Home » Archived » BIRT » Data Set Error
Data Set Error [message #202134] |
Tue, 21 November 2006 10:55  |
Greetings,
As I tried to migrate reports from BIRT version 2.0.1 to 2.1.1,
I have encountered the problem with my query.
This query works fine on 2.0.1 but same query on 2.1.1 gets me the error of
ORA-01742 (Comment not terminated properly) and doesn't return a resultSet
object.
I have been scratched my head off to see if thereis any extra string or
space but I couldn't find one.
Any suggestion or help is greatly appreciated.
Here is the query
select
month||'-'||year mon_year,to_char(to_date(month||'-'||year,'MM-YYYY'),'Mon
YYYY') monyear,
disch_state_count,revoke_state_count,
nvl(round((disch_state_count/case when
(disch_state_count+revoke_state_count)>1 then
(disch_state_count+revoke_state_count) else 1 end)*100,1),0)
discharged_state_percent,
nvl(round((revoke_state_count/case when
revoke_state_percent
from
(select
month,year,
round(sum(total_discharged_state)OVER( order by year,month rows between 5
preceding and current row)) disch_state_count,
round(sum(total_revoked_state)OVER( order by year, month rows between 5
preceding and current row)) revoke_state_count
from
(select
to_char(disch_dt,'MM') month,
to_char(disch_dt,'YYYY') year,
count(distinct case when (disch_type = '01' ) then inmnum else null end)
total_revoked_state,
count(distinct case when (disch_type= '02') then inmnum else null end)
from
parolees_inactive,
(select
add_months(to_date('JAN-2005','MON-YYYY'),-5) v_begin_date_b,
last_day(add_months(to_date('JAN-2006','MON-YYYY'),+5)) v_end_date_f
from dual)
where
disch_dt between v_begin_date_b and v_end_date_f
and disch_type in ('01','02')
and region < '6'
group by to_char(disch_dt,'MM'),to_char(disch_dt,'YYYY')))
where to_date(month||'-'||year,'MM-YYYY') between
to_date('JAN-2005','MON-YYYY') and to_date('JAN-2006','MON-YYYY')
order by to_date(month||'-'||year,'MM-YYYY')
Re: Data Set Error [message #202157 is a reply to message #202134] |
Tue, 21 November 2006 12:59   |
Can you set your log level to FINEST and attach your log. There is a
QueryText field in the log that is the query that runs.
Verify that it is correct.
Jason
"Eric" <sirericyang@gmail.com> wrote in message
news:9ae3fbe066c26cab2b49eacecad7ca62$1@www.eclipse.org...
> Greetings,
> As I tried to migrate reports from BIRT version 2.0.1 to 2.1.1, I
> of
> object.
> Here is the query
> select month||'-'||year
> mon_year,to_char(to_date(month||'-'||year,'MM-YYYY'),'Mon YYYY') monyear,
> from
> (select month,year,
> from
> (select to_char(disch_dt,'MM') month,
> from parolees_inactive, (select
> from dual)
> where disch_dt between v_begin_date_b and v_end_date_f
> and region < '6' group by
Re: Data Set Error [message #202171 is a reply to message #202157] |
Tue, 21 November 2006 14:38   |
The problem is the division in the sql. You can just overwrite the 2.1.1 with the 2.1.2
org.eclipse.birt.report.data.oda.jdbc oda-jdbc.jar
I would like to vote that 2.1.2 gets released soon as this is a fairly major sql bug.
> Jason
>>Greetings,
>>of
>>object.
>>Here is the query
>>from
>>(select month,year,
>>from
>>from dual)
Re: Data Set Error [message #202224 is a reply to message #202157] |
Tue, 21 November 2006 14:51   |
Jason,
Thank you for the quick response. Attached is the error captured
from the log after setting the log level to FINEST. Thank you very much
for your help.
Nov 21, 2006 2:49:35 PM org.eclipse.birt.data.engine.impl.PreparedQuery
PreparedQuery
FINE: PreparedQuery starts up.
<init>
FINE: Start to prepare a PreparedQuery.
<init>
FINE: Finished preparing the PreparedQuery.
