How to generate executable jar file from JSystemTrader with Eclipse ? [message #202990] |
Tue, 03 April 2007 11:18 |
Originally posted by: no.spam.com
Eclipse 3.2
I try to generate executable jar file from this Java program under BSD
licence :
http://www.myjavaserver.com/~nonlinear/JSystemTrader/JSystem Trader.html
I do :
Menu / file / Export...
Etc.
I have the following Error dialogue box :
JAR creation failed. See details for additional information.
Exported with compile warnings:
/JSystemTrader/source/com/ib/client/EReader.java
/JSystemTrader/source/com/jsystemtrader/backdata/BackDataDia log.java
Then warning about all class
Then this error message :
Resource is out of sync with the file system:
/JSystemTrader/log/EventLog.htm.
I think it is not the warning which stop generate Jar.
I think it is the last error message :
Tintin92
Re: How to generate executable jar file from JSystemTrader with Eclipse ? [message #203137 is a reply to message #202990] |
Wed, 04 April 2007 04:07 |
Originally posted by: irbull.cs.uvic.ca
You're right, I don't think it is the warning's that are causing the
problems. Usually when you get a "Resource is out of sync error", this
means that the file has change outside of Eclipse. For example, if you
have a file in your workspace, but make a change to it using an external
editor. Trying selecting your project and select File->Refresh (or
press F5). Then try the export again.
cheers,
ian
Tintin92 wrote:
> Eclipse 3.2
> licence :
> I do :
> Etc.
> Tintin92
Re: How to generate executable jar file from JSystemTrader with Eclipse ? [message #203220 is a reply to message #203137] |
Wed, 04 April 2007 08:16 |
----- Original Message ----- > You're right, I don't think it is the
> cheers,
> ian
Hi Ian,
I try F5 and it helps me to do a step.
Now I do a jar file but when I double click I have the following error box :
Failed to load Main-Class manifest attribute from S:\testJSystemTrader.jar
Any idea ?
Tintin92
Re: How to generate executable jar file from JSystemTrader with Eclipse ? [message #203329 is a reply to message #203220] |
Wed, 04 April 2007 17:16 |
--------------030608090103050304060601
On the last page (Page 3) of the export wizard (I assume you are using
the export as jar wizard) you can set the Main class (The application
entry point).
See the attached screenshot.
cheers,
ian
>> cheers,
>> ian
> Hi Ian,
> Any idea ?
> Tintin92
Content-Type: image/jpeg;
name="export.jpg"
Content-Disposition: inline;
filename="export.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAGKAe4DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDp9MsYH0e3dbWOR9sSFRhd ileW9/pT0s4P
twt2ijIDqp+QdwD/AFrp9A8NWk2g6fcfaLtJJLWMsY5NvVR6Cr8fhDT4jlJb lTnOQ4z+eK0U
kQ4s5YaZYgJuWLOTvHHTBx/IfnUcdhZNeSIYkMYTcvA56V1v/CIad/z0uP8A vsf4Uf8ACIad
/wA9Lj/vsf4UcyCzORXTLZth2plgxKhFyMD+tKNLtCcbovv7c7F9QP8AP0rr h4S09TlZbkZG
OHH+FJ/wiGnf89Lj/vsf4UcyDlZxc1paLDG8candkHKLUHkw/wDPGP8A74Fd 3/wiGnf89Lj/
AL7H+FH/AAiGnf8APS4/77H+FNTQuVnCeRD/AM8Y/wDvkUeRD/zxj/75Fd3/ AMIhp3/PS4/7
7H+FH/CIad/z0uP++x/hRzxFys4TyIf+eMf/AHyKPIh/54x/98iu7/4RDTv+ elx/32P8KP8A
hENO/wCelx/32P8ACjniHKzhPIh/54x/98ijyIf+eMf/AHyK7v8A4RDTv+el x/32P8KP+EQ0
7/npcf8AfY/wo54hys4TyIf+eMf/AHyKPIh/54x/98iu7/4RDTv+elx/32P8 KP8AhENO/wCe
lx/32P8ACjniHKzhPIh/54x/98ijyIf+eMf/AHyK7v8A4RDTv+elx/32P8KP +EQ07/npcf8A
fY/wo54hys4TyIf+eMf/AHyKPIh/54x/98iu7/4RDTv+elx/32P8KP8AhENO /wCelx/32P8A
CjniHKzhPIh/54x/98ijyIf+eMf/AHyK7v8A4RDTv+elx/32P8KP+EQ07/np cf8AfY/wo54h
ys4TyIf+eMf/AHyKPIh/54x/98iu7/4RDTv+elx/32P8KP8AhENO/wCelx/3 2P8ACjniHKzh
PIh/54x/98ijyIf+eMf/AHyK7v8A4RDTv+elx/32P8KP+EQ07/npcf8AfY/w o54hys4TyIf+
eMf/AHyKPIh/54x/98iu7/4RDTv+elx/32P8KP8AhENO/wCelx/32P8ACjni HKzhPIh/54x/
98ijyIf+eMf/AHyK7v8A4RDTv+elx/32P8KP+EQ07/npcf8AfY/wo54hys4T yIf+eMf/AHyK
PIh/54x/98iu7/4RDTv+elx/32P8KP8AhENO/wCelx/32P8ACjniHKzhPIh/ 54x/98ijyIf+
eMf/AHyK7v8A4RDTv+elx/32P8KP+EQ07/npcf8AfY/wo54hys4TyIf+eMf/ AHyKPIh/54x/
98iu7/4RDTv+elx/32P8KP8AhENO/wCelx/32P8ACjniHKzhPIh/54x/98ij yIf+eMf/AHyK
7v8A4RDTv+elx/32P8KP+EQ07/npcf8AfY/wo54hys4TyIf+eMf/AHyKPIh/ 54x/98iu7/4R
