Home » Newcomers » Newcomers » eclipsework
eclipsework [message #202876] Mon, 02 April 2007 16:30 Go to next message
Originally posted by: elisabetfrazer.phreaker.net
I'm trying to use Eclipsework (for projects concerning the framework
webwork) and have copied the downloaded folder to the plugin folder of
Eclipse 3.2.2 under Mac OS X 10.4.5. The jar is in the folder and I've
seen a number of plugins that come in a folder, so that doesn't seem
untypical. Sysdeo Tomcat was installed successfully this way. I installed
EasySQL too by the way.
I restarted Eclipse with ./eclipse -clean, but it still fails to recognize
the plugin. I don't see any errors in the logs. What more can I do in
order to use this plugin?
Re: eclipsework [message #202970 is a reply to message #202876] Tue, 03 April 2007 05:17 Go to previous message
Originally posted by: jakub.jurkiewicz.gmail.com
Hi Elisabet,
I've just tried to run Eclipseworks under WinXP and it doesn't work as
you said.
Maybe you should try to ask developers of Eclipseworks?
regards,
Jakub Jurkiewicz
> installed EasySQL too by the way.
> recognize the plugin. I don't see any errors in the logs. What more can
> I do in order to use this plugin?
Previous Topic:code convertion question using CDT + Eclipse
Next Topic:Eclipse SDK on Suse linux
Current Time: Sun Jun 29 14:51:47 EDT 2025
Powered by FUDForum. Page generated in 0.12067 seconds