Nov 21, 2006 2:49:35 PM org.eclipse.birt.data.engine.impl.DataEngineImpl
prepare
FINE: Finished preparing query.
prepare
FINER: RETURN
doPrepare
FINER: Start to prepare the execution.
org.eclipse.birt.data.engine.impl.OdaDataSetRuntime <init>
FINER: OdaDataSetRuntime starts up
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager getInstance
FINER: ENTRY
FINER: RETURN
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager@18b6281
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager openConnection
FINER: ENTRY org.eclipse.birt.report.data.oda.jdbc
{odaURL=jdbc:oracle:thin:@consid:1521:oratest,
odaDriverClass=oracle.jdbc.driver.OracleDriver,
OdaPropertyConfigId=org.eclipse.birt.report.data.oda.jdbc_Da ta Source,
odaPassword=tivnc33a, odaUser=lookup}
org.eclipse.birt.data.engine.odaconsumer.DriverManager
setDriverLogConfiguration
Nov 21, 2006 2:49:35 PM org.eclipse.birt.data.engine.odaconsumer.Driver
Driver
Driver
FINER: RETURN org.eclipse.birt.data.engine.odaconsumer.Driver@95a1b6
setLogConfiguration
INFO: ODA driver does not have valid trace logging defined in the plug-in
options or plugin.xml file.
FINER: RETURN
org.eclipse.birt.data.engine.odaconsumer.DriverManager getDriverHelper
FINER: RETURN
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaDr iver @e4e6cf
getExtensionDataSourceId
FINER: RETURN org.eclipse.birt.report.data.oda.jdbc
org.eclipse.birt.report.data.oda.jdbc.OdaJdbcDriver getConnection
FINE: JDBCConnectionFactory.getConnection( )
connectionClassName=org.eclipse.birt.report.data.oda.jdbc
Nov 21, 2006 2:49:35 PM org.eclipse.birt.report.data.oda.jdbc.Connection
open
FINE: Connection.open(Properties). connProperties =
Source;odaDriverClass=oracle.jdbc.driver.OracleDriver;odaURL =jdbc:oracle:thin:@consid:1521:oratest;odaPassword=***;odaUs er=lookup;
close
FINE: Connection closed.
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager getConnection
FINE: Request JDBC Connection:
driverClass=oracle.jdbc.driver.OracleDriver;
url=jdbc:oracle:thin:@consid:1521:oratest; jndi name url=null
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager doConnect
FINER: Calling DriverManager.getConnection.
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager$Wrap pedDriver:oracle.jdbc.driver.OracleDriver
connect
FINER: ENTRY jdbc:oracle:thin:@consid:1521:oratest
Nov 21, 2006 2:49:37 PM
org.eclipse.birt.data.engine.odaconsumer.Connection Connection
FINER: ENTRY
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection @14b7042
FINER: RETURN org.eclipse.birt.data.engine.odaconsumer.Connection@1b72ada
org.eclipse.birt.data.engine.odaconsumer.Connection getMaxQueries
FINER: ENTRY
FINER: RETURN 0
org.eclipse.birt.data.engine.odaconsumer.Connection prepareStatement
FINER: ENTRY select
YYYY') monyear,
from
(select
month,year,
from
(select
from
parolees_inactive,
(select
from dual)
where
and region < '6'
org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet
org.eclipse.birt.data.engine.odaconsumer.Connection prepareOdaQuery
FINER: ENTRY select
YYYY') monyear,
from
(select
month,year,
from
(select
from
parolees_inactive,
(select
from dual)
where
and region < '6'
Nov 21, 2006 2:49:37 PM org.eclipse.birt.report.data.oda.jdbc.Connection
createStatement
FINE:
Connection.createStatement(org.eclipse.birt.report.data.oda. jdbc.JdbcSelectDataSet)
Nov 21, 2006 2:49:37 PM org.eclipse.birt.report.data.oda.jdbc.Statement
prepare
FINE: Statement.prepare( "select
YYYY') monyear,
from
(select
month,year,
from
(select
from
parolees_inactive,
(select
from dual)
where
and region < '6'
order by to_date(month||'-'||year,'MM-YYYY')" )
FINER: RETURN
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery @27147d
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement
PreparedStatement
FINER: ENTRY
org.eclipse.birt.data.engine.odaconsumer.Connection@1b72ada select
YYYY') monyear,
from
(select
month,year,
from
(select
from
parolees_inactive,
(select
from dual)
where
and region < '6'
PreparedStatement
FINER: RETURN
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement@5e06ef
FINER: RETURN
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement setProperty
FINER: ENTRY queryTimeOut null
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement doSetProperty
FINER: RETURN
FINER: RETURN
setColumnsProjection
FINER: ENTRY <null>
resetCurrentMetaData
FINER: ENTRY
FINER: RETURN
getProjectedColumns
FINER: ENTRY
getRuntimeMetaData
FINER: ENTRY
getMetaData
FINE: Statement.getMetaData( )
executeQuery
FINE: Statement.executeQuery( )
org.eclipse.birt.report.data.oda.jdbc.JDBCException JDBCException
FINE: odajdbc.ResultSetCannotReturn
org.eclipse.birt.report.data.oda.jdbc.JDBCException logSQLException
FINE: SQL Exception #1
java.sql.SQLException: ORA-01742: comment not terminated properly
at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java: 134)
at oracle.jdbc.ttc7.TTIoer.processError(TTIoer.java:289)