DTv+elx/32P8KP8AhENO/wCelx/32P8ACjniHKzhPIh/54x/98ijyIf+eMf/ AHyK7v8A4RDT
v+elx/32P8KP+EQ07/npcf8AfY/wo54hys4TyIf+eMf/AHyKPIh/54x/98iu 7/4RDTv+elx/
32P8KP8AhENO/wCelx/32P8ACjniHKzhPIh/54x/98ijyIf+eMf/AHyK7v8A 4RDTv+elx/32
P8KP+EQ07/npcf8AfY/wo54hys4TyIf+eMf/AHyKPIh/54x/98iu7/4RDTv+ elx/32P8KP8A
ys4TyYf+eMf/AHwKsnTd1tC0VrAxkySX+XocYUAHJ+tdmvhLTVcEtOwB6Fxg /pWobCAoE+ZV
AxhWKjHpxSlNdClF9Tgv7CNvavPJZLc/vAiRwAbmGSC3T2zyQPeuZ8XaVc2+ iwTxIkW6WPO0
7WXcjHaeAe1ewyQQIgUBhgYG1sY/KuH+I0aR+G7cIuB9rUnnOfkeld7jsjSm vrjT/AOhy2sj
JK8lhH8gyWVpIw4A913Vkpc+OJV2SW12pu7mK4T5kTyIyzB4iyg4AXYckZzu rsvDQB8L6VkA
4tYiM/7orTWSN3ZFdSy/eAPI+tQUcleHxNceCtJW1mmi1lpIFuZDGMrz85Yd Nvrjt0rOk1Dx
vp8eqSPZvdXEsivbRooaKEeWxKAgZI3BVz6nsK9AJUYyQM8CjigDg7rUPGM4 ZfsBEbzMAsaM
jIqyw7TuDZOVaX/vn8y0m8YWMsarF9oSe+uWlkuQ52oJ8RqAM7VMeSDwOmff u9yb9u4bsZxn
nFKSoBJIAHOaAOKjvvFU2r2S3ETw20WoFJ3hgykkJjk29fmwG8sE9MnOSOlj XbrXrHxHFPZi
S408Q/vItpVYiFcly2MN/D8pIPAx3rqklikaRUdWaNtrgfwnAOPyIP408gHr QBwFr4g8X3mi
QXdtYxSecls/mvAybd8bNJhASWAbYAR/ePpV66vfEs9vcxyWhjlV7UxJAjYd S0RkbeCDxmQb
fReetdiAqgAAADoBUVxdW9rHvnlVF9z15A/Hkj86AOBs28XWE0srR3NwZJJy zS7mEaG7CqVT
dg4hywAH/wBez4h1XxazXFppFjMFNo4S58rB8zyS6soOQPnATB79u9d1wKhm ure3RHmlRFdg
qknqT/8AqJ/CgDi7rUfFdtPePY2UlwjuDE0sbHeRbxkDaW+QGTcCRjGOnetb SL3xFLrbx6ja
olk32nayxkFNkqrFznnchY9O1dDFNFOm+J1dclcg9wSCPzBFJDPDcBzE4cI5 RiOzDqPwoAlo
qOaeKCJ5ZZFREUuzMegHU1JkUAFFN8xAQC65JwBnv1xUbXlssEk5nj8qMEu4 YELjrmgCaioo
bqC43CGVXK43AHp9aloAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKbIdsbEdhQBky3 M73M4ihaSMNt
DhiBnuPwqubueLBkhlAB5fccKPU1Y0+fZbquf4R/KotSmBiOTweDUfVU53bY va2ReY5Gc1xn
xIIPh23x/wA/a/8AoD10dgxbToCTkhAPyrmfiJ/yLkH/AF9r/wCgPXTJWRKd zsPDP/Ir6V/1
6Rf+giqsek39sF+zi0DxTGQSEsrTg7siTA/2s98kdqs+GmA8L6Vkj/j0i/8A QRWruX+8PzrE
s5SDwzfrc20txdrOIWhch5XOXRNrEenc45yfSl/4Ri/khkSXUHB8p1QpNIP3 hXAkPPXPOOg7
V1W5f7w/Ojcv94fnQBzN14evSZ44LgPbSSIUiknkUoo+9hhkgk/z+lSReH7w prMVzfSTR36O
kYZ8hA27HGBjAYDqc4roty/3h+dG5f7w/OgDmJfDN2yTvb3ZtZ5yNxjlYgKI kTbz7p1xnBqy
+hXM2kWdnLeS74d5Z/ObJJVgvzLjOCw7fwit7cv94fnRuX+8PzoA5e48O6n5 kAtNQMcUc6yk
NK5OMR5HOc5Kvxx97r1BT/hFblltYpL1nhRYGlRpXO+RHVmbk99tdTuX+8Pz o3L/AHh+dAHK
ReGtUjQBtTllcXKy7nmOCBnPAUdc9M9utWG8NSNoOn2CyLHJZFtjq7dfLdFb PXOWBx7V0e5f
7w/Ojcv94fnQBzlloF9a6zHdtfu1urSMYVfC/MztjGOfvg5yOV71G/hq8jdh a3YiVpJZMiRx
sLSO3A6HIYKc9NuRXT7l/vD86Ny/3h+dAHP6l4cN3a28MTjMdpPbFpJHyPMU Ddnknkd/WmHw
9epqtvPFqEy2kMu4QeaeFyCRyCWzgjGRwa6Pcv8AeH50bl/vD86AOXl0C8v9 SnvTO9r5VwZb
VCFO5gEBZuDwdmOMHDH1p1t4Va30m8sTOJPtVskTMeNrKD0xj5efr15rpty/ 3h+dG5f7w/Og
DlJvDGotPvi1OSNfPaQqkhB2k5XJIOdo4x+tdTH5m0+Zt3bjjb0xnj8cYp25 f7w/Ojcv94fn
QAtFJuX+8Pzo3L/eH50ALRSbl/vD86Ny/wB4fnQAtFJuX+8Pzo3L/eH50ALR Sbl/vD86Ny/3
h+dAC0Um5f7w/Ojcv94fnQAtFJuX+8Pzo3L/AHh+dAC0Um5f7w/Ojcv94fnQ AtFJuX+8Pzo3
L/eH50ALRSbl/vD86Ny/3h+dAC0Um5f7w/Ojcv8AeH50ALRSbl/vD86Ny/3h +dAC0Um5f7w/
Ojcv94fnQAtFJuX+8Pzo3L/eH50ALRSbl/vD86Ny/wB4fnQAtFJuX+8Pzo3L /eH50ALRSbl/
vD86Ny/3h+dAC0Um5f7w/Ojcv94fnQAtFJuX+8Pzo3L/AHh+dADZS4jYxgF8 cA9DXKxeK7p/
E0Oh3Wm+S0yOwk35HA+ldYWX1H51m3WlWt1qVrqDAC5ts7HB6gggg/nVwcVe 5Mk+hkx77aUr
MswAAHyoSDgY7VDes1woWFZifQxkfzrpmXPp+dRtGx6AfmKtT6kuCMuzheK1 jjb+FQDXN/ET
/kXIP+vtf/QHrs2hc9APzFcd8RkZPDkG4Yzdr3/2HpSasNLU3tERG8P6YSoJ +yRdv9gVdCRH
oqHHoBVPQ/8AkXtM/wCvSL/0AVz7aBqlukcFp5caNL/yznZCAEcZZ1RS3JUg HPI5PNc5odb5
cf8AcX8qjWS1eYwq0TSqNxQYJAzjP5gj8Kwv7G1j7RdO2oNKkjhlQzugZc5x wMpgcZU845qO
bR9RhvGnhupfPuJAm9ZGZUj3SE5B44Vxj3HpQM6N/Ijxv8tdxCjOOSegp3lx /wBxfyrFvNCe
61MziRhCywgkXDqw8tmJxj1DDnOevrSaZpWqWuprPdX7TQiBU2eYxG4KoPyk eoJznPNAG35a
f3F/Kjy0/uL+VYMeh38WJF1CYzBI/v3EjKWBbecZ6EFQPp2qGy0PV0Aa61Fi ySbo1S5kIAzG
SDnG77r9c/eoA6CKS1nLiJopChAbbg4yMj9DUnlx/wBxfyrmIPDuqW5tWTUX BWUSXGJ3+c4T
nkHP3W44HzVNaaHqENx508/nMsc8alruTOHCbcnHqp6AYyMcigDofLj/ALi/ lR5cf9xfyp1F
ADfLj/uL+VHlx/3F/KnUUAN8uP8AuL+VHlx/3F/KnUUAN8uP+4v5UeXH/cX8 qdRQA3y4/wC4
v5UeXH/cX8qdRQA3y4/7i/lR5cf9xfyp1FADfLj/ALi/lR5cf9xfyp1FADfL j/uL+VHlx/3F
/KnUUAN8uP8AuL+VHlx/3F/KnUUAN8uP+4v5UeXH/cX8qdRQA3y4/wC4v5Ue XH/cX8qdRQA3
y4/7i/lR5cf9xfyp1FADfLj/ALi/lR5cf9xfyp1FADfLj/uL+VHlx/3F/KnU UAN8uP8AuL+V
