UIMA descriptor editor doesn't show up [message #201946] |
Wed, 28 March 2007 09:43 |
Steinar Bang Messages: 108 Registered: July 2009 |
Platform: Intel Pentium M, Ubuntu Dapper
eclipse 3.2.1
eclipse GEF SDK 3.2.1
EMF 2.2.0/2.2.1 (I'm not entirely sure files dated sep 21)
I'm trying to build UIMA 2.1.0 from subversion, and the component
description editor, which is an eclipse plugin, doesn't show up as a
candidate for editing .xml files.
I've followed the instructions here:
http://incubator.apache.org/uima/svn.html
Specifically, I've:
- checked out the 2.1.0 branch from SVN
- built everything with
mvn install
- made the eclipse project files with
mvn -DdownloadSources=true eclipse:eclipse
- made a distribution with
mvn assembly:assembly
in the uimaj-distr directory
- unpacked the uimaj-2.1.0-incubating-bin.tar.gz file into tmp
- copied everything under /tmp/apache-uima/eclipsePlugins/ into
/usr/local/eclipse/plugins/
- stopped and started eclipse, with eclipse -clean
The plugins show up, and look normal in the PDE target platform and in
the Plug-ins view, and on manual inspection.
There are no Errors listed in the Problems view.
In the Plug-in registry view, org.apache.uima.desceditor and
org.apache.uima.jcas.jcasgenp have white-x-on-red on their icons. But
I haven't found any way of showing what their error actually is
(usually plug-in load problems are shown as errors in the Problems
view).
All hints, tips and tricks appreciated!
Thanx!
- Steinar
FUDForum. Page generated in 0.08531 seconds