at oracle.jdbc.ttc7.Oall7.receive(Oall7.java:573)
at oracle.jdbc.ttc7.TTC7Protocol.doOall7(TTC7Protocol.java:1891 )
oracle.jdbc.ttc7.TTC7Protocol.parseExecuteDescribe(TTC7Proto col.java:830)
oracle.jdbc.driver.OracleStatement.doExecuteQuery(OracleStat ement.java:2391)
oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(Orac leStatement.java:2672)
oracle.jdbc.driver.OraclePreparedStatement.executeUpdate(Ora clePreparedStatement.java:589)
oracle.jdbc.driver.OraclePreparedStatement.executeQuery(Orac lePreparedStatement.java:527)
org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery (Statement.java:340)
org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData( Statement.java:296)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doGetMetaData(OdaQuery.java:388)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.getMetaData(OdaQuery.java:356)
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.g etRuntimeMetaData(PreparedStatement.java:369)
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.g etProjectedColumns(PreparedStatement.java:339)
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.s etColumnsProjection(PreparedStatement.java:1028)
org.eclipse.birt.data.engine.executor.DataSourceQuery.prepar e(DataSourceQuery.java:259)
org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:344)
org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:212)
org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:397)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:147)
org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:135)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:127)
org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelp er.executeQuery(QueryExecutionHelper.java:107)
org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelp er.executeQuery(QueryExecutionHelper.java:87)
org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHel per.getRealMetaData(DataSetMetaDataHelper.java:144)
org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHel per.getDataSetMetaData(DataSetMetaDataHelper.java:101)
org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.getDataSetMetaData(DataRequestSessionImpl.java:112)
org.eclipse.birt.report.designer.data.ui.util.DataSetProvide r.populateAllOutputColumns(DataSetProvider.java:211)
org.eclipse.birt.report.designer.data.ui.util.DataSetProvide r.execute(DataSetProvider.java:280)
org.eclipse.birt.report.designer.data.ui.util.DataSetProvide r.execute(DataSetProvider.java:264)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.executeProcess(ResultSetPreviewPage.java:278)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.runUpdateResults(ResultSetPreviewPage.java:247)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.access$100(ResultSetPreviewPage.java:83)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage$4.runInUIThread(ResultSetPreviewPage.java:224)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.birt.report.designer.internal.ui.dialogs.BaseDia log.open(BaseDialog.java:95)
org.eclipse.birt.report.designer.internal.ui.views.data.prov iders.DataSetNodeProvider.performEdit(DataSetNodeProvider.ja va:192)
org.eclipse.birt.report.designer.internal.ui.views.DefaultNo deProvider.performRequest(DefaultNodeProvider.java:355)
org.eclipse.birt.report.designer.internal.ui.views.actions.E ditAction.doAction(EditAction.java:79)
org.eclipse.birt.report.designer.internal.ui.views.actions.A bstractElementAction.run(AbstractElementAction.java:64)
org.eclipse.birt.report.designer.internal.ui.views.RenameLis tener.doubleClick(RenameListener.java:211)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:796)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:794)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1227)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1158)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:223)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:220)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:281)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
getRuntimeMetaData
SEVERE: Cannot get resultset metadata.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does
not return a ResultSet object.
SQL error #1: ORA-01742: comment not terminated properly
org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery (Statement.java:344)
Caused by: java.sql.SQLException: ORA-01742: comment not terminated
properly
... 71 more
Re: Data Set Error [message #202250 is a reply to message #202224] |
Tue, 21 November 2006 15:26  |
Brad,
After replacing the
org.eclipse.birt.report.data.oda.jdbc_2.1.1.v20060922-1058 with
org.eclipse.birt.report.data.oda.jdbc_2.2.0.v20061117-1020, the query is
running successfully.
Thanks for the tips on the division inside the query. Was it treated as
escape string when binding to the JDBC?
Eric
Current Time: Fri Jul 18 07:20:54 EDT 2025
Powered by FUDForum. Page generated in 0.51701 seconds