Hlx/3F/KnUUAN8uP+4v5UeXH/cX8qdRQA3y4/wC4v5UeXH/cX8qdRQA3y4/7 i/lR5cf9xfyp
1FADfLj/ALi/lR5cf9xfyp1FADfLj/uL+VHlx/3F/KnUUAN8uP8AuL+VHlx/ 3F/KnUUAN8uP
+4v5UeXH/cX8qdRQA3y4/wC4v5UeXH/cX8qdRQA3y4/7i/lR5cf9xfyp1FAD fLj/ALi/lR5c
f9xfyp1FADfLj/uL+Vcl8RVVfDkG0Af6WvQf7D119cj8Rv8AkXIP+vtf/QHo W4mb+h/8i9pn
/XpF/wCgCrkkscK7pZFQdMscVT0P/kXtM/69Iv8A0AU7ULaacZhdkbaVyuNy 5xyM/T1FNK71
B7aFwMrKHDAqRnIPFNiljmTfFIki9NysCKz7u0mbRJ7dVZ5XBwikHOT05IB9 +R3rHh0fVbyW
OeV3sAlwZPIR02kYToVBzjaeuPvYzSGdXRXMTeGLw20MUGpyx7Vj8zEh+dwG DNk59VP4U+58
O3kkluYb3Yq3DSzEsxLgybsc542/L2/LigDowQwBByDyCO9NE0ZlEQdS5Bba D2Bwf1rB07QL
uyvbCU3hEFtAsRhRjtJCkdCMnOQeo5HehPDbJP5qyKjJLJJGUZh9+USHP4Ar /wDroA6GisGy
0K7t9LurSfUJZnmdT5jOc4BGTwBgn/JqKfw5ciB0tLsoXL7gzscgyBkHOcbV yOhpAdEzKi7n
YKvTJOKZBNHcwJNE26NxlWxjIrno/Dd4IEEuoM8x8sTOXb51URgjGe5Rv++v rTE8L3cW9I9Q
kERt1iSMSFQpAUY6HjKk9T948UwOlkmihiklkdVSMEuxP3QBnn8KbDcw3BYR SBiuMgdRn1/K
sWHw+66XqVnM8TveooaQZ5YRqhyPTK5/Gq8/hq9eXdFqLxr5zPtVsfLuYryQ fug4FAHT0UUU
gCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArkfiN/wAi5B/1 9r/6A9ddXI/E
b/kXIP8Ar7X/ANAemtxM39D/AORe0z/r0i/9AFX6oaH/AMi9pn/XpF/6AKv0 MAoqC7XdbMCp
YZGVAzkZGeO9IVszeQtaW3lYVt5FuY/THJAoGWKK5ye11eK9vZbRJn3glHeU ZBJHCgsV6Z4K
j696qJceJTGbMtIt1s3+aYPlz02bsbM7fmzn7xxQB1xOBk9KK566stWudKs0 kklacJKs6qUT
duRgu4ZI646Gmm18Qw3NtHDdM9qko3syxlmTCdenGfMHHPTrQB0dFYl5aaxL dzPBeyxRGQhE
Xy8BPK4PKk58z9KqpF4lm1FlkleC0YjLqYyVwf4eD1Geo/xoA6TI3BcjJ6Cl rkTp3iHzJrwS
BbswxIu0RnP3TJj3yD1OP0qw1t4ge4j82edol8l28oxpkjbvAGTnPzE5I9Bm gDpqM46nrWJf
W+sPfzPaTGKERM0YUJ88gC7Q2RnH3qZe6bf3OseYlxcJB5kbqysmI8I6ttBB OSSO3ekBvUVh
aXHr329jqMoEBgAAVUwH2rnBBznO/tjpVTZ4paE+ayggjAtym5hhv73HBCn6 MfSgDqMjOM80
Vzf2LXf7QtLp59+DMswXYNqF02hOPRcnPOM9DUNqfEYvLaGZpztwzsfKCsN4 yWxnHy7sBSec
Z9mB1VFc3py+I/NT7d5gi87JCNFuxhep6Fc7umG6Vf0JNWS2l/teQPKX+XCq ABjnGCeM9M4N
AGrRRRSAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooA
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACuR+I3/ACLkH/X2v/oD111c j8Rv+Rcg/wCv
tf8A0B6a3Ezf0P8A5F7TP+vSL/0AVfqhof8AyL2mf9ekX/oAq/QwEZlRSzEA DqTTVnjdtquC
fSiVS8RA68U0B2mVmTaFB7/SkMkDKSQGBI6gGlqAwMxPJHXvnvmlMJwV38Y9 Oe3+FMCaio0i
Kybi5PGOmO1MFuTu3PnPQY6df8f0pAT5Gcd+tFRrFtdmz1BHTnrTPs5woL8D rgUAT0mRnGea
jEJ3KzOSR1460NAGLngEkkcd8YoAloqIQkeZ85O/OPagwD5th25PHHbHSgCW kBBGR0qIW+Fx
v+bBGcfX/H9KPs4DZDYABGAMev8AjTAmoqOOLZnkElcZAx6/40JCE75yCD75 NIB4IPTmlqEW
4CABtpxjIHtil8k+UqbyCDnIoAloBBGRUIgyfmbPrx19fwoNucEBv4sjjp14 /WgCaioDAxVv
mAJOemfX/H9KUwEoRv75zjk/WgCaigDAAooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArkfiN /wAi5B/19r/6
A9ddXI/Eb/kXIP8Ar7X/ANAemtxM39D/AORe0z/r0i/9AFX6oaH/AMi9pn/X pF/6AKv0MAop
kjMoXaMnPI9utR+e6kBlGSenpQMnoqHzJGKjaBzzg9uD6e9Is7sF+QDccfe+ n+NAE9FQl3Mc
bDByMtg+1CStnaV6Lkkn2oAfJNHEQHbBPYAmmfa4f7zf98H/AApG/wCPtv8A cH8zTqQCfa4f
7zf98H/Cj7XD/eb/AL4P+FLRQAn2uH+83/fB/wAKPtcP95v++D/hS0UAJ9rh /vN/3wf8KPtc
P95v++D/AIUtFACfa4f7zf8AfB/wo+1w/wB5v++D/hS0UAJ9rh/vN/3wf8KP tcP95v8Avg/4
UtFACfa4f7zf98H/AAo+1w/3m/74P+FLRQAn2uH+83/fB/wo+1w/3m/74P8A hS0UAJ9rh/vN
/wB8H/Cj7XD/AHm/74P+FLRQAn2uH+83/fB/wo+1w/3m/wC+D/hS0UAJ9rh/ vN/3wf8ACj7X
D/eb/vg/4UtFACfa4f7zf98H/Cj7XD/eb/vg/wCFLRQAn2uH+83/AHwf8KPt cP8Aeb/vg/4U
tFACfa4f7zf98H/Cj7XD/eb/AL4P+FLRQAn2uH+83/fB/wAKPtcP95v++D/h S0UAJ9rh/vN/
3wf8KPtcP95v++D/AIUtFACfa4f7zf8AfB/wo+1w/wB5v++D/hS0UAJ9rh/v N/3wf8KPtcP9
5v8Avg/4UtFACfa4f7zf98H/AAo+1w/3m/74P+FLRQAn2uH+83/fB/wo+1w/ 3m/74P8AhS0U
AJ9rh/vN/wB8H/Cj7XD/AHm/74P+FLRQAn2uH+83/fB/wo+1w/3m/wC+D/hS 0UAJ9rh/vN/3
wf8AClW5iZgoY5PAypFFMl+6v++v/oQoAmLYbAVmI67VJxRuP/POX/vg0Rti ST6j+VNmndHA
U9R+dMB24/8APOX/AL4NG4/885f++DTTcOMfKMkZAzQLpiRhMAkDJP8An2os A7cf+ecv/fBo
3H/nnL/3waI7gupLDb+Oak3+9ADFYNnqCOoIwRXJfEb/AJFyD/r7X/0B66pD meX6j+Vcr8Rv
+Rcg/wCvtf8A0B6FuDN/Q/8AkXtM/wCvSL/0AVfqhof/ACL2mf8AXpF/6AKv EhRkkAe9DEBU
MMMoI9xmlACjCgAegGKKKQwoyaKOlABRmjOOtFAETxM0u9HAOMHK5/rSeXL/ AM9E/wC+D/jU
1FAEPly/89E/74P+NHly/wDPRP8Avg/409pY1kWNpFDvnapPJxycCn0AQ+XL /wA9E/74P+NH
ly/89E/74P8AjUnmR+aIt6+YV3bM849celOoAh8uX/non/fB/wAaPLl/56J/ 3wf8amooAh8u
X/non/fB/wAaPLl/56J/3wf8alVlcEqwYAkcHPI4NLQBD5cv/PRP++D/AI0e XL/z0T/vg/41
NRQBD5cv/PRP++D/AI0eXL/z0T/vg/41NRQBD5cv/PRP++D/AI0eXL/z0T/v g/41NRQBD5cv
