Home » Newcomers » Newcomers » Install on Windows Terminal Server
Install on Windows Terminal Server [message #19229] Thu, 27 January 2005 20:16
Originally posted by: estow.csu.edu.au
I am attempting to install and run eclipse from a Windows 2003 Terminal
server. By default, and I would like to keep it that way, the installation
directories are read only client
Elicpse will not start from a terminal client because of file locking
problems on the configuration files, in particular the .mananger directory
and files. The log file has the following line :
-- log file extract --
Root exception:
java.io.FileNotFoundException:
c:\ITC307\eclipse\configuration\org.eclipse.core.runtime\.ma nager\.fileTableLock
(Access is denied)
-- end of log file extract --
I have tried the command line arguement below as suggested by some other
posts without success.
eclipse -Dosgi.locking=none
Does anybody have any suggestions ...
Edward Stow
estow at csu dot edu dot au
Previous Topic:Running command line argument file with Eclipse.
Next Topic:text editor template
Current Time: Sun May 11 09:12:45 EDT 2025
Powered by FUDForum. Page generated in 0.04369 seconds
