Home » Archived » Voicetools » openvxml vtp 3.0. I need help
openvxml vtp 3.0. I need help [message #19304] |
Fri, 26 September 2008 16:30  |
Hello all, I have a problem apparently. I have an application made in
openVXML(I download VTP-3.0 from eclipse project), is a very simple, but
apparently I have problems with the export of my application to file a war
once it has been exported, I take the war and file in the directory I
leave my webapp Tomcat installation (my version apache-tomcat-5.5.26 and I
also tested with the version apache-tomcat-6.0.18). will automatically
unzip the file and then war in my web browser I write the url:
http://localhost:8081/ <warfile> / <projectname>.
in my application designed openVXML has a playPrompt using a wav sound file
module begin -> module PlayPrompt -> module endcall
in my web browser I see the following code:
<? xml version = "1.0"?>
- <vxml Xmlns="http://www.w3.org/2001/vxml" version="2.0">
- <form Id="InitialForm" scope="document">
<var name="ANI" expr="" />
<var name="DNIS" expr="" />
- <block Name="InitialBlock">
name="ANI" expr="session.connection.remote.uri" /> <assign
name="DNIS" expr="session.connection.local.uri" /> <assign
<submit
next=" /Alex/-/next;jsessionid=BA1D0604EC17B37AE750BE99BFDC50F4?cbb 0fc79382a4f039e6f8eb5fef8b1cd=success.filled "
method="get" namelist="ANI DNIS" />
</ block>
</ form>
</ VXML>
apparently this bad, if anyone can help me I would appreciate.
Also if someone has experience with openvxml and voxeo Prophecy to call my
application from sip the phone.
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #19396 is a reply to message #19304] |
Wed, 01 October 2008 13:15   |
Hi Alejandro--
You're almost there. What you're seeing is just the initialization page,
which is the first thing you'll see for any voice application. Since you're
looking at things through a web browser, you'll need to help the process
along manually to see the rest of it.
In the response that you got when you first invoked the application, take
special note of the submit tag
<submit
f039e6f8eb5fef8b1cd=success.filled" method="get" namelist="ANI DNIS" />
Specifically, it's the "next" parameter you're interested in. If you copy
everything in that parameter and replace the war/app part of your URL,
you'll get this:
http://localhost:8081/Alex/-/next;jsessionid=BA1D0604EC17B37AE750BE99BFDC50F
4?cbb0fc79382a4f039e6f8eb5fef8b1cd=success.filled
If you paste that in as the next address in the browser, you'll see the next
page (which, according to you description, would be the wav file).
As for calling your application through Prophecy via a Sip phone, no
problem, I've done it many times. You'll need to configure the application
through Prophecy's Administration interface. Click the Call Routing tab,
then use one of the Routes. Provide an ID (you'll use this to make the SIP
call). Specify VXML as the type, and then put the initial application URL
in the URL field. Be sure and click the Save Changes button at the bottom
when you're done. To make the call, you'll start your SIP phone and make a
SIP call to <ID>@<prophecy IP>. If you called your application hello, and
everything was running on your local box, then you could dial
hello@localhost.
I hope this helps.
Good luck,
Randy Childers
OpenMethods
On 9/26/08 3:30 PM, in article
79dcc9ec9229841edf0d17595aa78002$1@www.eclipse.org, "Alejandro Novoa"
> <submit
> </ block>
> </ form>
> </ VXML>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #19488 is a reply to message #19442] |
Thu, 02 October 2008 09:56   |
Originally posted by: gus273.yahoo.com
Hello all,
I seem to be having the same problem described by Alejandro. I've made up a
very simple application consisting of the following 3 blocks:
a) Begin.
b) PlayPrompt (to play a pre-recorded VOX file).
c) EndCall.
I generated the WAR file and deployed it to a Tomcat server.
