Home » Eclipse Projects » Eclipse Platform » Menubar contribution blues
Menubar contribution blues [message #202010] Wed, 25 February 2004 20:45
Hi. I am attempting to add some UI to the tollbar. I've used the same
pattern as other plugins, such as org.eclipse.jdt.ui, but I can't get my
actions to appear on the menu. In this case, I'm trying to add actions
to the Project menu. But nothing shows up under that menu after I add
the command via Window->Customize Perspective. Thanks for any tips.
Cheers, Chris
excerpt from my plugin.xml file (actually, it's new code in
org.eclipse.compare/plugin.xml...
<extension
point="org.eclipse.ui.actionSets">
<actionSet
label="%action.CheckpointActionSet.label"
description="%action.CheckpointActionSet.description"
visible="false"
id="org.eclipse.compare.CheckpointActionSet">
<action
definitionId="org.eclipse.compare.ui.project.addcheckpoint"
label="%action.AddCheckpoint.label"
tooltip="%action.AddCheckpoint.tooltip"
class="org.eclipse.compare.internal.AddCheckpointAction"
menubarPath="project/additions"
id="addCheckointAction">
</action>
<action
definitionId="org.eclipse.compare.ui.project.showcheckpoints "
label="%action.ShowCheckpoints.label"
tooltip="%action.ShowCheckpoints.tooltip"
class="org.eclipse.compare.internal.ShowCheckpointsAction"
id="showCheckointsAction">
</action>
</actionSet>
</extension>
Previous Topic:Printing on OSX 10.3
Next Topic:dynamic context menus
Current Time: Sat Jul 26 09:18:19 EDT 2025
Powered by FUDForum. Page generated in 0.45952 seconds
