Home » Language IDEs » C / C++ IDE (CDT) » GDB Hardware Debugging Breakpoints problem
GDB Hardware Debugging Breakpoints problem [message #200204] Fri, 24 August 2007 07:01 Go to next message
Originally posted by: john.nospam.assen.demon.co.uk
In CDT 4.0, with the GDB Hardware Debugging feature, I'm having issues
with breakpoints. If anyone is aware of whether I'm doing something
wrong here I would appreciate knowing, otherwise I'll look at raising
bugs on these.
1) When I set a breakpoint, let's say I do it from the console like
e.g.:
b FuncName
The output in the console (verbose mode) shows that the breakpoint has
been added in the correct file, but the breakpoints view in the CDT
debug perspective shows the breakpoint in the .elf file that I have
set in the "C/C++ Application:" field of the "Main" tab in the debug
configuration.
2) When I set a number of breakpoints in the "Run Commands" field of
the "Startup" tab, I have a number of breakpoints supposedly in my
..elf file which, when I relaunch the program, Eclipse tries to set and
receives errors from gdb as a result.
3) When I right click next to a source line and select "Toggle
breakpoint", the breakpoints view shows two breakpoints at that place
with different icons. One icon is just a dot, one is a dot with a tick
next to it. This doesn't seem right and, additionally, I can't find
anything that explains what these icons mean (Could someone please
point me to a reference - it doesn't seem to be in the help, and
there's another type of icon whch has a dot, a tick, and an arrow
across the top of it!). When I repeat this on the same line, the entry
with only a dot icon is removed, but the other entry is not, meaning
that the breakpoint still exists (and is still shown in the margin
next to the source line). If I do this again I end up with 3 entries
in the Breakpoints view!
4) Finally, not related to breakpoints, but in the debug perspective,
when I open a file using the "File" -> "Open" command on the menus I
get a java Null Pointer Exception.
FWIW, I'm using MIPS development kit with sde-gdb and an Abatron
BDI2000 probe. This is a pristine install of Eclipse Europa with only
the GDB Hardware Debugging feature added.
This all looks really promising but it would be nice if it all made
sense.
Any help gratefully appreciated.
John
Re: GDB Hardware Debugging Breakpoints problem [message #200627 is a reply to message #200204] Wed, 29 August 2007 03:32 Go to previous messageGo to next message
Originally posted by: paul.mcconkey.net
Hi John,
It sounds like the Debug perspective and GDB aren't staying synchronised
with the way you're using them. I haven't come across this issue, but it has
never occurred to me to set breakpoints using the console.
> e.g.:
> b FuncName
> configuration.
I don't know what you mean here - I just have the name of the .elf file in
the "C/C++ Application:" field of the "Main" tab, no breakpoint set.
On the Debug tab I have m68k-elf-gdb in the GDB Command field, The Init file
field is empty, command set is Standard (Windows), protocol version MI2,
verbose unchecked (although I do use this occasionally), remote target
unchecked.
Startup tab: Init commands are target remote | m68k-elf-sprite
pe://USBMultilink/ m5282evb to set up my BDM wiggler followed by load. I
used to have break main in here many moons ago but dropped it. Automatically
load image is unchecked - this didn't seem to work very well. Run commands
are just continue.
So you see it is really pretty minimal - I use Eclipse to set
breakpoints/watchpoints, etc. (Not using the console).
Could this be related to the Automatically load image? Try putting load,
followed by your breakpoint commands in the init commands script.
The CDT icons are a complete mystery to me and the documentation is not
detailed enough/out of date so it's hard to know where to find out. I am a
complete Java novice, but it may be that installing the CDT SDK and looking
at the source may be a way to find out.
What sort of file? You should look at the Eclipse error log to see what
happened.
You could always try the Zylin CDT extensions, which do pretty much the same
job as the Hardware debugging stuff.
> sense.
As far as I'm concerned Eclipse/CDT is the best development environment that
I have used for embedded work, so it's worth persevering to get a system
that works for you.
Paul.
