Example of callback [message #200784] |
Wed, 21 March 2007 07:57  |
Originally posted by: mukerji.nita.gmail.com
I have Eclipse SDK 3.2.1 Linux.I have used Multi Page Editor
Template to generate a editor plugin.I have a text file open in this
editor.
From a menu item I want to callback an executable code and
provide the textfile that is open in the editor, as input to the executable
code.Kindly provide some examples.
Re: Example of callback [message #200846 is a reply to message #200784] |
Wed, 21 March 2007 10:11  |
Hi Nita,
The code below illustrates an Action called on the contents of an Editor.
This code uses an IRunnableWithProgress because it makes a long running
call to a server (to send encrypted mail). You could replace this with
a simple call to your "callback".
Hope this helps.
Charlie
* Copyright (c) 2006, Charles Kelly; All rights reserved
package com.charleskelly.mail.ui.actions.send;
import java.lang.reflect.InvocationTargetException;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.dialogs.ProgressMonitorDialog;
import org.eclipse.jface.operation.IRunnableWithProgress;
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.plugin.AbstractUIPlugin;
import com.charleskelly.client_side_logger.ClientSideLogger;
import com.charleskelly.mail.model.VmHolder;
import com.charleskelly.mail.ui.editors.MailEditor;
import com.charleskelly.mail.ui.editors.editor_inputs.MailEditorInp ut;
import com.charleskelly.mail.ui.subactions.send.SendMailSubAction;
public class SendMailAction extends Action
private final static String ID =
"com.charleskelly.mail.ui.actions.send.SendMailAction";
private static final String pluginID = "com.charleskelly.mail.ui";
private static final String classID = ID;
private final IWorkbenchWindow iWorkbenchWindow;
@SuppressWarnings("unused")
// private IStructuredSelection iStructuredSelection;
public SendMailAction (IWorkbenchWindow iWorkbenchWindow)
this.iWorkbenchWindow = iWorkbenchWindow;
this.setId(ID);
this.setText("&Send mail");
this.setToolTipText("Request mail sending services from Mail Sending
Provider");
ImageDescriptor imageDescriptor =
AbstractUIPlugin.imageDescriptorFromPlugin("com.charleskelly.mail.ui ",
"icons/send.jpg");
this.setImageDescriptor(imageDescriptor);
}// public EditCKMailAction (IWorkbenchWindow iWorkbenchWindow)
public void run()
try
IEditorPart iEditorPart =
iWorkbenchWindow.getActivePage().getActiveEditor();
MailEditor mailEditor = (MailEditor) iEditorPart;
mailEditor.doSave(null);
VmHolder vmHolder = mailEditor.getVmHolder();
VmHolder newVmHolder = vmHolder.makeCopy();
MailEditorInput mailEditorInput = mailEditor.getMailEditorInput();
SendMailSubAction sendMailSubAction = new SendMailSubAction
(newVmHolder, mailEditorInput);
IRunnableWithProgress iRunnableWithProgress = sendMailSubAction;
ProgressMonitorDialog progressMonitorDialog = new
ProgressMonitorDialog (Display.getCurrent().getActiveShell() );
boolean separateThread = false;
boolean cancelable = true;
progressMonitorDialog.run (separateThread, cancelable,
iRunnableWithProgress);
mailEditor.close(false);
}// try
catch (InvocationTargetException ite)
ClientSideLogger.logError (pluginID, classID, "run()",
ite.toString(), ite);
MessageDialog.openError(
Display.getCurrent().getActiveShell(),
"SendMailAction",
ite.toString() );
}// catch (InvocationTargetException e)
catch (InterruptedException ie)
ClientSideLogger.logError (pluginID, classID, "run()", ie.toString(),
ie);
}// catch (InterruptedException e)
catch (Exception e)
ClientSideLogger.logError (pluginID, classID, "run()", e.toString(), e);
"ScheduleDisbursementSubAction",
e.toString() );
}// catch (Exception e)
}// public void run()
public void dispose()
}// public void dispose()
public static String getID()
return ID;
}// public static String getID()
}// public class EditCKMailAction extends Action implements
ISelectionListener, IWorkbenchAction
> editor.
FUDForum. Page generated in 0.11797 seconds
