Home » Archived » BIRT » Exception in eclipse report designer on scripted data source preview results
Exception in eclipse report designer on scripted data source preview results [message #200527] Mon, 13 November 2006 11:02 Go to next message
I'm getting the below exception when I use a very simple scripted
datasource... this started happening after I upgraded my birt report
designer plugin in eclipse from version 2.1.0 to 2.1.1.
The error message is:
An unexpected internal exception occurred.Please see log for detail.
Plug-in Provider:Eclipse€UI
Plug-in ID:org.eclipse.birt.report.designer.ui
Version:2.1.1.v20060922-1058
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:Caused by java.lang.reflect.InvocationTargetException
Any help would be appreciated.
PS. this works outside of eclipse, e.g. when I generate reports with a
script using the report engine API.
Salome
Re: Exception when clicking on preview results for scripted data source [message #200705 is a reply to message #200527] Tue, 14 November 2006 04:26 Go to previous message
The rptdesign file that use the dataset (which gives the exception) does
work. It's only when I click on preview results on the dataset that I get
this error...
Previous Topic:problem to run
Next Topic:Birt Report Design prespective in my RCP
Current Time: Mon Jul 21 21:06:01 EDT 2025
Powered by FUDForum. Page generated in 0.04955 seconds