Re: GDB Hardware Debugging Breakpoints problem [message #200635 is a reply to message #200204] Wed, 29 August 2007 04:37 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
John,
The first obvious 'mistake' is that you are not meant to set breakpoints
manually (either through the console, or through the Load/Run commands). You are
doing this behind Eclipse's back and so it has no knowledge of what you have
done. Breakpoints should be set through Eclipse.
So that leads to the question - why are you trying to set breakpoints this way?
Derek
> bugs on these.
> e.g.:
> b FuncName
> configuration.
> sense.
> John
Re: GDB Hardware Debugging Breakpoints problem [message #200643 is a reply to message #200627] Wed, 29 August 2007 05:09 Go to previous messageGo to next message
On Wed, 29 Aug 2007 08:32:43 +0100, "Paul McConkey"
<paul@mcconkey.net> wrote:
>Hi John,
I just tried it to see what happened :-)
>> e.g.:
>> b FuncName
>> configuration.
Ah - you've misinterpreted what I said but, reading that again, it's
quite easy to see why! I just have the name of the .elf file in the
"C/C++ Application:" field of the "Main" tab; setting the breakpoint
is done later. However when I set a breakpoint either from the console
or in the "Run Commands" box of the debug configuration, the
breakpoints view shows that the breakpoint is set in the .elf file, it
doesn't show the source file name.
>unchecked.
Interesting. I haven't tried changing the protocol versions.
>are just continue.
That's another issue as I mentioned later :-)
I don't use Automatically load image, but your suggestion about moving
the breakpoint settings to the Initialization box is worth trying.
That may be worthwhile if no one else knows what they mean! I'm
concerned about the creation of two breakpoints though, and only
removing one of them when I toggle etc.
>happened.
A C++ file. I'll try it again some time today and have a look at the
error log.
Yes - I may go down that route. At least I know that's been around for
a while and there appears to be more documentation about it than the
official CDT one.
>> sense.
>that works for you.
Thanks. I hope so. I would love to be able to use Eclipse in this way.
John
Re: GDB Hardware Debugging Breakpoints problem [message #200651 is a reply to message #200635] Wed, 29 August 2007 05:12 Go to previous messageGo to next message
On Wed, 29 Aug 2007 09:37:04 +0100, Derek Morris
<dmsubs@NOSPAM.consertum.com> wrote:
>John,
Automation essentially (convenience - I always want to set those
breakpoints - at least, for the moment), and possibly ignorance - does
Eclipse automatically set an initial breakpoint at the start of the
program? I want to make sure that, when I press the Debug button, it's
going to stop at the place I want it to.
Re: GDB Hardware Debugging Breakpoints problem [message #200667 is a reply to message #200651] Wed, 29 August 2007 05:28 Go to previous messageGo to next message
By default, Eclipse sets a breakpoint on main() (setting is on the Debugger
tab). It also remembers breakpoints between runs, so no need to remember where
you set them - it does it for you. If you right click on a breakpoint icon (blue
dot on the left) it can show you a breakpoint dialog that shows its properties.
You can also see what breakpoints are set in the Breakpoints view.
HTH
Derek
>> John,
Re: GDB Hardware Debugging Breakpoints problem [message #200675 is a reply to message #200667] Wed, 29 August 2007 06:08 Go to previous messageGo to next message
On Wed, 29 Aug 2007 10:28:14 +0100, Derek Morris
>tab).
This setting isn't in the GDB Hardware Debugging configuration's
Debugger tab.
Thanks. It's worth re-reading my original message though wrt setting
breakpoints and viewing them in the breakpoints view.
Re: GDB Hardware Debugging Breakpoints problem [message #200684 is a reply to message #200643] Wed, 29 August 2007 06:25 Go to previous messageGo to next message
On Wed, 29 Aug 2007 10:09:55 +0100, John McCabe
Putting the breakpoint commands in the Initialization section results
in Eclipse not listing any of them in the Breakpoints view.
>>happened.
>error log.
Tried that again. The error log reports a load of problems! It has a
list of:
1) Unhandled event loop exception (4 of these; two at 11:21:36.671 and
two at 11:21:36.686 from the org.eclipse.ui plug-in)
2) An unexpected exception was thrown. (from the
org.eclipse.ui.workbench plug-in)
3) Problems occurred when invoking code from plug-in
"org.eclipse.ui.workbench".
