Home » Language IDEs » C / C++ IDE (CDT) » CDT Cgywin debugger can't find source under Eclipse 3.2
CDT Cgywin debugger can't find source under Eclipse 3.2 [message #200222] Fri, 24 August 2007 08:42 Go to next message
Originally posted by: czhao.cs.toronto.edu
Platform:
Win XP SP2, SUN JDK/JRE 1.6.0_02, Eclipse 3.2.1 + CDT 3.1.2
I am debugging a large project (myProject) whose directory is located
like the following in Eclipse:
\root
\directory1
\directory2
\myProject
.(files).
Compile and link are fine.
When I am trying to debug(launching Cygwin/GNU gdb 6.5.50), Eclipse
reports saying it can't find the source, thus won't display the
debugging info properly during the debug process.
The problem still remains even when I have specified the full directory
path through "find source" button.
Any idea or comments?
Thank you
Chuck
Re: CDT Cgywin debugger can't find source under Eclipse 3.2 [message #200238 is a reply to message #200222] Fri, 24 August 2007 09:19 Go to previous messageGo to next message
Chuck Zhao a écrit :
> Platform:
> \root
> \directory1
> \directory2
> \myProject
> .(files).
> Thank you
> Chuck
I'm not sure, but sometime it happen to me when I forgot to tell the
compiler what I want to compile in debug mode (gcc -g)
Mehdi
Re: CDT Cgywin debugger can't find source under Eclipse 3.2 [message #200246 is a reply to message #200238] Fri, 24 August 2007 09:44 Go to previous messageGo to next message
of course, -g is on for the entire project in Makefile.
- Chuck
>> Platform:
>> \root
>> \directory1
>> \directory2
>> \myProject
>> .(files).
>> directory path through "find source" button.
>> Thank you
>> Chuck
> Mehdi
Re: CDT Cgywin debugger can't find source under Eclipse 3.2 [message #200533 is a reply to message #200246] Tue, 28 August 2007 10:38 Go to previous message
See if this helps:
http://dev.eclipse.org/newslists/news.eclipse.tools.cdt/msg1 1853.html
(Posting entitled "cdt debug can't find source files" on 17Dec2006)
....Beth
Previous Topic:Europa discovery site not working
Next Topic:no debugging of C++ programs on linux?
Current Time: Mon Jul 21 22:20:32 EDT 2025
Powered by FUDForum. Page generated in 0.30065 seconds
