Home » Language IDEs » ServerTools (WTP) » WTP Issue - Axis WS deployment locks up Eclipse 3.3
Re: WTP Issue - Axis WS deployment locks up Eclipse 3.3 [message #200136 is a reply to message #200128] |
Thu, 20 September 2007 20:34 |
Seng Phung Lu Messages: 62 Registered: July 2009 |
Member |
Mark,
is this severe failure reproducible given the steps you describe? I
have never experienced this from the WS wizards before, and I know that
multiple methods are supported.
If Eclipse or JVM crashed.. is there a java dump? Was your CPU max'd or
HD swapping memory at the time?
If the problem continues, please do open a bug report with the steps you
performed, and any other useful observations.
(https://bugs.eclipse.org/bugs/enter_bug_wizard.cgi)
The component to target would likely be "jst.ws".
Seng
mark wrote:
> Hello,
> I am running into an issue using the WS tooling found in the WTP of Eclipse
> 3.3 Europa. I am using JDK 1.5.0_10, Tomcat 5.5 and have everything set up
> to where I can successfully create a WS from a simple JavaBean impl class w/
> a single method. I have a second JavaBean impl class w/ 4 methods that I
> want to create another service from. I run through all the dialogs as
> before (Bottom up web service creation), I get to the page w/ the Start
> Server button. I click it, the Server starts OK and the Next and Finish
> buttons are enabled. When I click either one of those buttons, the message
> about "Deploying...." shows up at the bottom of the dialog....and then the
> entire IDE locks up (Task Manager shows "Not Responding"), nothing is
> written to the Eclipse Error log file and you have to "kill" the Eclipse
> process to shut everything down...including the javaw.exe that is left by
> the hard kill...since the Tomcat instance is running. Has anybody
> experienced something like this. It appears that the deployment step where
> the WS is deployed to Axis is dying.....yet it worked for the other WS which
> did have only ONE method.
> Any ideas would be greatly appreciated. Thanks
Re: WTP Issue - Axis WS deployment locks up Eclipse 3.3 [message #200151 is a reply to message #200136] |
Thu, 20 September 2007 22:30 |
mark streit Messages: 11 Registered: July 2009 |
------=_NextPart_000_0036_01C7FBB4.49ABCF30
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Ok...here is what I have tried:
And my machine was not locked up, only Eclipse processes were locked up. =
Memory usage was not maxed out. CPU use was about 25%.
Using the following:
Europa 3.3 JEE distro
JDK 1.5.0_10
Tomcat 5.5.25
a.. Created a new Dynamic Web project
b.. Called Source folder JavaSource instead of src
c.. Added a package to JavaSource
d.. Added a class to that package
e.. Added TWO methods one taking a String as a parameter and the other =
taking a simple custom object called Insured
f.. Right clicked on the class (java file), Web Services -> Create Web =
Service
g.. Using Bottom up Java Bean Web Service
h.. Only the "overwrite files w/o warning" check box is checked
i.. Slider is set to "Start Service"
j.. Web Service Java Bean Identity opens with methods shown checked, =
document/literal (wrapped) is the "Style and use" radio button by =
default
k.. Click Next and generation starts and stops on the Start Server =
page
l.. Click Start server page, Conole view shows server started...
m.. Now there is a Back, Next, Finish, and Cancel button all =
enabled...I select Next or Finsih and...
n.. everything locks up...the message at the bottom of the dialog box =
says: Deploying Web service to Axis run-time environment...=20
o.. but now the Task Manager shows 2 identically-named Eclipse =
processes that are locked up:
Java - =
AIMWebServices2/WebContent/WEB-INF/AIMWebServices2Service/co m/xyzcompany/=
aim/deploy.wsdd - Eclipse Platform
Java - =
a.. At this point, I can no longer get back into the IDE of course...I =
have to do an End Process, which then brings both of them down. The =
Tomcat process javaw.exe is of course still running, so I have to go =
kill that manually too.
