Home » Language IDEs » ServerTools (WTP) » Connection Pooling and reusing connections on republish of Tomcat webapp within IDE
Connection Pooling and reusing connections on republish of Tomcat webapp within IDE [message #202364] Tue, 16 October 2007 14:58 Go to next message
Good afternoon,
I am experiencing problems with Tomcat and commons-dbcp when my Tomcat
webapp gets restarted / republished from within the IDE.
As far as I can tell the connections in the connection pool are not being
closed when the webapp gets republished.
Has anyone else expierence this problem and is there a work-around?
Thanks in advance.
Whatty
Re: Connection Pooling and reusing connections on republish of Tomcat webapp within IDE [message #202522 is a reply to message #202364] Wed, 17 October 2007 08:42 Go to previous messageGo to next message
I assume by "webapp gets restarted" you referring to what is more
commonly referred to as "reloading". Any reloading triggered by WTP
publishing is under the control of Tomcat and if that's not working, you
may have to resort to restarting the server. I haven't done a lot with
connection pooling, but I believe the easiest way to cause this is to
configure the connection pool as a global resource. Then that pool
would be unaffected by any webapp reloading. Is this the case in your
configuration?
Larry
Steve Whatmore wrote:
> Good afternoon,
> Thanks in advance.
> Whatty
Re: Connection Pooling and reusing connections on republish of Tomcat webapp within IDE [message #202546 is a reply to message #202522] Wed, 17 October 2007 11:35 Go to previous messageGo to next message
You are correct, I am in fact referring to reloading.
This is how I have the resource defined
<!-- Connection Pooling Resource Definition -->
<resource-ref>
<description>Data Source Connection Pool</description>
<res-ref-name>jdbc/sybase</res-ref-name>
<res-type>javax.sql.DataSource</res-type>
<res-auth>Application</res-auth>
<res-sharing-scope>Shareable</res-sharing-scope>
</resource-ref>
and in the context.xml I have the following (some details removed)
<Context>
<!-- Default set of monitored resources -->
<WatchedResource>/WEB-INF/web.xml</WatchedResource>
<Resource
name="jdbc/sybase"
auth="Application"
factory="org.apache.tomcat.dbcp.dbcp.BasicDataSourceFactory "
type="javax.sql.DataSource"
driverClassName="com.sybase.jdbc3.jdbc.SybDriver"
.... <etc>
</Context>
Thus, if I can the <res-auth> attribute to the following that should do it
correct?
<res-auth>Container</res-auth>
Whatty
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:ff4vvf$7vo$1@build.eclipse.org...
>I assume by "webapp gets restarted" you referring to what is more commonly
>referred to as "reloading". Any reloading triggered by WTP publishing is
>under the control of Tomcat and if that's not working, you may have to
>resort to restarting the server. I haven't done a lot with connection
>pooling, but I believe the easiest way to cause this is to configure the
>connection pool as a global resource. Then that pool would be unaffected
>by any webapp reloading. Is this the case in your configuration?
> Cheers,
> Larry
>> Good afternoon,
>> Thanks in advance.
>> Whatty
Re: Connection Pooling and reusing connections on republish of Tomcat webapp within IDE [message #202553 is a reply to message #202546] Wed, 17 October 2007 12:30 Go to previous messageGo to next message
Just to make sure, where is this context.xml located? Also, which
version of WTP and have you changed anything about how the default
server comes configured.
Again, I haven't done a lot with connection pools, but I assume the
closing of connections you are looking for is dependent on the pool
being garbage collected. Even if the pool is being loaded in the
webapp's classloader and not in one of the server's classloaders, the
old webapp classloader can fail to garbage collect for a number of
reasons. Some of these reasons are bugs internal to Tomcat.
Unfortunately, I've lost track of which Tomcat versions fix which issues.
Larry
> <resource-ref>
> </resource-ref>
> <Context>
> <Resource
> name="jdbc/sybase"
> auth="Application"
> .... <etc>
> </Context>
> correct?
> Whatty
>> Cheers,
>> Larry
>>> Good afternoon,
>>> Thanks in advance.
>>> Whatty
Re: Connection Pooling and reusing connections on republish of Tomcat webapp within IDE [message #202561 is a reply to message #202553] Wed, 17 October 2007 14:44 Go to previous message
Context.xml is located in the META-INF directory and we are using the latest
version of WTP (2.0.1).
The version of Tomcat we are using is 5.5 and nothing special with our
configuration of Tomcat and the IDE.
BTW, I have changed the <res-auth> to Container
and it seems to be behaving (although that could be a side-effect of
something else)
Thanks for the assistance.
Whatty
news:ff5dak$63v$1@build.eclipse.org...
> Just to make sure, where is this context.xml located? Also, which version
> of WTP and have you changed anything about how the default server comes
> configured.
> closing of connections you are looking for is dependent on the pool being
> garbage collected. Even if the pool is being loaded in the webapp's
> classloader and not in one of the server's classloaders, the old webapp
> classloader can fail to garbage collect for a number of reasons. Some of
> these reasons are bugs internal to Tomcat. Unfortunately, I've lost track
> Larry
>> <resource-ref>
>> </resource-ref>
>> <Context>
>> <Resource
>> name="jdbc/sybase"
>> auth="Application"
>> .... <etc>
>> </Context>
>> it correct?
>> Whatty
>>> configuration?
>>> Cheers,
>>> Larry
>>>> Good afternoon,
>>>> being closed when the webapp gets republished.
>>>> Thanks in advance.
>>>> Whatty
Previous Topic:url with (tomcat) context path not working
Next Topic:Design view of WSDL doesn't link to soap fault type
Current Time: Wed Oct 22 18:11:11 EDT 2025
Powered by FUDForum. Page generated in 0.05813 seconds
