recommended CVS server for Windows ? [message #203097] |
Fri, 27 February 2004 11:39  |
Originally posted by: jimmy.lopez.libertysurf.fr
does someone know a correct CVS server for Windows ? I tried CVSNT, but it
hangs when I commit projects... (when I use external servers like
cvsdude.org, all goes fine...)
Re: recommended CVS server for Windows ? [message #203396 is a reply to message #203301] |
Sat, 28 February 2004 06:23  |
ted stockwell wrote:
> We are successfully using CVSNT on Windows 2000 with both Eclipse 2.2.1 and
> 3.0M7.
> I installed CVSNT back in October of 2003, so it must be version 2.0.25 or
> thereabouts.
> I would make sure that you installed in correctly and are using it correctly
> (for instance, the root path should be a full path, something like
> c:cvsntcvs, this confused me when I first started using CVSNT).
that's why I did...
well, I think I will try again... (maybe by installing CVSNT on C: drive,
instead of D: drive as I did...)
FUDForum. Page generated in 0.03453 seconds