MThis whole thing has me totally stumped. I cannot get a stack trace or =
anything at this point. I am running on Win XP Pro/SP2, 2GB RAM
some perhaps useful file content:
/WEB-INF/AIMWebServices2Service/com/xyzcompany/aim/deploy.ws dd
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<!-- Use this file to deploy some handlers/chains and services -->
<!-- Two ways to do this: -->
<!-- java org.apache.axis.client.AdminClient deploy.wsdd -->
<!-- after the axis server is running -->
<!-- or -->
<!-- java org.apache.axis.utils.Admin client|server deploy.wsdd -->
<!-- from the same directory that the Axis engine runs =
--><deployment xmlns=3D"http://xml.apache.org/axis/wsdd/" =
xmlns:java=3D"http://xml.apache.org/axis/wsdd/providers/java">
<!-- Services from AIMWebServices2Service WSDL service -->
<service name=3D"AIMWebServices2" provider=3D"java:RPC" =
style=3D"wrapped" use=3D"literal">
<parameter name=3D"wsdlTargetNamespace" =
value=3D"http://aim.xyzcompany.com"/>
<parameter name=3D"wsdlServiceElement" =
value=3D"AIMWebServices2Service"/>
<parameter name=3D"schemaQualified" =
value=3D" http://aim.xyzcompany.com,http://exceptions.aim.xyzcompany.c om,h=
ttp://beans.aim.xyzcompany.com"/>
<parameter name=3D"wsdlServicePort" value=3D"AIMWebServices2"/>
<parameter name=3D"className" =
value=3D"com.xyzcompany.aim.AIMWebServices2"/>
<parameter name=3D"wsdlPortType" value=3D"AIMWebServices2"/>
<parameter name=3D"typeMappingVersion" value=3D"1.2"/>
<operation xmlns:operNS=3D"http://aim.xyzcompany.com" =
xmlns:retNS=3D"http://aim.xyzcompany.com" =
xmlns:rtns=3D"http://beans.aim.xyzcompany.com" name=3D"getInsuredByID" =
qname=3D"operNS:getInsuredByID" =
returnQName=3D"retNS:getInsuredByIDReturn" returnType=3D"rtns:Insured" =
soapAction=3D"">
<parameter xmlns:pns=3D"http://aim.xyzcompany.com" =
xmlns:tns=3D"http://www.w3.org/2001/XMLSchema" qname=3D"pns:insuredId" =
type=3D"tns:string"/>
<fault xmlns:fns=3D"http://aim.xyzcompany.com" =
xmlns:tns=3D"http://exceptions.aim.xyzcompany.com" =
name=3D"AIMServiceFatalException" qname=3D"fns:fault" =
class=3D"com.xyzcompany.aim.exceptions.AIMServiceFatalException " =
type=3D"tns:AIMServiceFatalException"/>
</operation>
xmlns:rtns=3D"http://beans.aim.xyzcompany.com" name=3D"createInsured" =
qname=3D"operNS:createInsured" returnQName=3D"retNS:createInsuredReturn" =
returnType=3D"rtns:InsuredPK" soapAction=3D"">
xmlns:tns=3D"http://beans.aim.xyzcompany.com" qname=3D"pns:insured" =
type=3D"tns:Insured"/>
</operation>
<parameter name=3D"allowedMethods" value=3D"createInsured =
getInsuredByID"/>
<typeMapping xmlns:ns=3D"http://beans.aim.xyzcompany.com" =
qname=3D"ns:BaseBean" type=3D"java:com.xyzcompany.aim.beans.BaseBean" =
serializer=3D"org.apache.axis.encoding.ser.BeanSerializerFactory " =
deserializer=3D"org.apache.axis.encoding.ser.BeanDeserializerFactory " =
encodingStyle=3D""/>
qname=3D"ns:Insured" type=3D"java:com.xyzcompany.aim.beans.Insured" =
qname=3D"ns:InsuredPK" type=3D"java:com.xyzcompany.aim.beans.InsuredPK" =
<typeMapping xmlns:ns=3D"http://exceptions.aim.xyzcompany.com" =
qname=3D"ns:AIMServiceFatalException" =
type=3D"java:com.xyzcompany.aim.exceptions.AIMServiceFatalException " =
</service>
</deployment>
/WEB-INF/server-config.wsdd (generated by Eclipse)
<globalConfiguration>
<parameter name=3D"sendMultiRefs" value=3D"true"/>
<parameter name=3D"disablePrettyXML" value=3D"true"/>
<parameter name=3D"adminPassword" value=3D"admin"/>
<parameter name=3D"attachments.Directory" =
value=3D" C:\3.3_Europa_JEE_EclipseWS\workspace\.metadata\.plugins\org .ecl=
