is a reply to message #23809] Thu, 15 May 2003 09:32 Go to previous messageGo to next message
Is eclipse from cvs ?
> when I'am again there. - However, at home I use Eclipse 2.1 final on two
> Valentino
>> Thanks
>> Haris Peco
> with
>> > reason
> I
> come
> inside
> to
> sources
>> > deployed "jdt.ui" plugin from the Eclipse plugin directory and not the
>> > imported
> and
>> > Valentino
>> >> > Adam ?
>> >> eclipse
>> > distribution?
>> >> a.
>> >> eclipse.org
Re: Refactor > Rename [message #24648 is a reply to message #24361] Thu, 15 May 2003 11:10 Go to previous message
NO, it's the "jdt.ui" plugin from inside of the Eclipse 2.1 final SDK (and
thus not from the CVS server), which I import with included sources into the
workspace and then recompile for usage in the Eclipse runtime-workspace.
Valentino
news:b9vsgl$uhh$2@rogue.oti.com...
University,
these
> > Valentino
> >> Thanks
> >> Haris Peco
along
> > with
> >> > reason
> > I
> > come
Eclipse
> > inside
seem
> > to
> > sources
the
> >> > imported
> > and
> >> > Valentino
> >> >> > Adam ?
> >> >> eclipse
> >> > distribution?
> >> >> a.
> >> >> eclipse.org
Previous Topic:Marker Bar
Next Topic:exception while setting up project
Current Time: Sat Jul 12 15:34:18 EDT 2025
Powered by FUDForum. Page generated in 1.09981 seconds
