Home » Language IDEs » ServerTools (WTP) » out of memory with 2.0.1
out of memory with 2.0.1 [message #200751] Sun, 30 September 2007 11:04 Go to next message
------=_NextPart_000_000C_01C80383.FAD71D60
Content-Type: text/plain;
format=flowed;
charset="windows-1255";
reply-type=original
I just installed the 2.0.1 build and began getting out of memory errors too
often.
I've seen this issue in bugzilla, but It seemed to me like it was an old
issue that was resolved a long time ago. Maybe this is a new bug with the
same symptoms.
Attaching a log snippet.
Content-Type: application/octet-stream;
name=".log"
Content-Disposition: attachment;
filename=".log"
!SESSION 2007-09-30 16:37:29.343 =
eclipse.buildId=3DM20070921-1145
java.version=3D1.6.0_02
java.vendor=3DSun Microsystems Inc.
BootLoader constants: OS=3Dwin32, ARCH=3Dx86, WS=3Dwin32, NL=3Den_US
Command-line arguments: -os win32 -ws win32 -arch x86 -data =
D:\work\eclipse workspaces\ws3
!ENTRY org.eclipse.core.resources 2 1 2007-09-30 16:47:20.703
!MESSAGE Skipping builder 'net.sourceforge.metrics.builder' for project =
'Renderer'. Either the builder is missing from the install, or it =
belongs to a project nature that is missing or disabled.
!ENTRY org.eclipse.wst.server.core 4 0 2007-09-30 16:47:49.125
!MESSAGE Error calling delegate setDefaults() ServerWorkingCopy =
9_30_07_4_47_PM0
!STACK 0
at =
org.eclipse.jst.server.generic.core.internal.GenericServer.g etServerDefin=
ition(GenericServer.java:239)
at =
org.eclipse.jst.server.generic.core.internal.GenericServer.s etDefaults(Ge=
nericServer.java:324)
at =
org.eclipse.wst.server.core.internal.ServerWorkingCopy.setDe faults(Server=
WorkingCopy.java:608)
at =
org.eclipse.wst.server.core.internal.ServerType.createServer (ServerType.j=
ava:195)
at =
org.eclipse.wst.server.ui.internal.wizard.page.ServerCreatio nCache.getSer=
ver(ServerCreationCache.java:61)
at =
org.eclipse.wst.server.ui.internal.wizard.page.NewManualServ erComposite.l=
oadServerImpl(NewManualServerComposite.java:214)
at =
org.eclipse.wst.server.ui.internal.wizard.page.NewManualServ erComposite.h=
andleTypeSelection(NewManualServerComposite.java:383)
at =
org.eclipse.wst.server.ui.internal.wizard.page.NewManualServ erComposite$1=
..serverTypeSelected(NewManualServerComposite.java:123)
at =
org.eclipse.wst.server.ui.internal.viewers.ServerTypeComposi te$2.selectio=
nChanged(ServerTypeComposite.java:85)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
at =
org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
at =
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredView=
er.java:2047)
at =
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.=
java:1641)
at =
org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer .java:1095)
at =
org.eclipse.wst.server.ui.internal.viewers.ServerTypeComposi te.setVisible=
(ServerTypeComposite.java:97)
at =
org.eclipse.wst.server.ui.internal.wizard.page.NewManualServ erComposite.s=
etVisible(NewManualServerComposite.java:407)
at =
org.eclipse.wst.server.ui.internal.wizard.page.NewServerComp osite.createC=
ontrol(NewServerComposite.java:233)
at =
org.eclipse.wst.server.ui.internal.wizard.page.NewServerComp osite. <init>(=
NewServerComposite.java:121)
at =
org.eclipse.wst.server.ui.internal.wizard.fragment.NewServer WizardFragmen=
t.createComposite(NewServerWizardFragment.java:74)
at =
org.eclipse.wst.server.ui.internal.wizard.TaskWizardPage.cre ateControl(Ta=
skWizardPage.java:43)
at =
org.eclipse.wst.server.ui.internal.wizard.TaskWizard.createP ageControls(T=
askWizard.java:396)
at =
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.jav=
a:669)
at =
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:54=
3)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1081)
at org.eclipse.jface.window.Window.open(Window.java:785)
at =
org.eclipse.wst.server.ui.internal.actions.LaunchWizardActio n.run(LaunchW=
izardAction.java:57)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at =
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Act=
ionContributionItem.java:546)
at =
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributi=
onItem.java:490)
at =
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContr=
ibutionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at =
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:2=
89)
at =
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:46=
1)
at =
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplicati=
on.java:106)
at =
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.ja=
va:169)
at =
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplicati=
on(EclipseAppLauncher.java:106)
at =
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Eclips=
eAppLauncher.java:76)
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:3=
63)
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
76)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
!ENTRY org.eclipse.jdt.core 4 4 2007-09-30 16:48:05.203
!MESSAGE JavaBuilder handling ImageBuilderInternalException while =
building: Formatter
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Problems =
encountered while deleting resources.
