Home » Newcomers » Newcomers » JavaDoc and Source code linking into eclipse
JavaDoc and Source code linking into eclipse [message #202384] Fri, 30 March 2007 06:06 Go to next message
Originally posted by: evaandoli.dodo.com.au
I have the SDK Java 6 and JRE installed. Eclipse 3.3m5
When I open a class like String - its says the source is not attached, same
with the javadoc.
Maybe I have the wrong understanding but isn't the SDK source+javadoc (plus
lots of other goodies)
So how do I link the SDK into eclipse is my question (I think),
Stu
Re: JavaDoc and Source code linking into eclipse [message #202391 is a reply to message #202384] Fri, 30 March 2007 06:22 Go to previous messageGo to next message
Stu,
Using Window->Preferences->Java->Installed JREs, choose the JRE and do
"Edit..." and then pick the jar and use Source Attachment... to find the
src.jar for that...
> with the javadoc.
> Stu
Re: JavaDoc and Source code linking into eclipse [message #202454 is a reply to message #202384] Fri, 30 March 2007 11:19 Go to previous message
> with the javadoc.
Are you specifying to Eclipse which Java version to use (using the -vm
option)? If not, it may be finding the JRE and using that, which does
not have source or Javadoc with it. You should be explicitly telling
Eclipse to use your JDK, in which case it will automatically pick up the
source and Javadoc.
Specifying the -vm option is a FAQ - Google or search the newsgroup
archives for the details.
Hope this helps,
Eric
Previous Topic:a simple question-how to do "java Sample 30 5" in eclipse?
Next Topic:Key bindings Linux KDE Eclipse 3.2.1
Current Time: Sat Jul 26 09:07:31 EDT 2025
Powered by FUDForum. Page generated in 0.08213 seconds
