Home » Eclipse Projects » GEF » Connection problem ...
Connection problem ... [message #202951] Tue, 15 November 2005 10:37 Go to next message
Hi all,
Hope someone can help with my problem
I have the following situation in my application:
Two steps A and B
- A is connected to B
- B can be connected to A as well
[ B1 ] <--------------> [ B2]
When at run time I connect the two nodes what I get is two lines that stands
one on the top of the other...
I have used bend point so once the line has been painted I can move/create a
bend point in one line and make them both visible.
Is there something that can help me to avoid this?
I would like to have still the possibility to use bend point but would be
nice if the connection line would avoid to lay (or even cross) another
connection.
Thanks to all
Kar
Re: Connection problem ... [message #203000 is a reply to message #202951] Tue, 15 November 2005 17:27 Go to previous messageGo to next message
Are there also 2 connections in your model or do they only appear as
EditParts?
"KarSc" <carmeloscala@hotmail.com> wrote in message
news:dlcvci$iqv$1@news.eclipse.org...
> Hi all,
> Two steps A and B
> stands one on the top of the other...
> a bend point in one line and make them both visible.
> connection.
> Thanks to all
> Kar
Re: Connection problem ... [message #203017 is a reply to message #202951] Wed, 16 November 2005 04:15 Go to previous message
stands
When this is the intended behaviour, use a fan router as the primary router:
so in your "root"-editpart :
protected void refreshVisuals()
ConnectionLayer cLayer = (ConnectionLayer)
getLayer(CONNECTION_LAYER);
AutomaticRouter router = new FanRouter();
router.setNextRouter(new BendpointConnectionRouter());
cLayer.setConnectionRouter(router);
> connection.
That
Previous Topic:Move with keys
Next Topic:Building palette as tree
Current Time: Thu Jul 17 04:53:13 EDT 2025
Powered by FUDForum. Page generated in 0.04379 seconds
