Home » Eclipse Projects » GEF » Selection of Nodes
Selection of Nodes [message #201497] Tue, 01 November 2005 14:42 Go to next message
Originally posted by: hochrainerj.utanet.at
Hi!
I have three different types of nodes (EditParts). When I want to select one
of them in the editor with the selection tool and press the mouse, suddenly
a marquee-like cross apears and it is possiple to select it only by dragging
the cross over this node-type. It is not possible to select it just by
clicking on it.
I don't have this problem with the other two types of nodes, they are
selectable by clicking on them.
Have I forgotten to give this special node-type some rights? Do you have
some hints?
Thank you in advance,
Johannes
Re: Selection of Nodes [message #201519 is a reply to message #201497] Tue, 01 November 2005 16:13 Go to previous messageGo to next message
Originally posted by: none.unknown.com
You're probably returning a MarqueeTool from its getDragTracker() method.
Return the DragEditPartsTracker.
"Johannes Hochrainer" <hochrainerj@utanet.at> wrote in message
news:dk8gd9$fm9$1@news.eclipse.org...
> Hi!
one
suddenly
dragging
> clicking on it.
> some hints?
> Johannes
Re: Selection of Nodes [message #201536 is a reply to message #201519] Tue, 01 November 2005 16:59 Go to previous messageGo to next message
Hi!
Thank you for your answer but that is not the solution. I use the
super-implementation in this case for all my EditParts.
Johannes
"Pratik Shah" <none@unknown.com> schrieb im Newsbeitrag
news:dk8lq6$nki$1@news.eclipse.org...
> > Hi!
> one
> suddenly
> dragging
> > clicking on it.
> > some hints?
> > Johannes
Re: Selection of Nodes [message #201543 is a reply to message #201536] Tue, 01 November 2005 18:04 Go to previous messageGo to next message
What about isSelectable()? Are you returning true for that. If you can
select the parts using marquee, you must be. Basically, something is
preventing your EditPart from being targetted by the SelectionTool. You
should set a breakpoint in SelectionTool#mouseDown() and just debug it.
news:dk8odi$r5u$1@news.eclipse.org...
> Hi!
> Johannes
method.
> > > Hi!
select
> > one
> > suddenly
> > dragging
> > > clicking on it.
have
> > > some hints?
> > > Johannes
Re: Selection of Nodes [message #208105 is a reply to message #201497] Thu, 26 January 2006 06:12 Go to previous message
Originally posted by: gmittendorferREMOVETHISTEXT.web.de
Hi Johannes, a wild guess: I encountered a similar behaviour of an
EditPart when I forgot to call some super method of
AbstractGraphicalEditPart. I can't exactly recall which method it was
but I think I overrode registerVisuals() by accident. Unlikely that you
have the same problem in your code but maybe it helps ...
Johannes Hochrainer wrote:
> Hi!
> clicking on it.
> some hints?
> Johannes
Previous Topic:rotate figure / GEF rotation support
Next Topic:Two Editors but one model - how?
Current Time: Sat Jul 26 20:54:52 EDT 2025
Powered by FUDForum. Page generated in 0.05206 seconds