/PRP++D/AI0eXL/z0T/vg/41NRQBD5cv/PRP++D/AI0eXL/z0T/vg/41NRQB D5cv/PRP++D/
AI0eXL/z0T/vg/41NRQBD5cv/PRP++D/AI0eXL/z0T/vg/41NRQBD5cv/PRP ++D/AI0eXL/z
0T/vg/41NRQBD5cv/PRP++D/AI0eXL/z0T/vg/41NRQBD5cv/PRP++D/AI0e XL/z0T/vg/41
0T/vg/41NRQBD5cv/PRP++D/AI0eS7Y3yLgEHhcdDn1qaigCGRJd5MbLg9d1 N23Q/ij/AFqx
RQBW8u4JyfJJ9SP/AK1Ltuv70f61YooAr7br+9H+tG25/vR/rViigCKGNk3F yCzHPHSuW+I3
/IuQf9fa/wDoD111cj8Rv+Rcg/6+1/8AQHprcTN/Q/8AkXtM/wCvSL/0AVZd UF1HJNCZogpG
3buweOcfmKraH/yL2mf9ekX/AKAKv0dQM3UI5RpFwIY3Dbt0cS8kDcCF4/yM 1lwprF7eC7iS
S1VrjdJDKxAC7EX2z91jjpz+I6aigZz9rZa8mgXME14jX7MDHJzgD5cjrnnD fTPamx2GvZg8
28Vo18vepbkkOCWzg8bQRjPXnNdFRQBy9rpOsrKklxOXkACbjOT8okRskdCS A36dOghvrTXb
LTkWO5ubiRowv7uRi3nFQN2Qp+XIPBwOe1ddRQBkXunXtzqQlS8mit8oCkcp X5cNu/Ekrz7d
qzl0/wARyXaCW7VYDHEsjJKQxIMZYjsMgSdAOo59OoooA5WTRNZM0k63g89I 5I4XMh+6THjO
MZJVG59SDSy6VrkyxrLctIgjjLgTlDuWQNgY9QMZOfrXU0UAY1zpVxNri3kc 8kcTJEkgWUjK
r5pIx9WT9apLpeuyQOsl/JG4ifYVnzmXC7WPH3chjt7ZrpqKAMaey1VbBobS 82zCc+XJK24+
WRjnjkjJI+gqn/Z/iBz895tZ1JZkl+VcjlQMdQx4b0GK6WikBy50nW4IbiO3 ucg3DSQjzSAF
LMcN3J5BJz7duW/ZPEM1tdGKVkZ522CWY52h3wRjBUY2cZ5xn69VRTA5qWx8 QPZOougLoshZ
xIdrKByFAxtOe+ea6G3WRbaJZm3yhAHb1bHJqSikAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABXI/Eb/kXIP8Ar7X/ANAeuurkfiN/yLkH/X2v/oD01uJm/of/ACL2mf8A XpF/6AKv1Q0P
/kXtM/69Iv8A0AVfoYCMwXGTjJwPrSB1PRh1xQ6BwA3T/wCtUbW+WGDhRjjN IZIZFGOQcnA5
pdy/3h+dMEKBgRnjp+Q/wpFt1UKAW4PXPXp/hTAcZEwpBBDdMU4MpA56jP4U 3ywUVSTwMZpB
CoYsCc4xz9MUAMlLtPsWQoAoPAHOSfX6U3ZJ/wA/En5L/hSysqXRZiFBQAEn 3NHnRf8APVP+
+hSATZJ/z8Sfkv8AhRsk/wCfiT8l/wAKXzov+eqf99Cjzov+eqf99CgBNkn/ AD8Sfkv+FGyT
/n4k/Jf8KXzov+eqf99Cjzov+eqf99CgBNkn/PxJ+S/4UbJP+fiT8l/wpfOi /wCeqf8AfQo8
6L/nqn/fQoATZJ/z8Sfkv+FGyT/n4k/Jf8KXzov+eqf99Cjzov8Anqn/AH0K AE2Sf8/En5L/
AIUbJP8An4k/Jf8ACl86L/nqn/fQo86L/nqn/fQoATZJ/wA/En5L/hRsk/5+ JPyX/Cl86L/n
qn/fQo86L/nqn/fQoATZJ/z8Sfkv+FGyT/n4k/Jf8KXzov8Anqn/AH0KPOi/ 56p/30KAE2Sf
8/En5L/hRsk/5+JPyX/Cl86L/nqn/fQo86L/AJ6p/wB9CgBNkn/PxJ+S/wCF GyT/AJ+JPyX/
AApfOi/56p/30KPOi/56p/30KAE2Sf8APxJ+S/4UbJP+fiT8l/wpfOi/56p/ 30KPOi/56p/3
0KAE2Sf8/En5L/hRsk/5+JPyX/Cl86L/AJ6p/wB9Cjzov+eqf99CgBNkn/Px J+S/4UbJP+fi
T8l/wpfOi/56p/30KPOi/wCeqf8AfQoATZJ/z8Sfkv8AhRsk/wCfiT8l/wAK Xzov+eqf99Cj
zov+eqf99CgBNkn/AD8Sfkv+FGyT/n4k/Jf8KXzov+eqf99Cjzov+eqf99Cg BNkn/PxJ+S/4
UbJP+fiT8l/wpfOi/wCeqf8AfQo86L/nqn/fQoATZJ/z8Sfkv+FGyT/n4k/J f8KXzov+eqf9
9Cjzov8Anqn/AH0KAE2Sf8/En5L/AIUbJP8An4k/Jf8ACl86L/nqn/fQo86L /nqn/fQoATZJ
/wA/En5L/hRsk/5+JPyX/Cl86L/nqn/fQo86L/nqn/fQoATZJ/z8Sfkv+FGy T/n4k/Jf8KXz
ov8Anqn/AH0KPOi/56p/30KAE2Sf8/En5L/hRsk/5+JPyX/Cl86L/nqn/fQo 86L/AJ6p/wB9
CgBNkn/PxJ+S/wCFGyT/AJ+JPyX/AApfOi/56p/30KPOi/56p/30KAE2Sf8A PxJ+S/4Uh8yP
a3nOw3AYIHc47CnedF/z1T/voU15EcKqOrHevAOe4oAsKod33FuMAYOKGWFD gtJ/30ajaZIZ
HDsFyQRn6VHJNBIwJlXpimBZ2Q/32/7+Gjy4geWf/v4aqmW3Ix5i4AxjI5pq SQLgmYZBzkH/
AD/k0AXRFEejOf8AgZo8mP1k/wC+zVVJoI1IWYfXOaf9rh/56j86AJE4kkQE kKRjJz2rlPiN
/wAi5B/19r/6A9dRA4keVlOQSOfwrl/iN/yLkH/X2v8A6A9CBm/of/IvaZ/1 6Rf+gCr9UND/
AORe0z/r0i/9AFX6GIKKKKQwooooAKKKKAClz70lFAC596M+9JRQAufejPvS UUALn3oz70lF
AC596M+9JRQAufejPvSUUALn3oz70lFAC596M+9JRQAufejPvSUUALn3oz70 lFAC596M+9JR
QAufejPvSUUALn3oz70lFAC596M+9JRQAufejPvSUUALn3oz70lFAC596M+9 JRQAufejPvSU
UALn3oz70lFAC596M+9JRQAufejPvSUUALn3oz70lFAC596TNFFAAQD1ANJt X0H5UtFACbV9
B+VG1fQflS0UAJtHoPyo2r6D8qWigA6dK5H4jf8AIuQf9fa/+gPXXVyPxG/5 FyD/AK+1/wDQ
HprcTN/Q/wDkXtM/69Iv/QBV+qGh/wDIvaZ/16Rf+gCsLz/ENvaSC3hkml8x Q0s4IyMNnCYJ
HIXOMjnjGKAOsorm0n1q41xIprVks45twcDHQMPxByD1P4dKnurvWEW4MUT7 lnKqFg3AJhtp
HPzZIXPpk0DN2iuceTX2lt2kJjjaYmRYogSihwAM5OQVJOfao47rxNIk26GK JkLMoCFs4UkL
zjgnbyM9TzQB09Fc/bTa1HcW0coeWNriYTFosFV3nZg9Mbcf/XxityAu1vE0 md5QFsrtOcc8
c4pASUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
XI/Eb/kXIP8Ar7X/ANAeuurkfiN/yLkH/X2v/oD01uJm/of/ACL2mf8AXpF/ 6AKv1Q0P/kXt
M/69Iv8A0AVbKtNdpAJTErKW3ADJxjgZ470dQJKKpXVxNDptzJE8TSRbgsj8 KcdzWNB4mn82
zhNsZxOxDTZVB97Hy4JD468HpQM6aiua0rxBcatcs0cIjWOKb5d25XYeUVOc ZH3yMfWorfxD
qKQNdS2sdxG0akLC5yH8kuQBjplSOvU0AdVRWB/wkEv9kWl+1sFMsro0auH3 BUcjaR3JUfnV
Jdd1oSW8c1oI5IyftY8sYC70w33uBtbtnkUAdZRRRSAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKAGlwDjDE/7Kk/yo8wf3ZP+/bf4URtteTnuP5Usk7KwAdV 4J+b2x/jTATz
