Home » Modeling » GMF (Graphical Modeling Framework) » Copy paste problem
Copy paste problem [message #202987] Fri, 22 August 2008 01:07 Go to next message
Hi ,
I am using latest version of gmf i.e 2.1.0. I am using separate file for
model and diagram. When I copy a element on editor and paste it, at this
time I can see the element on the editor but value is not getting saved in
model. When I close the editor and reopen it ,my copied element is getting
lost.
Could some one please help on this.
Vikas
Re: Copy paste problem [message #203043 is a reply to message #202987] Fri, 22 August 2008 05:09 Go to previous messageGo to next message
Hello Vikas,
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=129533.
Looks like this is a known problem. To work around it you have to use custom
resoruce factory for the domain model creating XMLResourceImpl subclasses
with overriden "useUUIDs" method. This method have to return "true" to switch
on GUIDS support.
Alex Shatalin
Re: Copy paste problem [message #203069 is a reply to message #203043] Fri, 22 August 2008 06:25 Go to previous messageGo to next message
Thanks Alex for the information.
Could you please tell me how exactly I can use custom resource factory
for the domain model creation.
Thanks once again.
Best Regards,
Vikas
Re: Copy paste problem [message #203126 is a reply to message #203069] Fri, 22 August 2008 09:36 Go to previous messageGo to next message
Hello Vikas,
See org.eclipse.emf.ecore.extension_parser extension point.
Alex Shatalin
Re: Copy paste problem [message #203376 is a reply to message #203126] Tue, 26 August 2008 07:06 Go to previous message
Originally posted by: gtyagi.csc.com
I am facing the same problem. I enabled the uuid's for elements in
semantic model but when paste happens, the element does not go into the
model.
One reason, why the element does not go into the model could be that the
original element and new element have same point ti the same location in
memory.
Previous Topic:Diagram label for association ends - modify domain model or diagram code?
Next Topic:Creating a text attribute in GMF
Current Time: Fri Jul 18 03:02:10 EDT 2025
Powered by FUDForum. Page generated in 0.06897 seconds