at =
org.eclipse.core.internal.resources.Resource.delete(Resource .java:713)
at =
org.eclipse.jdt.internal.core.builder.BatchImageBuilder.clea nOutputFolder=
s(BatchImageBuilder.java:111)
at =
org.eclipse.jdt.internal.core.builder.BatchImageBuilder.buil d(BatchImageB=
uilder.java:45)
at =
org.eclipse.jdt.internal.core.builder.JavaBuilder.buildAll(J avaBuilder.ja=
va:269)
at =
org.eclipse.jdt.internal.core.builder.JavaBuilder.build(Java Builder.java:=
183)
at =
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:624=
at =
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.jav=
a:166)
at =
a:197)
at =
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:246=
at =
a:249)
at =
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager=
..java:302)
at =
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:334=
at =
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:1=
37)
at =
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:235)
!SUBENTRY 1 org.eclipse.core.resources 4 273 2007-09-30 16:48:05.203
!MESSAGE Problems encountered while deleting resources.
!SUBENTRY 2 org.eclipse.core.resources 4 273 2007-09-30 16:48:05.203
!MESSAGE Could not delete '/Formatter/build/classes/com'.
!STACK 1
at =
org.eclipse.core.internal.localstore.FileSystemResourceManag er.delete(Fil=
eSystemResourceManager.java:223)
at =
org.eclipse.core.internal.resources.ResourceTree.internalDel eteFolder(Res=
ourceTree.java:351)
at =
org.eclipse.core.internal.resources.ResourceTree.standardDel eteFolder(Res=
ourceTree.java:782)
at =
org.eclipse.core.internal.resources.Resource.unprotectedDele te(Resource.j=
ava:1659)
at =
org.eclipse.core.internal.resources.Resource.delete(Resource .java:700)
at =
at =
uilder.java:45)
at =
va:269)
at =
183)
at =
at =
a:166)
at =
a:197)
at =
at =
a:249)
at =
..java:302)
at =
at =
37)
at =
!SUBENTRY 3 org.eclipse.core.resources 4 273 2007-09-30 16:48:05.203
!SUBENTRY 4 org.eclipse.core.filesystem 4 273 2007-09-30 16:48:05.203
!MESSAGE Problems encountered while deleting files.
!SUBENTRY 5 org.eclipse.core.filesystem 4 273 2007-09-30 16:48:05.203
!MESSAGE Could not delete: D:\work\eclipse =
workspaces\ws3\Formatter\build\classes\com\sundaysky.
workspaces\ws3\Formatter\build\classes\com.
!SUBENTRY 3 org.eclipse.core.filesystem 4 273 2007-09-30 16:48:05.203
!ENTRY org.eclipse.ui 4 0 2007-09-30 16:56:13.812
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.OutOfMemoryError: Java heap space
!ENTRY org.eclipse.core.jobs 4 2 2007-09-30 16:56:13.812
!MESSAGE An internal error occurred during: "Requesting Java AST from =
selection".
!STACK 0
------=_NextPart_000_000C_01C80383.FAD71D60--
Re: out of memory with 2.0.1 [message #200763 is a reply to message #200751] Sun, 30 September 2007 12:05 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
How much memory are you allocating to eclipse? What does your
eclipse.ini look like?