ipse.wst.server.core\tmp1\wtpwebapps\AIMWebServices2\WEB-INF \attachments "=
<parameter name=3D"dotNetSoapEncFix" value=3D"true"/>
<parameter name=3D"enableNamespacePrefixOptimization" =
value=3D"false"/>
<parameter name=3D"sendXMLDeclaration" value=3D"true"/>
<parameter name=3D"attachments.implementation" =
value=3D"org.apache.axis.attachments.AttachmentsImpl"/>
<parameter name=3D"sendXsiTypes" value=3D"true"/>
<requestFlow>
<handler type=3D"java:org.apache.axis.handlers.JWSHandler">
<parameter name=3D"scope" value=3D"session"/>
</handler>
<parameter name=3D"scope" value=3D"request"/>
<parameter name=3D"extension" value=3D".jwr"/>
</handler>
</requestFlow>
</globalConfiguration>
<handler name=3D"LocalResponder" =
type=3D"java:org.apache.axis.transport.local.LocalResponder "/>
<handler name=3D"URLMapper" =
type=3D"java:org.apache.axis.handlers.http.URLMapper"/>
<handler name=3D"Authenticate" =
type=3D"java:org.apache.axis.handlers.SimpleAuthenticationHandler "/>
<operation name=3D"getInsuredByID" qname=3D"ns1:getInsuredByID" =
returnQName=3D"ns1:getInsuredByIDReturn" returnType=3D"ns2:Insured" =
soapAction=3D"" xmlns:ns1=3D"http://aim.xyzcompany.com" =
xmlns:ns2=3D"http://beans.aim.xyzcompany.com">
<parameter qname=3D"ns1:insuredId" type=3D"xsd:string" =
xmlns:xsd=3D"http://www.w3.org/2001/XMLSchema"/>
<fault =
qname=3D"ns1:fault" type=3D"ns3:AIMServiceFatalException" =
xmlns:ns3=3D"http://exceptions.aim.xyzcompany.com"/>
</operation>
<operation name=3D"createInsured" qname=3D"ns4:createInsured" =
returnQName=3D"ns4:createInsuredReturn" returnType=3D"ns5:InsuredPK" =
soapAction=3D"" xmlns:ns4=3D"http://aim.xyzcompany.com" =
xmlns:ns5=3D"http://beans.aim.xyzcompany.com">
<parameter qname=3D"ns4:insured" type=3D"ns5:Insured"/>
<fault =
qname=3D"ns4:fault" type=3D"ns6:AIMServiceFatalException" =
xmlns:ns6=3D"http://exceptions.aim.xyzcompany.com"/>
</operation>
getInsuredByID"/>
<typeMapping =
encodingStyle=3D"" qname=3D"ns7:BaseBean" =
xmlns:ns7=3D"http://beans.aim.xyzcompany.com"/>
<typeMapping =
encodingStyle=3D"" qname=3D"ns8:Insured" =
xmlns:ns8=3D"http://beans.aim.xyzcompany.com"/>
<typeMapping =
encodingStyle=3D"" qname=3D"ns9:InsuredPK" =
xmlns:ns9=3D"http://beans.aim.xyzcompany.com"/>
<typeMapping =
encodingStyle=3D"" qname=3D"ns10:AIMServiceFatalException" =
xmlns:ns10=3D"http://exceptions.aim.xyzcompany.com"/>
</service>
<service name=3D"AdminService" provider=3D"java:MSG">
<parameter name=3D"allowedMethods" value=3D"AdminService"/>
<parameter name=3D"enableRemoteAdmin" value=3D"false"/>
<parameter name=3D"className" value=3D"org.apache.axis.utils.Admin"/>
<namespace>http://xml.apache.org/axis/wsdd/</namespace>
</service>
<service name=3D"Version" provider=3D"java:RPC">
<parameter name=3D"allowedMethods" value=3D"getVersion"/>
<parameter name=3D"className" value=3D"org.apache.axis.Version"/>
</service>
<transport name=3D"http">
<requestFlow>
<handler type=3D"URLMapper"/>
<handler =
type=3D"java:org.apache.axis.handlers.http.HTTPAuthHandler"/ >
</requestFlow>
<parameter name=3D"qs:list" =
value=3D"org.apache.axis.transport.http.QSListHandler"/>
<parameter name=3D"qs:wsdl" =
value=3D"org.apache.axis.transport.http.QSWSDLHandler"/>
<parameter name=3D"qs.list" =
<parameter name=3D"qs.method" =
value=3D"org.apache.axis.transport.http.QSMethodHandler"/>
<parameter name=3D"qs:method" =
<parameter name=3D"qs.wsdl" =
</transport>
<transport name=3D"local">
<responseFlow>
<handler type=3D"LocalResponder"/>
</responseFlow>
</transport>
</deployment>
"Seng Phung-Lu" <sengpl@ca.ibm.com> wrote in message =
news:fculg0$k0t$1@build.eclipse.org...