I can navigate successfully to the first VXML page, using the following URL:
http://localhost:8080/VxmlTests/Test1
.... and the resulting VXML page is:
<?xml version="1.0"?>
<vxml xmlns="http://www.w3.org/2001/vxml" version="2.0">
<form id="InitialForm" scope="document">
<var name="ANI" expr=""/>
<var name="DNIS" expr=""/>
<block name="InitialBlock">
<assign name="ANI" expr="session.connection.remote.uri"/>
<assign name="DNIS" expr="session.connection.local.uri"/>
<submit
next=" /VxmlTests/-/next;jsessionid=FF28916879E31933A8302DC3AA47453 8?cbb0fc79382a4f039e6f8eb5fef8b1cd=success.filled "
method="get" namelist="ANI DNIS"/>
</block>
</form>
</vxml>
So far, so good. But...
.... when I try to navigate to the next VXML page, using the following URL:
http://localhost:8080/VxmlTests/-/next ;jsessionid=FF28916879E31933A8302DC3AA474538?cbb0fc79382a4f0 39e6f8eb5fef8b1cd=success.filled
.... I always receive the following VXML page:
<form id="EndMessageForm" scope="document">
<block name="EndMessageBlock">
<disconnect/>
</block>
</form>
</vxml>
Instead of this VMXL page, I was expecting a VXML page with instructions to
carry out the pre-recorded VOX file playback, as instructed in the
"PlayPrompt" block of the graphical application.
I'm using the following software:
- openVXML-3.0-windows-installer.exe (160 MBs).
- jdk-1_5_0_16-windows-i586-p.exe (51,8 MBs).
- apache-tomcat-4.1.37-LE-jdk14.exe (8,11 MBs).
On the same machine I have installed:
- prophecy-8.0.198.1-small-tts-ds.msi (171 MBs).
I'm available to provide any additional information that may be required.
Any help will be very much appreciated! Thanks in advance,
- Gustavo.
"Alejandro Novoa" <nvooaj@gmail.com> wrote in message
news:b4915a033d5bbf2ce25eff13f7543258$1@www.eclipse.org...
> Hi Randy, thanks for your answer.
> When you hit the next line:
> -/next; jsessionid = A1D0604EC17B37AE750BE99BFDC50F
> 4? Cbb0fc79382a4f039e6f8eb5fef8b1cd = success.filled
> as you say what you like this:
> http://localhost:8081/Alex/-/next; jsessionid =
> in the web browser that appears:
> <vxml version="2.0">
> <disconnect/>
> </block>
> </form>
> </vxml>
> really is not like your shows, do not actually what the problem is.
> - I get off from openmethods the openvxml3.0
> - I have ran a tomcat (apache-tomcat-5.5.26).
> - E: \ apache-tomcat-5.5.26 \ webapps my file this war, here are
> automatically deploy
> -I have installed the J2SE Runtime Environment 5.0 Update 15.
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #19623 is a reply to message #19488] |
Mon, 06 October 2008 17:23   |
Gustavo, everything looks good with your setup except the Tomcat version --
we generally use 5.5, though I don't really think that's your problem. The
most important part is the Java version, which you've got. Please send me
your .war file and I'll take a look at it myself.
Randy Childers
OpenMethods
On 10/2/08 8:56 AM, in article gc2jtq$n94$1@build.eclipse.org, "Gustavo"
<gus273@yahoo.com> wrote:
> Hello all,
> a) Begin.
> c) EndCall.
> <submit
> 2a4f039e6f8eb5fef8b1cd=success.filled"
> </block>
> </form>
> </vxml>
> http://localhost:8080/VxmlTests/-/next;jsessionid=FF28916879E31933A8302DC3AA47
> 4538?cbb0fc79382a4f039e6f8eb5fef8b1cd=success.filled
> <disconnect/>
> </block>
> </form>
> </vxml>
> - Gustavo.
>> <disconnect/>
>> </block>
>> </form>
>> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #19714 is a reply to message #19623] |
Mon, 06 October 2008 20:12   |
Hi Randy,
I've just sent you an email with information for downloading the .war file
(8 MBs).
Thank you very much for your help!
- Gustavo.
