| RCP plugin using Java Comm API doesn't find javax/comm classes [message #203139] |
Fri, 27 February 2004 12:50  |
I'm developing a rich client platform plugin using eclipse M7.
I'm trying to use the Java Comm API from within the plugin.
I installed the comm.jar, win32comm.dll and the corresponding property file
in all possible JRE locations
on my computer (j2sdk1.4.2_03).
The SerialDemo Java Application delivered with the Java Comm API runs
(compiled and started as "normal" Java application
from the eclipse workspace).
When I run my plugin and try to instantiate a class extending a javax/comm
class, I get the appended log message.
Any ideas?
Greetings,
Bernd Hofner
!SESSION Feb 27, 2004
18:17:40.455 ---------------------------------------------
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -application ssi.profilstrasse.RcpApplication -data
D:\Eclipse-Workspace\ssi.profilstrasse.runtime-workspace -dev bin -debug
file:D:\Eclipse-Workspace\.metadata\.plugins\org.eclipse.pde .core\D__Eclipse-Workspace_ssi.profilstrasse.runtime-workspa ce/.options
!ENTRY org.eclipse.core.runtime 4 2 Feb 27, 2004 18:17:40.465
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.NoClassDefFoundError: javax/comm/SerialPortEventListener
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.define
Class(DefaultClassLoader.java:298)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClass
Loader.java:99)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findCl
assImpl(DefaultClassLoader.java:287)
ass(DefaultClassLoader.java:176)
org.eclipse.osgi.framework.adaptor.BundleClassLoader.findLoc alClass(BundleCl
assLoader.java:261)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseCl
assLoader.java:73)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleL
oader.java:326)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:357)
org.eclipse.osgi.framework.adaptor.BundleClassLoader.loadCla ss(BundleClassLo
ader.java:115)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at ssi.profilstrasse.clm.Clm.<init>(Clm.java:48)
at ssi.profilstrasse.clm.Clm.getInstance(Clm.java:30)
at ssi.profilstrasse.clm.views.TestView.createPartControl(TestV iew.java:50)
at org.eclipse.ui.internal.PartPane$1.run(PartPane.java:121)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:819)
at org.eclipse.core.runtime.Platform.run(Platform.java:493)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:117)
at org.eclipse.ui.internal.ViewPane.createChildControl(ViewPane .java:256)
at org.eclipse.ui.internal.ViewFactory$1.run(ViewFactory.java:2 45)
:819)
at org.eclipse.ui.internal.ViewFactory.busyRestoreView(ViewFact ory.java:174)
at org.eclipse.ui.internal.ViewFactory$2.run(ViewFactory.java:4 19)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
at org.eclipse.ui.internal.ViewFactory.restoreView(ViewFactory. java:417)
org.eclipse.ui.internal.ViewFactory$ViewReference.getPart(Vi ewFactory.java:9
3)
org.eclipse.ui.internal.WorkbenchPage$1.propertyChange(Workb enchPage.java:13
4)
at org.eclipse.ui.internal.LayoutPart.setVisible(LayoutPart.jav a:236)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:38 6)
org.eclipse.ui.internal.WorkbenchPage.updateVisibility(Workb enchPage.java:27
23)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1937)
at org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:1824)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:1
811)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:58
9)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:1123)
org.eclipse.ui.internal.WorkbenchWindow.openPage(WorkbenchWi ndow.java:1120)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1186)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:899)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1503)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at ssi.profilstrasse.RcpApplication.run(RcpApplication.java:31)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:257)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
| Re: RCP plugin using Java Comm API doesn't find javax/comm classes [message #203373 is a reply to message #203139] |
Sat, 28 February 2004 05:51  |
Hmm, it seems I kind of helped myself:
instead of the placement as a java extension lib:
C:\Java\j2sdk1.4.2_03\jre\lib\ext\comm.jar
C:\Java\j2sdk1.4.2_03\jre\bin\win32com.dll
C:\Java\j2sdk1.4.2_03\jre\lib\javax.comm.properties
as recommended by the Java Comm API documentation,
I placed the three files in my plugin directory (next to the plugin.xml).
In the plugin.xml, I added comm.jar to the run-time libraries.
Now the plugin just runs fine.
Note that an absolute reference like:
//C:/Java/j2sdk1.4.2_03/jre/lib/ext/comm.jar
or
as a run-time library entry in the plugin.xml seems not to work
(i.e. the classes in the jar are still not found at runtime).
Nevertheless the question remains:
Why does the eclipse class loader mechanism doesn't find
extension libraries installed in the JRE directories of the VM?
So long,
Bernd
"Bernd Hofner" <bernd.hofner@gmx.net> wrote in message
news:c1nvo0$tu4$1@eclipse.org...
> Hello,
file
> Any ideas?
> Greetings,
> Bernd Hofner
> !STACK 0
> at
> at
> Loader.java:99)
> at
> at
> at
> assLoader.java:261)
> at
> assLoader.java:73)
> at
> oader.java:326)
> at
> .java:357)
> at
> ader.java:115)
> at
> at
va
> :819)
> at
> :819)
> at
> at
> 3)
> at
> 4)
> at
> 23)
> at
> at
> at
> 811)
> at
> 9)
> at
> at
> at
> at
> at
> java:257)
> at
> at
> at
> .java:25)
FUDForum. Page generated in 0.03989 seconds