> Mark,
> is this severe failure reproducible given the steps you describe? I=20
> have never experienced this from the WS wizards before, and I know =
that=20
>=20
> If Eclipse or JVM crashed.. is there a java dump? Was your CPU max'd =
or=20
>=20
> If the problem continues, please do open a bug report with the steps =
you=20
>=20
>=20
> Seng
>=20
>=20
>=20
> mark wrote:
>> Hello,
>>=20
>> I am running into an issue using the WS tooling found in the WTP of =
Eclipse=20
>> 3.3 Europa. I am using JDK 1.5.0_10, Tomcat 5.5 and have everything =
set up=20
>> to where I can successfully create a WS from a simple JavaBean impl =
class w/=20
>> a single method. I have a second JavaBean impl class w/ 4 methods =
that I=20
>> want to create another service from. I run through all the dialogs =
as=20
>> before (Bottom up web service creation), I get to the page w/ the =
Start=20
>> Server button. I click it, the Server starts OK and the Next and =
Finish=20
>> buttons are enabled. When I click either one of those buttons, the =
message=20
>> about "Deploying...." shows up at the bottom of the dialog....and =
then the=20
>> entire IDE locks up (Task Manager shows "Not Responding"), nothing is =
>> written to the Eclipse Error log file and you have to "kill" the =
Eclipse=20
>> process to shut everything down...including the javaw.exe that is =
left by=20
>> the hard kill...since the Tomcat instance is running. Has anybody=20
>> experienced something like this. It appears that the deployment step =
where=20
>> the WS is deployed to Axis is dying.....yet it worked for the other =
WS which=20
>>=20
>> Any ideas would be greatly appreciated. Thanks=20
>>=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16525" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Ok...here is what I have =
tried:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>And my machine was not locked up, only =
Eclipse=20
processes were locked up. Memory usage was not maxed out. =
CPU use=20
was about 25%.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Using the following:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Europa 3.3 JEE distro</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>JDK 1.5.0_10</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Tomcat 5.5.25</FONT></DIV>
<UL>
<LI><FONT face=3DArial size=3D2>Created a new Dynamic Web =
project</FONT></LI>
<LI><FONT face=3DArial size=3D2>Called Source folder JavaSource =
instead of=20
src</FONT></LI>
<LI><FONT face=3DArial size=3D2>Added a package to =
JavaSource</FONT></LI>
<LI><FONT face=3DArial size=3D2>Added a class to that =
package</FONT></LI>
<LI><FONT face=3DArial size=3D2>Added TWO methods one taking a=20
<EM>String</EM> as a parameter and the other taking a simple custom =
object=20
called <EM>Insured</EM></FONT></LI>
<LI><FONT face=3DArial size=3D2>Right clicked on the class (java =
file), Web=20
Services -> Create Web Service</FONT></LI>
<LI><FONT face=3DArial size=3D2>Using Bottom up Java Bean Web =
Service</FONT></LI>
<LI><FONT face=3DArial size=3D2>Only the "overwrite files w/o warning" =
check box=20
is checked</FONT></LI>
<LI><FONT face=3DArial size=3D2>Slider is set to "Start =
Service"</FONT></LI>
<LI><FONT face=3DArial size=3D2>Web Service Java Bean Identity opens =
with methods=20
shown checked, document/literal (wrapped) is the "Style and use" radio =
button=20
by default</FONT></LI>
<LI><FONT face=3DArial size=3D2>Click Next and generation starts and =
stops on the=20
Start Server page</FONT></LI>
<LI><FONT face=3DArial size=3D2>Click Start server page, Conole view =