"Randy Childers" <randy@openmethods.com> wrote in message
news:C50FEBFF.2CFD%randy@openmethods.com...
> version --
> The
> Randy Childers
> OpenMethods
>> Hello all,
>> a
>> a) Begin.
>> c) EndCall.
>> URL:
>> <submit
>> </block>
>> </form>
>> </vxml>
>> URL:
>> <disconnect/>
>> </block>
>> </form>
>> </vxml>
>> to
>> - Gustavo.
>>> <disconnect/>
>>> </block>
>>> </form>
>>> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #19928 is a reply to message #19779] |
Wed, 08 October 2008 13:42   |
configuring Prophecy to hit the app via SIP)Hi Randy,
Thank you very much for your help and for trying the ".war" file I had
generated.
After knowing (per your test result) that the problem was not related to the
".war" file, I decided to focus my attention on Tomcat's generation of the
VXML pages. Luca's post provided me with a hint that the problem might be
related to some international setting affecting Tomcat's generation of the
VXML pages. (I was performing my tests on a system with Latin-american
regional settings).
After much trial and error, I've finally been able to resolve the problem by
doing the following on the system where Tomcat was running:
1. Click Start, click Run, type regedit, and then click OK.
2. Locate the following registry key:
HKEY_USERS\.Default\Control Panel\International
3. Right-click Locale, and then click Modify.
4. In the Value data box, type 00000409, and then click OK.
5. Quit Registry Editor.
6. Restart the "Apache Tomcat" service.
7. Retry navigation of the VXML pages (make sure you are getting the VXML
pages from Tomcat, and not from the browser's cache).
Note: The "Apache Tomcat" service on my system is running on the "Local
System account" (default Tomcat service installation on Windows).
I hope this information is helpful to everyone else having this same
problem.
Best regards!
- Gustavo.
news:C510FB04.2D23%randy@openmethods.com...
Hi Gustavo--
I've just taken a look at your app, and things looked fine for me. Here's
what I saw:
<submit
next=" /VxmlTests/-/next;jsessionid=F481020D504EA4990A3F754BA9F0C3A A?cbb0fc79382a4f039e6f8eb5fef8b1cd=success.filled "
</block>
</form>
</vxml>
http://localhost:8080/VxmlTests/-/next ;jsessionid=F481020D504EA4990A3F754BA9F0C3AA?cbb0fc79382a4f0 39e6f8eb5fef8b1cd=success.filled
<form id="OutputMessageForm" scope="document">
<property name="bargein" value="false"/>
<block name="OutputMessageBlock">
<prompt bargein="false" xml:lang="en-US">
<audio src="/VxmlTests/-/resources/Susan-EnUS/Welcome.vox"/>
</prompt>
<goto next="/VxmlTests/-/next"/>
</block>
</form>
<catch event="connection.disconnect.hangup">
<goto next="/VxmlTests/-/abort"/>
</catch>
</vxml>
Be aware that one of the ways session is tracked is using cookies - I
generally completely shut down the browser between tests to clear anything
residual out from the last test. Please give this a try and let me know if
you see anything different.
Good luck,
Randy
On 10/6/08 7:12 PM, in article gce9h2$phd$1@build.eclipse.org, "Gustavo"
> Hi Randy,
> (8 MBs).
> - Gustavo.
>> version --
>> The
>> me
>> Thanks,
>> Randy Childers
>> OpenMethods
>>> Hello all,
>>> up
>>> a
>>> a) Begin.
>>> c) EndCall.
>>> URL:
>>> <submit
>>> 38
>>> </block>
>>> </form>
>>> </vxml>
>>> URL:
>>> 47
>>> <disconnect/>
>>> </block>
>>> </form>
>>> </vxml>
>>> to
>>> required.
>>> - Gustavo.