- Konstantin
Re: out of memory with 2.0.1 [message #200780 is a reply to message #200763] Mon, 01 October 2007 02:12 Go to previous messageGo to next message
------=_NextPart_000_0029_01C80402.DB4161C0
format=flowed;
reply-type=response
Here it is...
"Konstantin Komissarchik" <kosta@bea.com> wrote in message
news:fdohfo$oh6$1@build.eclipse.org...
> How much memory are you allocating to eclipse? What does your eclipse.ini
> look like?
> - Konstantin
name="eclipse.ini"
filename="eclipse.ini"
-showsplash=0A=
org.eclipse.platform=0A=
--launcher.XXMaxPermSize=0A=
256m=0A=
-vmargs=0A=
-Xms40m=0A=
-Xmx256m=0A=
------=_NextPart_000_0029_01C80402.DB4161C0--
Re: out of memory with 2.0.1 [message #200818 is a reply to message #200780] Mon, 01 October 2007 06:29 Go to previous messageGo to next message
Zohar,
Likely you'll want to double or more the -Xmx256m value.
zohar wrote:
> Here it is...
>> - Konstantin
Re: out of memory with 2.0.1 [message #200825 is a reply to message #200818] Mon, 01 October 2007 07:30 Go to previous messageGo to next message
Ed Merks wrote:
> Zohar,
> zohar wrote:
>> Here it is...
>>> - Konstantin
WTP on less than 512m is a NO GO at least with all WTP-projects I have
created!
- Göran Rehnlund
Re: out of memory with 2.0.1 [message #200832 is a reply to message #200825] Mon, 01 October 2007 07:49 Go to previous messageGo to next message
I have this now:
"C:\Program
Files\eclipse\eclipse.exe" -vmargs -Xms128m -Xmx512m -XX:MaxPermSize=128m
Should this be OK?
<user@domain.invalid> wrote in message
news:fdqljs$d9a$1@build.eclipse.org...
> Ed Merks wrote:
>> Zohar,
>> zohar wrote:
>>> Here it is...
>>>> - Konstantin
> created!
> - Göran Rehnlund
Re: out of memory with 2.0.1 [message #200840 is a reply to message #200832] Mon, 01 October 2007 07:54 Go to previous messageGo to next message
Zohar,
If you run out of PermGen space, make the last number bigger. If you
run out of heap memory again make the 512 bigger.
zohar wrote:
> I have this now:
> "C:\Program Files\eclipse\eclipse.exe" -vmargs -Xms128m -Xmx512m
> Should this be OK?
>> Ed Merks wrote:
>>> Zohar,
>>> zohar wrote:
>>>> Here it is...
>>>>> - Konstantin
>> have created!
>> - Göran Rehnlund
Re: out of memory with 2.0.1 [message #200855 is a reply to message #200840] Mon, 01 October 2007 10:28 Go to previous messageGo to next message
Thanks.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fdqn55$h8f$1@build.eclipse.org...
> Zohar,
> If you run out of PermGen space, make the last number bigger. If you run
> zohar wrote:
>> I have this now:
>> "C:\Program
>> Should this be OK?
>>> Ed Merks wrote:
>>>> Zohar,
>>>> zohar wrote:
>>>>> Here it is...
>>>>>> - Konstantin
>>> created!
>>> - Göran Rehnlund
Re: out of memory with 2.0.1 [message #200951 is a reply to message #200840] Tue, 02 October 2007 02:33 Go to previous messageGo to next message
If this is so obvious, why isn't it set like that in the eclipse.ini which
comes out of the box? Should I open a bugzilla issue for that?
> Zohar,
> zohar wrote:
>> I have this now:
>> "C:\Program
>> Should this be OK?
>>> Ed Merks wrote:
>>>> Zohar,
>>>> zohar wrote:
>>>>> Here it is...
>>>>>> - Konstantin
>>> created!
