Home » Language IDEs » Java Development Tools (JDT) » Does iContract work with eclipse?
Does iContract work with eclipse? [message #19107] Sat, 10 May 2003 02:11
I'd like to try iContract, but am having a hard time getting it to work in
eclipse. I've made a build.xml for ant, but although I put the iContract.jar
in the build path of the project properties, it gives an arror saying that
iContract is not found in the classpath. So finally added a classpath
attribute to the icontract element, which did locate iContract.jar, but then
complained about tools.jar. Added that also, and then get an
UnsupportedClassVersionError with tools.jar from sdk1.4.1, but not with the
one in jdk1.3.1. Other issues still seem to fail, so I'm wondering if anyone
has gotten iContract to work and have a sample build.xml?
-- Mike
Previous Topic:Format source code under the same project
Next Topic:[ANN] new release of metrics plugin
Current Time: Mon Jul 21 21:19:16 EDT 2025
Powered by FUDForum. Page generated in 0.06730 seconds