>>>> <disconnect/>
>>>> </block>
>>>> </form>
>>>> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #19958 is a reply to message #19928] |
Wed, 08 October 2008 18:38   |
Thanks, Gustavo--
Yes, that's pretty much it. What's happening is that when the app is
served, the OS's local language setting on the webserver is used to attempt
to dynamically select the default language used for the application. In all
of the apps I looked at, English was the language used in the Voice
Formatter project, but if the language on the webserver wasn't English then
the dynamic language selection mechanism I just mentioned would fail, which
is why the app wouldn't get past the initial page fetch.
Short of updating openVXML to allow you to select the default language
explicitly when the application is exported (stay tuned!), there are a few
workarounds for this. Gustavo's suggestion below will likely work (I only
say that because I haven't tried it myself). Another option is to create a
language formatter for the target language (this isn't as hard as it might
sound -- we have a tutorial doc that walks you through the process, if
you're a java programmer). Probably the least appealing solution would be
to set up a webserver that's configured with English as the local language
and serve the app from there.
Of the above, the best solution is just to take some time to create the
language formatter for your language -- and then upload it to the VTP for
the greater good, in the same spirit in which we've provided openVXML. :)
If anyone wants to give this a shot, please email me for the language
formatter document.
Randy Childers
OpenMethods
On 10/8/08 12:42 PM, in article gcirf0$jsq$1@build.eclipse.org, "Gustavo"
> generated.
> regional settings).
> problem.
> Best regards!
> - Gustavo.
> Hi Gustavo--
> what I saw:
> <submit
> </block>
> </form>
> </vxml>
> http://localhost:8080/VxmlTests/-/next;jsessionid=F481020D504EA4990A3F754BA9F0
> C3AA?cbb0fc79382a4f039e6f8eb5fef8b1cd=success.filled
> </prompt>
> </block>
> </form>
> </catch>
> </vxml>
> Good luck,
> Randy
>> Hi Randy,
>> (8 MBs).
>> - Gustavo.
>>> version --
>>> The
>>> me
>>> Thanks,
>>> Randy Childers
>>> OpenMethods
>>>> Hello all,
>>>> up
>>>> a
>>>> a) Begin.
>>>> c) EndCall.
>>>> URL:
>>>> <submit
next=" /VxmlTests/-/next;jsessionid=FF28916879E31933A8302DC3AA47453 8?cbb0fc7 >>>>
9
>>>> 38
>>>> </block>
>>>> </form>
>>>> </vxml>
>>>> URL:
http://localhost:8080/VxmlTests/-/next;jsessionid=FF28916879E31933A8302DC3A>>>>
A
>>>> 47
>>>> <disconnect/>
>>>> </block>
>>>> </form>
>>>> </vxml>
>>>> to
>>>> required.
>>>> - Gustavo.
>>>>> <disconnect/>
>>>>> </block>
>>>>> </form>
>>>>> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #20044 is a reply to message #19958] |
Thu, 09 October 2008 09:22   |
Hi Randy,
Thanks for the detailed information. It would be great if OpenVXML would
optionally allow the application designer to select the default language
explicitly when the application is exported. I'll stay tuned!
Thanks again for your help!
- Gustavo.
news:C512A0A5.2D7E%randy@openmethods.com...
> Thanks, Gustavo--
> attempt
> all
> then
> which
> a
> formatter document.
> Randy Childers
> OpenMethods
>> generated.
>> the
>> the
>> the
>> regional settings).
>> by
>> problem.
>> Best regards!
>> - Gustavo.
>> Hi Gustavo--
>> Here's
>> what I saw:
>> <submit
>> </block>
>> </form>
>> </vxml>
>> </prompt>
>> </block>
>> </form>
>> </catch>
>> </vxml>
>> anything
>> if
>> Good luck,
>> Randy
>>> Hi Randy,
>>> file
>>> (8 MBs).
>>> - Gustavo.
>>>> version --
>>>> The
>>>> me
>>>> Thanks,
>>>> Randy Childers
>>>> OpenMethods
>>>> "Gustavo"
>>>>> Hello all,
>>>>> up
>>>>> a
>>>>> a) Begin.
>>>>> c) EndCall.
