Home » Archived » Visual Editor (VE) » Problem running VE 0.5.0
Problem running VE 0.5.0 [message #19140] |
Mon, 16 February 2004 13:10  |
Originally posted by: tobias.kastl.freenet.de
Hello @everyone!
I tried the VE under Win2k and was enthusiastic. So I tried to install it
under Linux (Debian Kernel 2.6.1, eclipse 2.1.2, GEF-runtime-I20031015,
emf_1.1.1_20031020_1612WL.zip) too. The installation succeeded, but, when
I try to create a new VisualClass I get a NullPointerException and the
logfile shows the following Information:
!SESSION Feb 16, 2004 19:05:58.530
java.version=1.4.2_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -install
file:/usr/share/eclipse/
!ENTRY org.eclipse.ve.java.core 4 0 Feb 16, 2004 19:05:58.532
!MESSAGE Exception
!STACK 0
at org.eclipse.core.runtime.CoreException.<init>(CoreException.java:35)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.exec(ProxyPl ugin.java:414)
org.eclipse.jem.internal.proxy.core.ProxyVMRunner.exec(Proxy VMRunner.java:20)
org.eclipse.jdt.internal.launching.StandardVMRunner.run(Stan dardVMRunner.java:230)
org.eclipse.jem.internal.proxy.remote.ProxyRegistration.star tImplementation(ProxyRegistration.java:206)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.startImpleme ntation(ProxyPlugin.java:165)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createProxyFactoryRegistry(JavaVisualEditorPart.jav a:667)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initializeForProject(JavaVisualEditorPart.jav a:1800)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initialize(JavaVisualEditorPart.java:1705)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1588)
at java.lang.Thread.run(Thread.java:534)
I already did a chmod on the installation directory.
So, could you please help me and tell me, where I did wrong.
Thank you very much,
best wishes,
Tobi
Re: Problem running VE 0.5.0 [message #19228 is a reply to message #19217] |
Mon, 16 February 2004 16:36   |
Back again,
thank you very much for your answer,
I did as you suggested and got another Exception trying to run a normal
Application.
Here comes the stacktrace:
!SESSION Feb 16, 2004 22:34:30.948
file:/usr/share/ecl
ipse/
!ENTRY org.eclipse.debug.ui 4 120 Feb 16, 2004 22:34:30.950
!MESSAGE Error logged from Debug UI:
!STACK 1
org.eclipse.core.runtime.CoreException[120]: java.io.IOException:
java.io.IOExce
ption: /usr/share/j2sdk1.4.2_03/bin/java: cannot execute
at java.lang.UNIXProcess.<init>(UNIXProcess.java:143)
at java.lang.Runtime.execInternal(Native Method)
at java.lang.Runtime.exec(Runtime.java:566)
at org.eclipse.debug.core.DebugPlugin.exec(DebugPlugin.java:471 )
org.eclipse.jdt.launching.AbstractVMRunner.exec(AbstractVMRu nner.java
:59)
ner.java:230)
org.eclipse.jdt.internal.launching.JavaLocalApplicationLaunc hConfigur
ationDelegate.launch(JavaLocalApplicationLaunchConfiguration Delegate.java:111)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConf
iguration.java:156)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlu
gin.java:676)
org.eclipse.debug.ui.DebugUITools.buildAndLaunch(DebugUITool s.java:53
8)
at org.eclipse.debug.ui.DebugUITools$2.run(DebugUITools.java:48 7)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(Modal
Context.java:101)
!ENTRY org.eclipse.debug.core 4 120 Feb 16, 2004 22:34:30.951
!MESSAGE Exception occurred executing command line.
!STACK 0
java.io.IOException: java.io.IOException:
not execute
:59)
ner.java:230)
iguration.java:156)
gin.java:676)
8)
Context.java:101)
I think we're on the right way but I'm afraid I still don't know where to
go. ;)
Be so kind and do another suggestion.
best wishes, Tobi
Rich Kulp wrote:
> Looking in the code the null pointer exception occurred because we had
> trapped an IOException and was trying to turn it into a CoreException,
> except we made mistake and had some bad code.
> The basic problem is that we were trying to do a:
> Runtime.getRuntime().exec(...)
> and an IOException was thrown.
> Unfortunately we lost what the actual I/O exception was that actually
> happened.
> Something about your setup prevented us from doing an exec() line.
> Since this code is not that much different then the standard java
> application launcher used by straight Eclipse, try this:
> 1) Create a class with a main
> 2) Use Launch As Java Application against this class.
> See if the standard launcher will have an I/O exception too and print
> off what the problem was.
Re: Problem running VE 0.5.0 [message #19246 is a reply to message #19228] |
Mon, 16 February 2004 16:40  |
Ha! After reading what I posted I found out what was missing.
I changed the access-rights for the eclipse-installation, but not for my
j2sdk.
There was the problem. After chmodding the sdk-directory it worked.
Thank you very much for your help,
bye, bye,
Tobi
Tobi wrote:
> Back again,
> Application.
> file:/usr/share/ecl
> ipse/
> !STACK 1
> java.io.IOExce
> at
> :59)
> at
> ner.java:230)
> at
> at
> iguration.java:156)
> at
> gin.java:676)
> at
> 8)
> at
> Context.java:101)
> !STACK 0
> not execute
> at
> :59)
> at
> ner.java:230)
> at
> at
> iguration.java:156)
> at
> gin.java:676)
> at
> 8)
> at
> Context.java:101)
> go. ;)
> best wishes, Tobi
> > happened.
Re: Problem running VE 0.5.0 [message #581297 is a reply to message #19140] |
Mon, 16 February 2004 13:52  |
happened.
Thanks, Rich Kulp
Re: Problem running VE 0.5.0 [message #581315 is a reply to message #19217] |
Back again,
Application.
file:/usr/share/ecl
ipse/
!STACK 1
java.io.IOExce
:59)
ner.java:230)
iguration.java:156)
gin.java:676)
8)
Context.java:101)
!STACK 0
not execute
:59)
ner.java:230)
iguration.java:156)
gin.java:676)
8)
Context.java:101)
go. ;)
best wishes, Tobi
> happened.
Re: Problem running VE 0.5.0 [message #581337 is a reply to message #19228] |
j2sdk.
bye, bye,
Tobi
Tobi wrote:
> Back again,
> Application.
> file:/usr/share/ecl
> ipse/
> !STACK 1
> java.io.IOExce
> at
> :59)
> at
> ner.java:230)
> at
> at
> iguration.java:156)
> at
> gin.java:676)
> at
> 8)
> at
> Context.java:101)
> !STACK 0
> not execute
> at
> :59)
> at
> ner.java:230)
> at
> at
> iguration.java:156)
> at
> gin.java:676)
> at
> 8)
> at
> Context.java:101)
> go. ;)
> best wishes, Tobi
> > happened.
Current Time: Fri May 09 16:04:08 EDT 2025
Powered by FUDForum. Page generated in 0.05118 seconds
