initializing a GraphicalEditor with an xml file [message #200313] |
Fri, 21 October 2005 12:55  |
Originally posted by: pbeagan.yahoo_dontspamme_.com
Hi - My GEF application is almost fully built. It uses an XML file as
input/output and apache XMLBeans to populate the GEF model. I am having
problems on how to react gracefully when a user tries to open an XML file
in my editor that does not pass schema/DTD validation. A case where a user
created a model in GEF, saved to xml, modified the xml by hand and screwed
it up, then tries to open the file in GEF again.
What I would like to happen:
1. User right clicks invalid XML file and select 'Open with MyGefEditor'
2. Inside (GraphicalEditor)MyGefEditor.setInput() I determine that the xml
file is not valid.
3. Somehow get eclipse to only display a standard text editor window and
possibly show a Dialog explaining why it failed.
Here's what I am able to make happen:
file is not valid. React and open the standard text editor and display
contents of XML file.
3. Eclipse displays MyGefEditor editor with Exception text : "Unable to
create this part due to an internal error. Reason for the failure: An
exception was thrown during initialization." This editor is now on top of
the text editor.
Is there any way I can get step 3 to NOT happen? Or is there somehow I can
validate the XML before it reaches my GraphicalEditor? I would settle even
for being able to set what text is being displayed in the failed
GraphicalEditor editor window.
Thanks for any suggestions.
-Patrick
Re: initializing a GraphicalEditor with an xml file [message #200345 is a reply to message #200313] |
Fri, 21 October 2005 13:50  |
> having problems on how to react gracefully when a user tries to open
> an XML file in my editor that does not pass schema/DTD validation. A
> case where a user created a model in GEF, saved to xml, modified the
> xml by hand and screwed it up, then tries to open the file in GEF
> again.
What I have implemented is as follows:
a) In the editor init() method, I add a PartListener before setInput() is
called.
b) In setInput() I parse the source file. If an error is found, I create a
dummy input and set an error flag.
c) When the part is activated, the part listener checks for the error flag.
If the flag is set it creates a Runnable which is asyncExec'd.
d) The runnable shows the user a messagebox with the error information,
closes the current editor and then opens the text editor with the source
file as the input.
Seems to work fine.
Sunil
FUDForum. Page generated in 0.04248 seconds