>>>>> following
>>>>> URL:
>>>>> <submit
> 9
>>>>> 38
>>>>> </block>
>>>>> </form>
>>>>> </vxml>
>>>>> URL:
> A
>>>>> 47
>>>>> <disconnect/>
>>>>> </block>
>>>>> </form>
>>>>> </vxml>
>>>>> instructions
>>>>> to
>>>>> required.
>>>>> - Gustavo.
>>>>>> <disconnect/>
>>>>>> </block>
>>>>>> </form>
>>>>>> </vxml>
Re: Solved. I need help(seeing the app in a browser and configuring s [message #20897 is a reply to message #19859] |
Thu, 09 October 2008 18:23  |
Hello everybody, I was able to operate my application, he was just a
detail, I believe that it had given as a solution, but I had done wrong.
We have to go to the configuration and choose English language, I only had
changed in the taskbar and not the language from start -> control panel ->
regional and language settings.
Well now well works well and what I tried to sip from voxeo phone and
works super.
Hopefully in the near future, enable the option for Spanish language and
other languages and also to suggest this step tutorial on the
configuration language.
thanks
Alejandro Novoa
Re: openvxml vtp 3.0. I need help [message #577277 is a reply to message #19304] |
Tue, 30 September 2008 16:11  |
good thing I'm trying to prove openvxml and Voxeo Prophercy. My
application for example is called simple and the file is called
example.war war. The application is very simple, just have a text (TTS)
that says "Hello Alex."
Begin -> PLayPrompt -> EndCall.
I exported my application to a web tutorial as stated in the "getting
started", then left the war in my installation file (on Tomcat webapp in
the directory, this is decompressed, then I go to my web browser and type
the following URL:
http://localhost:8081/example/simple
The browser displays the following contents:
-- <form id="InitialForm" scope="document">
-- <block name="InitialBlock">
<submit next="/example/-/next;
jsessionid=D405778EAB3F9E6F8ABB9F39242A0C61?cbb0fc79382a4f03 9e6f8eb5fef8b1cd=success.filled "
</ block>
</ form>
</ VXML>
I call my application from the phone sip of voxeo prophercy. when running
the application throws an error in the following lines:
INFO: The APR based Apache Tomcat Native library which allows optimal
performanc
e in production environments was not found on the java.library.path:
C:\Java\jdk
1.5.0_06\bin;.;C:\WINNT\System32;C:\WINNT;E:\oracle\ora92\bi n;C:\WINNT\system32;
C:\WINNT;C:\WINNT\System32\Wbem;C:\Archivos de programa\Microsoft SQL
Server\80\
Tools\BINN;%ANT_HOME\bin;C:\Archivos de programa\CollabNet Subversion
Server
28-09-2008 08:53:29 PM org.apache.coyote.http11.Http11Protocol init
INFO: Inicializando Coyote HTTP/1.1 en puerto http-8081
28-09-2008 08:53:29 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 803 ms
28-09-2008 08:53:29 PM org.apache.catalina.core.StandardService start
INFO: Arrancando servicio Catalina
28-09-2008 08:53:29 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.18
28-09-2008 08:53:29 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Despliegue del archivo example.war de la aplicaciŽ+¢n web
!SESSION 2008-09-28 20:53:30.984
eclipse.buildId=unknown
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_CL
Command-line arguments: -consoleLog
!ENTRY org.eclipse.osgi 4 0 2008-09-28 20:53:31.000
!MESSAGE Bundle org.apache.log4j@start not found.
INFO |2008/09/28|20:53:31> Host Started
INFO |2008/09/28|20:53:31|p=simple> Process "simple" Started
28-09-2008 08:53:32 PM org.apache.coyote.http11.Http11Protocol start
INFO: Arrancando Coyote HTTP/1.1 en puerto http-8081
28-09-2008 08:53:32 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
28-09-2008 08:53:32 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/47 config=null
28-09-2008 08:53:32 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 3024 ms
INFO |2008/09/28|20:53:45|p=simple|s=5A4CB542AA1BB173445DA2559BAB 2484 >
Session "
5A4CB542AA1BB173445DA2559BAB2484" created.
