Home » Archived » BIRT » TPTP Test Report Verdict -- Misleading sometimes
TPTP Test Report Verdict -- Misleading sometimes [message #202113] Tue, 21 November 2006 06:12
While running the JUnit tests using TPTP, I have seen the strange behaviour,
I am not sure if this is a bug I am doing something unexpected.
As a result of tests being run, execution file is created and when I see
that then in the Verdict field it shows "no verdict" and under Verdict
Summary generated chart is missing.
It does this on random basis, Sometimes execution report shows perfect
sometimes reports says "no verdict" and 'chart is missing"
If I run my testSuite using JUnit it shows 100 percent pass visually, every
time I run the tests.
I am using TPTP 4.2.1 and BIRT 2.1.1 and Eclipse 3.2.
I have seen one bug too, I am not sure If this is realted to this or not.
Could somebody have some thoughts on this please ?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=155093
Ravi.
Previous Topic:How to ask the engine, if there have been errors while executing task.run()
Next Topic:IO exception , along with output
Current Time: Sun Nov 09 05:38:25 EST 2025
Powered by FUDForum. Page generated in 0.02905 seconds