>>> - Göran Rehnlund
Re: out of memory with 2.0.1 [message #200992 is a reply to message #200951] Tue, 02 October 2007 07:16 Go to previous messageGo to next message
--------------020707060402050505060800
Content-Type: text/plain; charset=UTF-8; format=flowed
Zohar,
Running out of permgen space (I think) is typically related to having
lots of .class files and lots of string constants so while the default
setting may be fine for Eclipse with JDT, if you load lots more plugins
it might not be fine. For my purposes (working with bare Eclipse along
with about 150 modeling plugins) I've never needed to change the base
settings. It would certainly seem helpful if the wiki of known issues
talked about this particular issue.
<http://wiki.eclipse.org/SDK_Known_Issues#Windows_issues>
Issues related to heap or permgen space seem to be a daily occurrence on
the platform or newcomers newsgroups. I'm also not sure if the packaged
download change these default settings...
So while you could open a bugzilla, you might also contribute to the wiki...
> which comes out of the box? Should I open a bugzilla issue for that?
>> Zohar,
>> zohar wrote:
>>> I have this now:
>>> Should this be OK?
>>>> Ed Merks wrote:
>>>>> Zohar,
>>>>> zohar wrote:
>>>>>> Here it is...
>>>>>>> - Konstantin
>>>> have created!
>>>> - Göran Rehnlund
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Zohar,<br>
<br>
talked about this particular issue.  <a
href="http://wiki.eclipse.org/SDK_Known_Issues#Windows_issues"><br>
</a>
<blockquote><a
href="http://wiki.eclipse.org/SDK_Known_Issues#Windows_issues">http://wiki.eclipse.org/SDK_Known_Issues#Windows_issues</a><br>
</blockquote>
on the
download change these default settings...<br>
<br>
wiki...<br>
<br>
<br>
zohar wrote:
<blockquote cite="mid:fdsoma$tvc$1@build.eclipse.org" type="cite">If
<br>
<br>
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fdqn55$h8f$1@build.eclipse.org">news:fdqn55$h8f$1@build.eclipse.org</a>...
<br>
<blockquote type="cite">Zohar,
<br>
<br>
<br>
<br>
<br>
zohar wrote:
<br>
<blockquote type="cite">I have this now:
<br>
<br>
<br>
<br>
Should this be OK?
<br>
<br>
<a class="moz-txt-link-rfc2396E" href="mailto:user@domain.invalid">&lt;user@domain.invalid&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fdqljs$d9a$1@build.eclipse.org">news:fdqljs$d9a$1@build.eclipse.org</a>...
<br>
<blockquote type="cite">Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
zohar wrote:
<br>
<blockquote type="cite">Here it is...
<br>
<br>
"Konstantin Komissarchik" <a class="moz-txt-link-rfc2396E" href="mailto:kosta@bea.com">&lt;kosta@bea.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fdohfo$oh6$1@build.eclipse.org">news:fdohfo$oh6$1@build.eclipse.org</a>...
<br>
<blockquote type="cite">How much memory are you allocating
to eclipse? What does your eclipse.ini look like?
<br>
<br>
- Konstantin
<br>
</blockquote>
</blockquote>
</blockquote>
created!
<br>
- Göran Rehnlund
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------020707060402050505060800--
Re: out of memory with 2.0.1 [message #201016 is a reply to message #200992] Tue, 02 October 2007 08:46 Go to previous message
Ed Merks wrote:
> Zohar,
Along with what Ed said, the PermGen issue is SUN JRE specific. Other
JRE's like IBM's or BEA's don't have this particular issue, as they
handle the PermGen space differently. I believe their is already a bug
report opened at Sun's website in regards to the PermGen issue.
>>> Zohar,
>>> zohar wrote:
>>>> I have this now:
>>>> Should this be OK?
>>>>> Ed Merks wrote:
>>>>>> Zohar,
>>>>>> zohar wrote:
>>>>>>> Here it is...
>>>>>>>> - Konstantin
>>>>> have created!
>>>>> - Göran Rehnlund
Previous Topic:eclipse
Next Topic:Using Tomcat 6 Source ZIP in Eclipse SDK 3.3.0 Project
Current Time: Sun Nov 09 14:19:30 EST 2025
Powered by FUDForum. Page generated in 0.05269 seconds