B/dk/wC/bf4UeYP7sn/ftv8ACm/a2JwFweM7jjGcf40fayzFV6hgM/n/AIUW Ad5g/uyf9+2/
wo8wf3ZP+/bf4UsdwHUknHOMZqTzM9DRYCNWDZxnjqCMVyXxG/5FyD/r7X/0 B66pTmeU+4/l
XK/Eb/kXIP8Ar7X/ANAehbgzf0P/AJF7TP8Ar0i/9AFXXjSVdsiK6+jDIqlo f/IvaZ/16Rf+
gCp7q7W2HIycFjk4AA7mjd2Qr2WpOAFAAAAHQClqrLfxQ2El44bZGpZlXk8f pVeLXbGQQb5P
Kec4RSQ2ecdVJXk8DnrxQM0qKz7fWbW7u1gt2LjZIzsQVKlSnBBGeQ4OaSPX dOlWFkuCVmOE
PlsM8gA9OASQATwc8UgLU9pHcTQSuWDwMWQj3GD+hqesuLxHpUo3LckLt3bn idRjbuzkgD7o
J9wDUp1mwFml35zGJ38tcRsWLc8bcZzwe1AF+is9tb05XKm45CCQYRjuBxjb x833l4GeoqOP
XrJmuldmU27AMFRmOCAQSAMjOenXg0AalFZreINLU83QxsDghGIIIB4OME/M vHXkVLa6tY3s
wht5/McpvwEbAHucYB9utAF2iiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKpPq1nHdS2zyESxF AwKn+MgDHryw
z6ZFAF2isq48R6ZBG7LcpKViklwhzkIAW56dGFStrmmIoZr2BUOMMXGCfm49 f4G/I+hoA0KK
rR6hZyzyQR3UTSxDc6hhlR6mmJq2nyeVtvIT53+r+cfN9KALlFZx1zT/ADFA uYzGUdjKGG1S
pQYPud4p66vZvfw2cUySyyqXARgcLgHP5EfnQBYkWYOTGEIPXccU3/Sv7sX/ AH0f8KWOGO4u
Z/OBbYVCjcRjjPaorx9PspI43t5neRWcCIOxCrjJ4P8AtCnYLkn+lf3Yv++j /hRi6znbFn/e
P+FVZdQ0CJQWuIzkpgLIxPzkBeM/7S/nS3F5o8CttKyujhGRJTkE59/Y/kfS iwXLP+lf3Yv+
+j/hR/pX92L/AL6P+FLbJpl5GZLYrKgO0skjEZ/Op/sNp/zyP/fbf40WC5FC jqXaTbuY9F+l
ct8Rv+Rcg/6+1/8AQHrp4VEdzcRJnYpXaCScZHvXMfEb/kXIP+vtf/QHoW4m b+h/8i9pn/Xp
F/6AKnurOK7XbIO2DkAgj3BqDQ/+Re0z/r0i/wDQBV+i9ndBuiH7Mn2ZoMvt YEEq20/mMY/C
qQ8PaYJopvIYyxsWDtIxYknPJzz+NadFAzO07QtO0pi1nAY2O4El2PUKD1P+ wv5U2Pw9psRQ
pC42vv8A9a3zHIPPPPIB59K06KAKDaLp7wCF7cNHtC7SxxgIUx1/ukiqt5oi jT7W1sYwEgm8
3a1w8Z6MPvgE9WrZooAxovDWm+Z9oe0Edw0YRvLmchcbcbTx02LzgdKll8O6 ZP5u+BiZipkP
msC5XGCeeSMdfr61qUUAYX/CKWH2gZB+yLCIlt9zY4CgHOeoCLzjPHWr9vo9 la3EU8UbCSKM
xIS7HC9+CavUUAFFFFIAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKoXWjWl3J5koff5yTZDY+ZcYH0+ UZFX6KAMhPDl
kiFRJOQY2iOXByhVV29OgCrjvx1PNStoVk9xLORJvlzu+bjkOP8A2dq0qKYG RZaJ9k1Ke488
tA0bJHD/AHNx3Mc+55pkfhbTY5IJArl4TlSdvrkDpxg8/LitqigDATwfpaQv GRK+5i2WKnn5
OcYwf9WvUevrV210O1s7qOeFpV8tdqx5GwfKq5xjrhQPTjpWlRQBV+0x2tzN 5pK7yCpx14xV
W9ezvJYpftk8LxqyZhIBKtjI5B/ujpg1qUZoA5WLSLCLUZLhLmKOJtu1IrfD ptKlfnJOfuL2
xx0qddJ0UXUtwZZmklkEjEt3G/Hbn77dfb0ro80ZoAx7RNPsY5EguplEjlyA QOTgcADHb+fr
V6PUbWNdvnM3JOW5PJzVrNGaAKtq4mnuJVzsZl2kjrgVzfxG/wCRcg/6+1/9 AeuurkfiN/yL
kH/X2v8A6A9C3EzEuv7SvtZ8N6RZ6tc2EU+lRuxhY4yFJzjI9MV1mg6Ff6Tc SyXeu3Woq6bV
SYHCnPUcmsvT9Du59Z8Oa0hi+y2+lpE4LHdkoegx/tCrH/CWtbWryXUKyS71 Xy4BkLkMfvAs
D904PHuBWEKfvyk+562KxlsPTo0mrcqvor3u+tr9uo7VfDGqahqc11b+Jr2z ifG2CMHamABx
8w64z+NWtB0K/wBJuJZLvXbrUVdNqpMDhTnqOTVaPxWsU7W81vLIw89yyr0V Xk2gcYPEeOvc
VettXuLia6TyLfEVss0eyffuJLDHA6fL1q1Sipc3X1OaWPrypexbXLa3wx/O 1/xKGq+GNU1D
U5rq38TXtnFJjbBEDtTAA4+YdcZ/GrWg6Ff6TcSyXeu3Woq6bVSYHCnPUcmq sXieeKGS5urU
NAVUqYH3YbyfMKjjJHDc/Sr6a8r6Vb3og2maUxBZH2KCN3JYjgfKcZHcetCp RT5glj68qXsW
1y2t8Mfztf8AEoar4Y1TUNTmurfxNe2cUmNsEYO1MADj5h1xn8ataDoV/pNx LJd67dairptV
JgcKc9RyarDxWsFwbWWLzZi0+3acfcMhA6Y+7H1z+FXNP8Qx395BbiEL50Rk DbyeQSCAMDpj
vj6UKlFPmCWPrypexbXLa3wx/O1/xKWq+GNU1DU5rq38TXtnFJjbBEDtTAA4 +YdcZ/GrWg6F
f6TcSyXeu3Woq6bVSYHCnPUcmo116e91K2tbaIIpuNsrGQElNsnGMHBzH09M c88N/t+8W7Xf
bRGFWuFkVJckBJURW5HXDE4/WhUoqXN1CWPrypexbXLa3wx/O1/xI9V8Mapq GpzXVv4mvbOK
TG2CMHamABx8w64z+NWtB0K/0m4lku9dutRV02qkwOFOeo5NOsvEkN5YXt35 DxJajcd+Rkc+
o4PHPX8aox+NIJELi1yqxl2Hm4bIaRcBSASMxnnjGRxQqUebm6hLH15UvYtr ltb4Y/na/wCI
7VfDGqahqc11b+Jr2zikxtgjB2pgAcfMOuM/jVrQdCv9JuJZLvXbrUVdNqpM DhTnqOTVU+Ki
J1cxfugj7kjcOCVQvw3fgY+tLqPi0WQESQRPcvA8ihZiybgrtjcFxjCH39qF Sipc3X1CWPry
pexbXLa3wx/O1/xE1XwxqmoanNdW/ia9s4pMbYIwdqYAHHzDrjP41a0HQr/S biWS71261FXT
aqTA4U56jk02TxMkM7RPAGKsAxWQd+Bt/vc9fQc1N/b+zSLm+mtGRoGRTGrb 87gpByB/tjPH
GD1oVKKlzdfUJY+vKl7FtctrfDH87X/Eo6r4Y1TUNTmurfxNe2cUmNsEYO1M ADj5h1xn8ata
DoV/pNxLJd67dairptVJgcKc9RyarTeK5fsbXENhx91TLLtG/ZvwRjIGAefp x6XBr7CZUezY
CWZoIWSTdvdTgjpwMZOfRTR7KKlzdQlj68qXsW1y2t8Mfztf8SlqvhjVNQ1O a6t/E17ZxSY2
wRg7UwAOPmHXGfxq1oOhX+k3Esl3rt1qKuu1UmBwpz1HJpbnxJHa391bGAN5 BC5EoySVRskf
wr84+Y+hqD/hKclilmXCRPNJiQYVUOGIP8Xt0zQqUU+br6hLH15UvYtrltb4 Y/na/wCJHqvh
jVNQ1Oa6t/E17ZxSY2wRg7UwAOPmHXGfxq1oOhX+k3Esl3rt1qKum1UmBwpz 1HJq5pWoSX1v