INFO
|2008/09/28|20:53:45|p=simple|s=5A4CB542AA1BB173445DA2559BAB 2484|e=0001 > Ex
ecution "1" Started
INFO
|2008/09/28|20:53:45|p=simple|s=5A4CB542AA1BB173445DA2559BAB 2484|e=0001 > Ac
tion "Begin" Starting
INFO
|2008/09/28|20:53:45|p=simple|s=5A4CB542AA1BB173445DA2559BAB 2484|e=0001 > Re
questing initial variables.
INFO
tion "Begin" Ended
INFO
ecution "1" Ended
INFO |2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3 >
Session "
CF6A3909157A9407156E5C020A9B25D3" created.
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0001 > Ex
ecution "1" Started
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0001 > Ac
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0001 > Re
INFO
tion "Begin" Ended
INFO
ecution "1" Ended
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0002 > Ex
ecution "2" Started
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0002 > Ac
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0002 > Pr
ocessing initial variables.
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0002 > As
signed variable "Platform.ANI" to "unknown"
INFO
signed variable "Platform.DNIS" to "vxml"
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0002 > Pe
rforming variable assignments
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0002 > Va
riable assignments complete
INFO
tion "Begin" Ended
INFO
tion "PlayPrompt" Starting
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0002 > Se
nding output.
INFO
tion "PlayPrompt" Ended
ERROR|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C0 20A9B25D3|e=0002 >
null
org.eclipse.vtp.framework.interactions.core.services.Convers ation.res
olveOutput(Conversation.java:147)
org.eclipse.vtp.framework.interactions.core.services.Convers ation.acc
ess$2(Conversation.java:141)
org.eclipse.vtp.framework.interactions.core.services.Convers ation$Out
putMessage.createCommand(Conversation.java:620)
org.eclipse.vtp.framework.interactions.core.services.Convers ation$Abs
tractInteraction.enqueue(Conversation.java:475)
org.eclipse.vtp.framework.interactions.core.actions.OutputMe ssageActi
on.execute(OutputMessageAction.java:66)
org.eclipse.vtp.framework.engine.runtime.Action.execute(Acti on.java:1
33)
org.eclipse.vtp.framework.engine.runtime.Sequence.next(Seque nce.java:
108)
org.eclipse.vtp.framework.engine.runtime.Execution$1.run(Exe cution.ja
va:173)
org.eclipse.vtp.framework.engine.http.DeploymentExecution.vi sitRunnab
le(DeploymentExecution.java:461)
org.eclipse.vtp.framework.engine.runtime.Execution$1.accept( Execution
java:187)
org.eclipse.vtp.framework.engine.http.DeploymentExecution.do Next(Depl
oymentExecution.java:191)
org.eclipse.vtp.framework.engine.http.DeploymentSession.next (Deployme
ntSession.java:206)
org.eclipse.vtp.framework.engine.http.Deployment.next(Deploy ment.java
:167)
org.eclipse.vtp.framework.engine.http.HttpConnector.invokePr ocessEngi
ne(HttpConnector.java:376)
org.eclipse.vtp.framework.engine.http.HttpConnector.process( HttpConne
ctor.java:287)
org.eclipse.vtp.framework.engine.http.HttpConnectorServlet.p rocess(Ht
tpConnectorServlet.java:121)
org.eclipse.vtp.framework.engine.http.HttpConnectorServlet.d oGet(Http
ConnectorServlet.java:142)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleR
equest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(P
roxyServlet.java:111)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyS
ervlet.java:75)
org.eclipse.equinox.servletbridge.BridgeServlet.service(Brid geServlet
java:115)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(Appl
icationFilterChain.java:290)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationF
ilterChain.java:206)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperV
alve.java:233)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextV
alve.java:191)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.j
ava:128)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.j
ava:102)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineVal
ve.java:109)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.jav
a:286)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java
:845)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.proce
ss(Http11Protocol.java:583)
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:44
7)
at java.lang.Thread.run(Thread.java:595)
INFO
ecution "2" Ended
INFO
|2008/09/28|20:54:59|p=simple|s=CF6A3909157A9407156E5C020A9B 25D3|e=0003 > Se
ssion "CF6A3909157A9407156E5C020A9B25D3" Terminated
Session "
CF6A3909157A9407156E5C020A9B25D3" disposed.