The details of #3 (presumably the root cause of the problem) are:
at org.eclipse.core.runtime.Path.<init>(Path.java:152)
at org.eclipse.core.runtime.Path.isValidPath(Path.java:673)
org.eclipse.cdt.debug.internal.ui.actions.ResumeAtLineAdapte r.convertPath(ResumeAtLineAdapter.java:211)
org.eclipse.cdt.debug.internal.ui.actions.ResumeAtLineAdapte r.canResumeAtLine(ResumeAtLineAdapter.java:167)
org.eclipse.cdt.debug.internal.ui.actions.RetargetResumeAtLi neAction.canPerformAction(RetargetResumeAtLineAction.java:86 )
org.eclipse.cdt.debug.internal.ui.actions.RetargetAction.upd ate(RetargetAction.java:212)
org.eclipse.cdt.debug.internal.ui.actions.RetargetAction.par tActivated(RetargetAction.java:148)
org.eclipse.ui.internal.PartListenerList$1.run(PartListenerL ist.java:72)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
org.eclipse.ui.internal.PartListenerList.fireEvent(PartListe nerList.java:57)
org.eclipse.ui.internal.PartListenerList.firePartActivated(P artListenerList.java:70)
org.eclipse.ui.internal.PartService.firePartActivated(PartSe rvice.java:73)
org.eclipse.ui.internal.PartService.setActivePart(PartServic e.java:171)
org.eclipse.ui.internal.WWinPartService.updateActivePart(WWi nPartService.java:124)
org.eclipse.ui.internal.WWinPartService.access$0(WWinPartSer vice.java:115)
org.eclipse.ui.internal.WWinPartService$1.partDeactivated(WW inPartService.java:48)
org.eclipse.ui.internal.PartListenerList2$4.run(PartListener List2.java:113)
org.eclipse.ui.internal.PartListenerList2.fireEvent(PartList enerList2.java:53)
org.eclipse.ui.internal.PartListenerList2.firePartDeactivate d(PartListenerList2.java:111)
org.eclipse.ui.internal.PartService.firePartDeactivated(Part Service.java:116)
org.eclipse.ui.internal.PartService.setActivePart(PartServic e.java:165)
org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePart Changed(WorkbenchPagePartList.java:56)
org.eclipse.ui.internal.PartList.setActivePart(PartList.java :126)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3384)
org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:602)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2730)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2539)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1090)
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:105)
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:75)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
Source)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: GDB Hardware Debugging Breakpoints problem [message #200692 is a reply to message #200635] Wed, 29 August 2007 06:37 Go to previous messageGo to next message
>John,
Also - I can't see how to set breakpoints on a named function from
Eclipse, this is something you can do in the console.
E.g. if I want to set a breakpoint on function XYZ (let's say it's a
static function for example) then I can use
b XYZ
in the console (or in the startup commands) whereas, if I waited until
I was in Eclipse, I would need to find the file that it is in, open
it, then set [two] breakpoint[s!] on that line. (or would I, if you
know how to set a breakpoint in a function from Eclipse in the GDB
Hardware Debugging feature please let me know).
*Note the "[two] breakpoint[s!]" bit refers to the issue I'm having
with two breakpoints being set when I "Toggle Breakpoint" from the
editor.
Re: GDB Hardware Debugging Breakpoints problem [message #200997 is a reply to message #200204] Sun, 02 September 2007 18:04 Go to previous message
FWIW - I reported this as a bug, but was informed that it was a
duplicate (does anyone else find bugzilla's search facilities to be
not very useful!). Anyhow - this will be fixed in the CDT 4.0.1
release which should be released on 28th September according to
http://wiki.eclipse.org/CDT/planning/4.0.1.
Previous Topic:Switch standard make to managed make
Next Topic:Default optimization level?
Current Time: Tue Jul 22 11:12:01 EDT 2025
Powered by FUDForum. Page generated in 0.04578 seconds