E80cKSOHJWOXdja2PQH/AArRoVKKlzdQlj68qXsW1y2t8Mfztf8AE5jVfDGq X+pTXVv4nvbO
KQjbBGDtTAA4+Yemfxq1oOhX+k3Esl3rt1qKum1UmBwpz1HJrdooVKKlzdQl j68qXsW1y2t8
Mfztf8TmNV8Mapf6lNdW/ie9s4pCNsEYO1MADj5h6Z/GrWg6Ff6TcSyXeu3W oq6bVSYHCnPU
cmt2ihUoqXN1CWPrypexbXLa3wx/O1/xOY1Xwxql/qU11b+J72zikI2wRg7U wAOPmHpn8ata
DoV/pNxLJd67dairptVJgcKc9Rya3aKFSipc3UJY+vKl7FtctrfDH87X/E5j VfDGqX+pTXVv
4nvbOKQjbBGDtTAA4+Yemfxq1oOhX+k3Esl3rt1qKum1UmBwpz1HJrdooVKK lzdQlj68qXsW
1y2t8Mfztf8AE5jVfDGqX+pTXVv4nvbOKQjbBGDtTAA4+Yemfxq1oOhX+k3E sl3rt1qKum1U
mBwpz1HJrdooVKKlzdQlj68qXsW1y2t8Mfztf8TmNV8Mapf6lNdW/ie9s4pC NsEYO1MADj5h
6Z/GrWg6Ff6TcSyXeu3Woq6bVSYHCnPUcmt2ihUoqXN1CWPrypexbXLa3wx/ O1/xOY1Xwxql
/qU11b+J72zikI2wRg7UwAOPmHpn8ataDoV/pNxLJd67dairptVJgcKc9Rya 3aKFSipc3UJY
+vKl7FtctrfDH87X/E5jVfDGqX+pTXVv4nvbOKQjbBGDtTAA4+Yemfxq1oOh X+k3Esl3rt1q
Kum1UmBwpz1HJrdooVKKlzdQlj68qXsW1y2t8Mfztf8AE5jVfDGqX+pTXVv4 nvbOKQjbBGDt
TAA4+Yemfxq1oOhX+k3Esl3rt1qKum1UmBwpz1HJrdooVKKlzdQlj68qXsW1 y2t8Mfztf8Tm
NV8Mapf6lNdW/ie9s4pCNsEYO1MADj5h6Z/GrWg6Ff6TcSyXeu3Woq6bVSYH CnPUcmt2ihUo
qXN1CWPrypexbXLa3wx/O1/xOY1Xwxql/qU11b+J72zikI2wRg7UwAOPmHpn 8ataDoV/pNxL
Jd67dairptVJgcKc9Rya3aKFSipc3UJY+vKl7FtctrfDH87X/E5jVfDGqX+p TXVv4nvbOKQj
bBGDtTAA4+Yemfxq1oOhX+k3Esl3rt1qKum1UmBwpz1HJrdooVKKlzdQlj68 qXsW1y2t8Mfz
tf8AE5jVfDGqX+pTXVv4nvbOKQjbBGDtTAA4+Yemfxq1oOhX+k3Esl3rt1qK um1UmBwpz1HJ
rdooVKKlzdQlj68qXsW1y2t8Mfztf8TmNV8Mapf6lNdW/ie9s4pCNsEYO1MA Dj5h6Z/GrWg6
Ff6TPLJd67dairqFVJgcIc9Rya3aKFSipc3UJY+vKl7Ftcu3wx/O1/xOY1Xw xql/qU11b+J7
2zikI2wRg7UwAOPmHpn8ataDoV/pM8sl3rt1qKuoVUmBwhz1HJrdooVKKlzd Qlj68qXsW1y7
fDH87X/E5jVfDGqX+pTXVv4nvbOKQjbBGDtTAA4+Yemfxq1oOhX+kzyyXeu3 Woq6hVSYHCHP
Ucmt2ihUoqXN1CWPrypexbXLt8Mfztf8TmNV8Mapf6lNdW/ie9s4pCNsEYO1 MADj5h6Z/GrW
g6Ff6TPLJd67dairqFVJgcIc9Rya3aKFSipc3UJY+vKl7Ftcu3wx/O1/xOY1 Xwxql/qU11b+
J72zikI2wRg7UwAOPmHpn8ataDoV/pM8sl3rt1qKuoVUmBwhz1HJrdooVKKl zdQlj68qXsW1
y7fDH87X/E5jVfDGqX+pTXVv4nvbOKQjbBGDtTAA4+Yemfxq1oOhX+kzyyXe u3Woq6hVSYHC
HPUcmt2ihUoqXN1CWPrypexbXLt8Mfztf8Th/GWlaxb29/rNlr19GqhSlnFn A+6pwQfqelM8
XPJJ4B0h5mZpWaEuW6lvKbOfeut1nVItF0mfUZ0d4oQCypjJyQOM/WuY8dXK 3vg+wukBVJ54
5FDdQDGx5/OiEVGo7MutXq1cJBTirJ2UrJdFpoum933F0/WbyHXvDWkI6izn 0tJHXbyWCHv+
ArsfIh2lfKTaTkjaME+tcjp2h3c+teG9aRovstvpaROCx3ZKHoMf7Qrb1DxF Y6bNcwziXfBG
spCrneCcYXnkjqfY0Q5ryv3IxbpctL2dvhV7d7vfztY1PLTcG2LuGcHHIzQs cafdRV4xwMcV
ny69p0Turz4MbbXBRgRwxGBjn7p6elTf2pZ/ZY7nzW8uRzGuI23FhnI24zkY OeOMGtDjLQjj
VdoRQPQCjyo/L8vy12f3ccflWYviCxCE3EnkMPMJBViMITnnGM4UnHWp49Xs ZZDGkrFxH5pH
lPkL78dfbrSAtmKMtuMabumdopVjjUgrGoIGAQOg9KSG2ju7+VJgzKkSFQGI wSWz0+gq1/ZF
l/zyb/v43+NOwFYIikkIoJOSQO/rRsQEkIuT1461Z/siy/55N/38b/Gj+yLL /nk3/fxv8afK
xXKwjjAYBFAb72B1+tQPp1nIZS1umZYvJfAxlOePb7zdPWtD+yLL/nk3/fxv 8aP7Isv+eTf9
/G/xo5WFyqsUSKFWNQB0AHSjyIeP3ScDA+UcD0q1/ZFl/wA8m/7+N/jR/ZFl /wA8m/7+N/jR
ysLlXyo+P3a/L046U4qpBBUYPUY61Y/siy/55N/38b/Gj+yLL/nk3/fxv8aX KwuVvLj27di7
fTHHpUZtYWnjmKfPECE5OFz146Z9+tXf7Isv+eTf9/G/xo/siy/55N/38b/G nysLlNLWBJJp
FiXfMcyHH3uAP5AU8RoBgIoGMdO3pVn+yLL/AJ5N/wB/G/xo/siy/wCeTf8A fxv8aOVhcrqi
r91QPoKWp/7Isv8Ank3/AH8b/Gj+yLL/AJ5N/wB/G/xo5WFyCip/7Isv+eTf 9/G/xo/siy/5
5N/38b/GjlYXIKKn/siy/wCeTf8Afxv8aP7Isv8Ank3/AH8b/GjlYXIKKn/s iy/55N/38b/G
j+yLL/nk3/fxv8aOVhcgoqf+yLL/AJ5N/wB/G/xo/siy/wCeTf8Afxv8aOVh cgoqf+yLL/nk
3/fxv8aP7Isv+eTf9/G/xo5WFyCip/7Isv8Ank3/AH8b/Gj+yLL/AJ5N/wB/ G/xo5WFyCip/
7Isv+eTf9/G/xo/siy/55N/38b/GjlYXIKKn/siy/wCeTf8Afxv8aP7Isv8A nk3/AH8b/Gjl
YXIKKn/siy/55N/38b/Gj+yLL/nk3/fxv8aOVhcgoqf+yLL/AJ5N/wB/G/xo /siy/wCeTf8A
fxv8aOVhcgoqf+yLL/nk3/fxv8aP7Isv+eTf9/G/xo5WFyCip/7Isv8Ank3/ AH8b/Gj+yLL/
AJ5N/wB/G/xo5WFyCip/7Isv+eTf9/G/xo/siy/55N/38b/GjlYXIKKn/siy /wCeTf8Afxv8
aP7Isv8Ank3/AH8b/GjlYXIKKn/siy/55N/38b/Gj+yLL/nk3/fxv8aOVhcg oqf+yLL/AJ5N
/wB/G/xqveafb2sAmhVlcSIAfMY9WAPU+hpWC4tFQRQQT3NwZ4Y5dpULvUNg Y7Zqlqmo6NpF
xDDcWMJaVSwKpEOAQOjEEnkcKCaLDNSis06l4eAyY4AvPJtSBwcddvTIIHqR gZp32/w95yRK
to7u21RHBu5yR2Hqp/KiwrmhRVWyk0bUPM+yw2snlnDYhA+hGRyPccVa+w2P /Pnbf9+l/wAK
LDOd8do8ngrUkjUuxVMBRkn51rD8VKV+HmiqwIIMAIPb901dRqepW+gWeoXr wsbe3KHy4gB1
wOBwO9YHjq5W98H2F0gKpPPHIobqAY2PP51CS9pe+tjslOf1JQ5fd5m7+dlo Lp+s3kGveGtI