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577297 is a reply to message #19304] |
Hi Alejandro--
<submit
you'll get this:
hello@localhost.
I hope this helps.
Good luck,
Randy Childers
OpenMethods
> <submit
> </ block>
> </ form>
> </ VXML>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577320 is a reply to message #19396] |
Wed, 01 October 2008 17:42  |
<disconnect/>
</block>
</form>
</vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577342 is a reply to message #19442] |
Hello all,
a) Begin.
c) EndCall.
<submit
</block>
</form>
</vxml>
<disconnect/>
</block>
</form>
</vxml>
- Gustavo.
> <disconnect/>
> </block>
> </form>
> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577401 is a reply to message #19488] |
Randy Childers
OpenMethods
> Hello all,
> a) Begin.
> c) EndCall.
> <submit
> </block>
> </form>
> </vxml>
> <disconnect/>
> </block>
> </form>
> </vxml>
> - Gustavo.
>> <disconnect/>
>> </block>
>> </form>
>> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577427 is a reply to message #19442] |
Mon, 06 October 2008 17:24  |
Hi Alejandro--
In the URL you created to request the next page (indicated below), did it
include all the spaces which the sample below has? There shouldn't be any.
If this isn't your problem, please send me your .war and I'd be happy to
check it myself.
Thank you,
Randy Childers
OpenMethods
On 10/1/08 4:42 PM, in article
b4915a033d5bbf2ce25eff13f7543258$1@www.eclipse.org, "Alejandro Novoa"
> <disconnect/>
> </block>
> </form>
> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577452 is a reply to message #19623] |
Hi Randy,
(8 MBs).
- Gustavo.
> version --
> The
> Randy Childers
> OpenMethods
>> Hello all,
>> a
>> a) Begin.
>> c) EndCall.
>> URL:
>> <submit
>> </block>
>> </form>
>> </vxml>
>> URL:
>> <disconnect/>
>> </block>
>> </form>
>> </vxml>
>> to
>> - Gustavo.
>>> <disconnect/>
>>> </block>
>>> </form>
>>> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577469 is a reply to message #19714] |
Tue, 07 October 2008 12:39  |
> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
--B_3306224389_26141778
Content-type: text/plain;
charset="ISO-8859-1"
Content-transfer-encoding: 8bit
Hi Gustavo--
what I saw:
<submit
382a4f039e6f8eb5fef8b1cd=success.filled" method="get" namelist="ANI DNIS"/>
</block>
</form>
</vxml>
F0C3AA?cbb0fc79382a4f039e6f8eb5fef8b1cd=success.filled
</prompt>
</block>
</form>
</catch>
</vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577490 is a reply to message #19668] |
Tue, 07 October 2008 12:44  |
--B_3306224680_26169328
Hi Alejandro--
I received your .war, tried it out, and didn't have any trouble running it.
This is what I saw:
http://localhost:8080/Alex/Alex
<submit
next=" /Alex/-/next;jsessionid=BC278C44CFB542203A058CD26E09F5FD?cbb 0fc79382a4
</block>
</form>
</vxml>
http://localhost:8080/Alex/-/next;jsessionid=BC278C44CFB542203A058CD26E09F5F
D?cbb0fc79382a4f039e6f8eb5fef8b1cd=success.filled
<prompt bargein="true" xml:lang="en-US">
<audio src="/Alex/-/resources/English/pre_voces/Hola_pao.wav"/>
</prompt>
<goto next="/Alex/-/next"/>
</block>
</form>
<goto next="/Alex/-/abort"/>
</catch>
</vxml>
As with Gustavo, I
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577546 is a reply to message #19779] |
generated.
regional settings).
problem.