R1FpPpaSOu3ksEPf8BW9f6DHf3EsrTsvmpsI8tGwNpU4JGRkE9PWsTTtDu59 a8N60jRfZbfS
0icFjuyUPQY/2hXY0oc15X7hi3S5aXs7fCr273e/naxkx+GtKimkmW3PmSOJ GYyNyw3YPX/b
b86tyabayQrGVZQsrTKUdlIdiSSCDnnc351borQ4zKbw3pbXX2k27CYBgGEr DG4MD39GP50+
HQtPt3R4onVo4jEhErfKpOTjnr71pUUANhl+zXssro7I8aqCgzyC3+NWv7Th /wCec/8A37NV
6KLiLH9pw/8APOf/AL9mj+04f+ec/wD37NV6Kd2Fix/acP8Azzn/AO/Zo/tO H/nnP/37NV6K
LsLFj+04f+ec/wD37NH9pw/885/+/ZqvRRdhYsf2nD/zzn/79mj+04f+ec// AH7NV6KLsLFj
+04f+ec//fs0f2nD/wA85/8Av2ar0UXYWLH9pw/885/+/Zo/tOH/AJ5z/wDf s1XoouwsWP7T
h/55z/8Afs0f2nD/AM85/wDv2ar0UXYWLH9pw/8APOf/AL9mj+04f+ec/wD3 7NV6KLsLFj+0
4f8AnnP/AN+zR/acP/POf/v2ar0UXYWLH9pw/wDPOf8A79mj+04f+ec//fs1 XoouwsWP7Th/
55z/APfs0f2nD/zzn/79mq9FF2Fix/acP/POf/v2aP7Th/55z/8Afs1Xoouw sWP7Th/55z/9
+zR/acP/ADzn/wC/ZqvRRdhYsf2nD/zzn/79mj+04f8AnnP/AN+zVeii7CxY /tOH/nnP/wB+
zR/acP8Azzn/AO/ZqvRRdhYsf2nD/wA85/8Av2aP7Th/55z/APfs1XoouwsW P7Th/wCec/8A
37NH9pw/885/+/ZqvRRdhYsf2nD/AM85/wDv2aP7Th/55z/9+zVeii7CxY/t OH/nnP8A9+zR
/acP/POf/v2ar0UXYWLH9pw/885/+/Zo/tOH/nnP/wB+zVeii7CxY/tOH/nn P/37NH9pw/8A
POf/AL9mq9FF2Fix/acP/POf/v2aP7Th/wCec/8A37NV6KLsLFj+04f+ec// AH7NQXl2t1AI
o45dxdDlkwAAwJ/lSUUrhYq+f9muZi0crByCCkbN2x2FVL2Oxv5FkuLe9JVS mFSVQykgkEDq
OB1rVooGY7W2mu0RazusRgAL5cuCASRkdDgkkZ6VRl0XTSkSW0V7bIkiyFUh c7yoAXOQemP1
JrpqKAMa2tdNs45I7a0vIkdixCJKOoI7dOCfpwewq9HfRxghYbs5JPMMh6nP cVbooA5Txksl
z4Q1l0hk/eCPYpQhjhl7dazPFSlfh5oqsCCDACD2/dNXYazqsWi6TPqM6O8U IBZUxk5IHGfr
XMeOrlb3wfYXSAqk88cihuoBjY8/nURS9pe+tjslOf1JQ5fd5m7+dloLp+s3 kGveGtIR1FpP
paSOu3ksEPf8BXaVx1hoF3c6r4b1uKaJYLbTo4pEbO5soenGP4hWpr1r4kuJ 4jomoWtrEFIk
WZNxJz1HymoTlHmbV9TWpTo1XSjTko+7q3te73snraxu0Vy+l2PjCLUoX1LV rGezBPmRxxYZ
uDjB2jvirevWviS4niOiaha2sQUiRZk3EnPUfKarnfLezMnhIqqqftY69bu3 5X/A3aK5fS7H
xhFqUL6lq1jPZgnzI44sM3Bxg7R3xVvXrXxJcTxHRNQtbWIKRIsybiTnqPlN HO+W9mDwkVVV
P2sdet3b8r/gbtFcvpdj4wi1KF9S1axnswT5kccWGbg4wdo74q3r1r4kuJ4j omoWtrEFIkWZ
NxJz1HymjnfLezB4SKqqn7WOvW7t+V/wN2iuX0ux8YRalC+patYz2YJ8yOOL DNwcYO0d8Vb1
618SXE8R0TULW1iCkSLMm4k56j5TRzvlvZg8JFVVT9rHXrd2/K/4G7RXL6XY +MItShfUtWsZ
7ME+ZHHFhm4OMHaO+Kt69a+JLieI6JqFraxBSJFmTcSc9R8po53y3sweEiqq p+1jr1u7flf8
Ddorl9LsfGEWpQvqWrWM9mCfMjjiwzcHGDtHfFW9etfElxPEdE1C1tYgpEiz JuJOeo+U0c75
b2YPCRVVU/ax163dvyv+Bu0Vy+l2PjCLUoX1LVrGezBPmRxxYZuDjB2jvire vWviS4niOiah
a2sQUiRZk3EnPUfKaOd8t7MHhIqqqftY69bu35X/AAN2iuX0ux8YRalC+pat Yz2YJ8yOOLDN
wcYO0d8Vb1618SXE8R0TULW1iCkSLMm4k56j5TRzvlvZg8JFVVT9rHXrd2/K /wCBu0Vy+l2P
jCLUoX1LVrGezBPmRxxYZuDjB2jvirevWviS4niOiaha2sQUiRZk3EnPUfKa Od8t7MHhIqqq
ftY69bu35X/A3aK5jSrHxhFqUL6nq1lPZgnzI44sM3Bxg7R3xVrXrXxJcTxH RNQtbWIKRIsy
biTnqPlNHO+W9mDwkVVVP2sdet3b02v+Bu0VzGlWPjCLUoX1PVrKezBPmRxx YZuDjB2jvirW
vWviS4niOiaha2sQUiRZk3EnPUfKaOd8t7MHhIqqqftY69bu3ptf8DdormNK sfGEWpQvqerW
U9mCfMjjiwzcHGDtHfFWtetfElxPEdE1C1tYgpEizJuJOeo+U0c75b2YPCRV VU/ax163dvTa
/wCBu0VzGlWPjCLUoX1PVrKezBPmRxxYZuDjB2jvirWvWviS4niOiaha2sQU iRZk3EnPUfKa
Od8t7MHhIqqqftY69bu3ptf8DdormNKsfGEWpQvqerWU9mCfMjjiwzcHGDtH fFWtetfElxPE
dE1C1tYgpEizJuJOeo+U0c75b2YPCRVVU/ax163dvTa/4G7RXMaVY+MItShf U9Wsp7ME+ZHH
Fhm4OMHaO+Kta9a+JLieI6JqFraxBSJFmTcSc9R8po53y3sweEiqqp+1jr1u 7em1/wADdorm
NKsfGEWpQvqerWU9mCfMjjiwzcHGDtHfFWtetfElxPEdE1C1tYgpEizJuJOe o+U0c75b2YPC
RVVU/ax163dvTa/4G7RXMaVY+MItShfU9Wsp7ME+ZHHFhm4OMHaO+Kta9a+J LieI6JqFraxB
SJFmTcSc9R8po53y3sweEiqqp+1jr1u7em1/wN2iuY0qx8YRalC+p6tZT2YJ 8yOOLDNwcYO0
d8Va1618SXE8R0TULW1iCkSLMm4k56j5TRzvlvZg8JFVVT9rHXrd29Nr/gbt FcxpVj4wi1KF
9T1aynswT5kccWGbg4wdo74q1r1r4kuJ4jomoWtrEFIkWZNxJz1HymjnfLez B4SKqqn7WOvW
7t6bX/A3aK5jSrHxhFqUL6nq1lPZgnzI44sM3Bxg7R3xVrXrXxJcTxHRNQtb WIKRIsybiTnq
PlNHO+W9mDwkVVVP2sdet3b02v8AgbtFcxpVj4wi1KF9T1aynswT5kccWGbg 4wdo74q1r1r4
kuJ4jomoWtrEFIkWZNxJz1HymjnfLezB4SKqqn7WOvW7t6bX/A3aK5jSrHxh FqUL6nq1lPZg
nzI44sM3Bxg7R3xVrXrXxJcTxHRNQtbWIKRIsybiTnqPlNHO+W9mDwkVVVP2 sdet3b02v+Bu
0VzGlWPjCLUoX1PVrKezBPmRxxYZuDjB2jvirWvWviS4niOiaha2sQUiRZk3 EnPUfKaOd8t7
MHhIqqqftY69bu3ptf8AA3aK5jSrHxhFqUL6nq1lPZgnzI44sM3Bxg7R3xVr XrXxJcTxHRNQ
tbWIKRIsybiTnqPlNHO+W9mDwkVVVP2sdet3b02v+Bu0VzGlWPjCLUoX1PVr KezBPmRxxYZu
DjB2jvirWvWviS4niOiaha2sQUiRZk3EnPUfKaOd8t7MHhIqqqftY69bu3pt f8DdormNKsfG
EWpQvqerWU9mCfMjjiwzcHGDtHfFWtetfElxPEdE1C1tYgpEizJuJOeo+U0c 75b2YPCRVVU/