Best regards!
- Gustavo.
Hi Gustavo--
what I saw:
<submit
</block>
</form>
</vxml>
</prompt>
</block>
</form>
</catch>
</vxml>
Good luck,
Randy
> Hi Randy,
> (8 MBs).
> - Gustavo.
>> version --
>> The
>> me
>> Thanks,
>> Randy Childers
>> OpenMethods
>>> Hello all,
>>> up
>>> a
>>> a) Begin.
>>> c) EndCall.
>>> URL:
>>> <submit
>>> 38
>>> </block>
>>> </form>
>>> </vxml>
>>> URL:
>>> 47
>>> <disconnect/>
>>> </block>
>>> </form>
>>> </vxml>
>>> to
>>> required.
>>> - Gustavo.
>>>> <disconnect/>
>>>> </block>
>>>> </form>
>>>> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577567 is a reply to message #19928] |
Thanks, Gustavo--
formatter document.
Randy Childers
OpenMethods
> generated.
> regional settings).
> problem.
> Best regards!
> - Gustavo.
> Hi Gustavo--
> what I saw:
> <submit
> </block>
> </form>
> </vxml>
> </prompt>
> </block>
> </form>
> </catch>
> </vxml>
> Good luck,
> Randy
>> Hi Randy,
>> (8 MBs).
>> - Gustavo.
>>> version --
>>> The
>>> me
>>> Thanks,
>>> Randy Childers
>>> OpenMethods
>>>> Hello all,
>>>> up
>>>> a
>>>> a) Begin.
>>>> c) EndCall.
>>>> URL:
>>>> <submit
9
>>>> 38
>>>> </block>
>>>> </form>
>>>> </vxml>
>>>> URL:
A
>>>> 47
>>>> <disconnect/>
>>>> </block>
>>>> </form>
>>>> </vxml>
>>>> to
>>>> required.
>>>> - Gustavo.
>>>>> <disconnect/>
>>>>> </block>
>>>>> </form>
>>>>> </vxml>
Re: openvxml vtp 3.0. I need help (seeing the app in a browser and configuring Prophecy to hit the a [message #577611 is a reply to message #19958] |
Hi Randy,
- Gustavo.
> Thanks, Gustavo--
> attempt
> all
> then
> which
> a
> formatter document.
> Randy Childers
> OpenMethods
>> generated.
>> the
>> the
>> the
>> regional settings).
>> by
>> problem.
>> Best regards!
>> - Gustavo.
>> Hi Gustavo--
>> Here's
>> what I saw:
>> <submit
>> </block>
>> </form>
>> </vxml>
>> </prompt>
>> </block>
>> </form>
>> </catch>
>> </vxml>
>> anything
>> if
>> Good luck,
>> Randy
>>> Hi Randy,
>>> file
>>> (8 MBs).
>>> - Gustavo.
>>>> version --
>>>> The
>>>> me
>>>> Thanks,
>>>> Randy Childers
>>>> OpenMethods
>>>> "Gustavo"
>>>>> Hello all,
>>>>> up
>>>>> a
>>>>> a) Begin.
>>>>> c) EndCall.
>>>>> following
>>>>> URL:
>>>>> <submit
> 9
>>>>> 38
>>>>> </block>
>>>>> </form>
>>>>> </vxml>
>>>>> URL:
> A
>>>>> 47
>>>>> <disconnect/>
>>>>> </block>
>>>>> </form>
>>>>> </vxml>
>>>>> instructions
>>>>> to
>>>>> required.
>>>>> - Gustavo.
>>>>>> <disconnect/>
>>>>>> </block>
>>>>>> </form>
>>>>>> </vxml>
Re: Solved. I need help(seeing the app in a browser and configuring s [message #577634 is a reply to message #19859] |
works super.
thanks
Alejandro Novoa
Current Time: Tue Jul 08 18:47:11 EDT 2025
Powered by FUDForum. Page generated in 0.30938 seconds