ax163dvTa/4G7RXMaVY+MItShfU9Wsp7ME+ZHHFhm4OMHaO+Kta9a+JLieI6 JqFraxBSJFmT
cSc9R8po53y3sweEiqqp+1jr1u7em1/wN2iuY0qx8YRalC+p6tZT2YJ8yOOL DNwcYO0d8Va1
618SXE8R0TULW1iCkSLMm4k56j5TRzvlvZg8JFVVT9rHXrd29Nr/AIG7RXMa VY+MItShfU9W
sp7ME+ZHHFhm4OMHaO+Kta9a+JLieI6JqFraxBSJFmTcSc9R8po53y3sweEi qqp+1jr1u7em
1/wIvHaPJ4K1JEVmYqmAoyT861h+KlK/DzRVYEEGAEHt+6atfSrHxhFqUL6n q1lPZgnzI44s
M3Bxg7R3xUHxG/5FyD/r7X/0B6Ka5p89rdC8TJUqCwykpauV031SVtUuxv6H /wAi9pn/AF6R
f+gCr9UND/5F7TP+vSL/ANAFX60Z54UUUUhhRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVyPxG/5FyD/AK+1/wDQ Hrrq5H4jf8i5
B/19r/6A9NbiZv6H/wAi9pn/AF6Rf+gCr9UND/5F7TP+vSL/ANAFX6GAUUUU hhRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAVyPxG
/wCRcg/6+1/9AeuurkfiN/yLkH/X2v8A6A9NbiZvaI6jw/pgLAH7JF3/ANgV e8xP76/nVHQw
D4f0zIH/AB6Rf+gCr+0egoYCeYn99fzo8xP76/nS7R6CjaPQUhieYn99fzo8 xP76/nS7R6Cj
aPQUAJ5if31/OjzE/vr+dLtHoKNo9BQAnmJ/fX86PMT++v50u0ego2j0FACe Yn99fzo8xP76
/nS7R6CjaPQUAJ5if31/OjzE/vr+dLtHoKNo9BQAnmJ/fX86PMT++v50u0eg o2j0FACeYn99
fzo8xP76/nS7R6CjaPQUAJ5if31/OjzE/vr+dLtHoKNo9BQAnmJ/fX86PMT+ +v50u0ego2j0
FACeYn99fzo8xP76/nS7R6CjaPQUAJ5if31/OjzE/vr+dLtHoKNo9BQAnmJ/ fX86PMT++v50
u0ego2j0FACeYn99fzo8xP76/nS7R6CjaPQUAJ5if31/OjzE/vr+dLtHoKNo 9BQAnmJ/fX86
PMT++v50u0ego2j0FACeYn99fzo8xP76/nS7R6CjaPQUAJ5if31/OjzE/vr+ dLhfQUYX0FAC
eYn99fzo8xP76/nS4X0FGF9BQAnmJ/fX86PMT++v50uF9BRtHoKAE8xP76/n R5if31/Ol2j0
H5UbR6D8qAE8xP76/nR5if31/Ol2j0H5UbR6D8qAE8xP76/nR5if31/Ol2j0 H5UbR6CgBPMT
++v50eYn99fzpdo9BRtHoKAE8xP76/nR5if31/Ol2j0FG0egoATzE/vr+dHm J/fX86XaPQUb
R6CgBPMT++v50eYn99fzpdo9BRtHoKAE8xP76/nR5if31/Ol2j0FG0egoATz E/vr+dHmJ/fX
86XaPQUbR6CgBPMT++v51yXxFZW8OQYIP+lr0P8AsPXXbR6CuR+IwA8OQYH/ AC9r/wCgPTW4
mdBof/IvaZ/16Rf+gCpry7a2Q+XCZXC7ioOMDIGf1qHQ/wDkXtM/69Iv/QBU 15aC6jZQ5Qsj
Rk4yCp6gimrX1DpoFleC8gWTYUJVWx7EZBqzUUURj3Mz75HxubGOnQAdhUtJ 2voCv1CiiikM
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igArOtbKG9kuZJzIWEzKMORwOlaNZcF9HYy3McyTBjKzDETEEH3xQBYn07Tb aFpp5DFGvV3l
wB+JqrOmkw6f9u/fvCWVBgkFiWCjGcdz16VJPqdhdQtDcQSSxN1R7ckH8CKo ag1ndaT9ggee
Bd6urPA8uMMGHB9wPanoGpZgbQp443FwyeYGIDyEEbc5z/3yfypbcaPc3n2a ORixRXQ+YfnB
3dB142msiHS9I2wG7+0TyRKygrAyKQ27PHOPvt0IHTjgVoQtpsN+l8Ptr3Sx iIysjZdAScHj
nk5oug1Nb+xrL0k/7+Gqui/vbQiXMmxmVdxzgB2H8gKl/tu2/uz/APflv8Kr aSzQWW6SORd7
MwBU5xvY/wBRSGazRwKpYxrgDNM/0bGSijp1/H/A1C1yjKVw/Ix901GZImLF 1Y5OfuH3/wAa
Yi3/AKNuC7FJJxxS7bfdt2Lu9DVYTxBtwVwc5Pynk0v2mPdu2Nu9dpoCxa8q H/nktQ8JLKqD
ChQce/P+FM+1r6P/AN8miNjI8rhWAKgDIxnr/jSAda2ltJaQu8e52jVmJY5J Iou4tPsrOa6m
hHlQo0j4yTgDJ71Db38MVtFG5cOiKpBQ8ECo7+5tr7T7i08wqJo2jJaMkYIw eOP50wsN+3aI
oTz/AC4GcZCyPzj8CabPqOiQRM58tirorqHyVDOEycH/AGgaqra6e/mNctul khaBjDEY12N1
AXJwfxpVsdIW5E4M24bcDBxw4cdueVH+TTEbMNvp9xCk0KI8bjKsrHBpz2No I2IiAODggniq
lvd2drCIomcKCW5Unkkk/qakfUrcowBYkjgBDSuOw2P/AEiOxEuWDruYZxk7 at/YbP8A54r+
ZqipNtBZNIrARrhsDODtxU39p2395v8Avk0ARGTTBPLGYGCw8SS4OxTgHGc9 cGmreaC0ixie
Dcy7wN56c/l91vyPpVaePT5zcAz3Kx3APmRqSFJIAzjHXj6e1V4NM0SC0Nqq ymI5yDnnJcno
P+mjdKdwL1zf6Jb2rzAxORE0qoGOXCgnj/vk/lWj9hs/+eK/mawLjTdHupVm uGmlmERhMjrl
mU7u+OMbm6Y61sf2nbf3m/75NFwsLLDFb3Vv5K7N5YMATyMZrmPiN/yLkH/X 2v8A6A9dEbhL
q7g8rcQm4sdpAHGK534jf8i5B/19r/6A9C3Ezc0OWMeH9MHmJ/x6RfxD+4Kv +dF/z0T8xXkE
SIsEaqqgBQAAOnFO2j0FFgueu+dF/wA9E/MUedF/z0T8xXkW0ego2j0FFgue u+dF/wA9E/MU
edF/z0T8xXkW0ego2j0FFgueu+dF/wA9E/MUedF/z0T8xXkW0ego2j0FFgue u+dF/wA9E/MU
edF/z0T8xXkW0ego2j0FFgueu+dF/wA9E/MUedF/z0X/AL6FeRbR6CjaPQUW A9d86L/nov8A
30KPOi/56L/30K8i2j0FG0egosB6750X/PRf++hR50X/AD0X/voV5FtHoKNo 9BRYD13zov8A
nov/AH0KPOi/56L/AN9CvIto9BRtHoKLBc9d86P/AJ6L/wB9Cjzo/wDnov8A 30K8i2j0FG0e
gosFz13zo/8Anov/AH0KPOj/AOei/wDfQryLaPQUbR6CiwXPXfOj/wCei/8A fQo86L/non/f
QryLaPQUbR6CiwXPXfOi/wCei/8AfQo86P8A56L/AN9CvIto9BRtHoKLBc9d 86P/AJ6L/wB9
Cjzo/wDnov8A30K8i2j0FG0egosFz13zo/8Anov/AH0KPOj/AOei/wDfQryL aPQUbR6CiwXP
XfOi/wCeifmKPOj/AOei/wDfQryLaPQUbR6CiwXPXfOj/wCei/8AfQo86P8A 56L/AN9CvIto
9BRtHoKLBc9d86P/AJ6L/wB9Cjzo/wDnov8A30K8i2j0FG0egosFz13zov8A nov/AH0K5H4i
yRnw7AA6n/S17/7D1yG0egqveQRTQhZYkdd2cMoIoSA//9k=
--------------030608090103050304060601--
FUDForum. Page generated in 0.08030 seconds