shows server=20
started...</FONT></LI>
<LI><FONT face=3DArial size=3D2>Now there is a Back, Next, Finish, and =
Cancel=20
button all enabled...I select Next or Finsih and...</FONT></LI>
<LI><FONT face=3DArial size=3D2>everything locks up...the message at =
the bottom of=20
the dialog box says: Deploying Web service to Axis run-time =
environment...=20
</FONT></LI>
<LI><FONT face=3DArial size=3D2>but now the Task Manager shows 2=20
identically-named Eclipse processes that are locked =
up:</FONT></LI></UL>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV><FONT face=3DArial size=3D2>Java -=20
aim/deploy.wsdd=20
- Eclipse Platform</FONT></DIV>
aim/deploy.wsdd=20
- Eclipse Platform</FONT></DIV></BLOCKQUOTE>
<UL dir=3Dltr>
<LI><FONT face=3DArial size=3D2>At this point, I can no longer get =
back into the=20
IDE of course...I have to do an End Process, which then brings both of =
them=20
down. The Tomcat process javaw.exe is of course still running, =
so I have=20
to go kill that manually too.</FONT></LI></UL>
<DIV><FONT face=3DArial size=3D2>MThis whole thing has me totally =
stumped. I=20
cannot get a stack trace or anything at this point. I am running =
on Win XP=20
Pro/SP2, 2GB RAM</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial color=3D#ff0000><EM><STRONG>some perhaps useful =
file=20
content:</STRONG></EM></FONT></DIV>
<DIV><EM><FONT face=3DArial size=3D2></FONT></EM> </DIV>
<DIV><FONT size=3D2><FONT=20
face=3DArial><STRONG>/WEB-INF/AIMWebServices2Service/com/xyzcompany/aim/d=
eploy.wsdd</STRONG></FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT face=3D"Courier New"><?xml version=3D"1.0"=20
encoding=3D"UTF-8"?></FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT face=3D"Courier New"><!-- Use this file to =
deploy some=20
handlers/chains and services =2 0
--></FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT face=3D"Courier New"><!-- Two ways to do=20
this: & nbsp; & n=
bsp; &n bsp; &n b=
sp; &nb sp; &nb s=
p; &nbs p;=20
<DIV><FONT size=3D2><FONT face=3D"Courier New"><!-- java=20
org.apache.axis.client.AdminClient=20
deploy.wsdd   ; =20
<DIV><FONT size=3D2><FONT face=3D"Courier =
New"> <!--   ;=20
after the axis server is=20
running &am p;nbsp; =
nbsp; =20
<DIV><FONT size=3D2><FONT face=3D"Courier New"><!--=20
or &nbs p; &nbs p=
nbsp; & nbsp; & n=
bsp; &n bsp; =20
org.apache.axis.utils.Admin client|server deploy.wsdd =20
New"> <!--   ;=20
from the same directory that the Axis engine=20
runs &n bsp; =
--><deployment=20
xmlns=3D"</FONT><A href=3D"http://xml.apache.org/axis/wsdd/"><FONT=20
face=3D"Courier New">http://xml.apache.org/axis/wsdd/</FONT></A><FONT=20
face=3D"Courier New">" xmlns:java=3D"</FONT><A=20
href=3D"http://xml.apache.org/axis/wsdd/providers/java"><FONT=20
face=3D"Courier =
New">http://xml.apache.org/axis/wsdd/providers/java</FONT></A><FONT=20
face=3D"Courier New">"></FONT></FONT></DIV>
<DIV><FONT face=3D"Courier New"></FONT> </DIV>
<DIV><FONT face=3D"Courier New" size=3D2> <!-- Services from=20
AIMWebServices2Service WSDL service --></FONT></DIV>
<DIV><FONT size=3D2><FONT face=3D"Courier New"> <service=20
name=3D"AIMWebServices2" provider=3D"java:RPC" style=3D"wrapped"=20
use=3D"literal"><BR> <parameter=20
name=3D"wsdlTargetNamespace" value=3D"</FONT><A=20
href=3D'http://aim.xyzcompany.com"/'><FONT=20
face=3D"Courier New">http://aim.xyzcompany.com"/</FONT></A><FONT=20
face=3D"Courier New">><BR> =
<parameter=20
name=3D"wsdlServiceElement"=20
value=3D"AIMWebServices2Service"/><BR> =20
<parameter name=3D"schemaQualified" value=3D"</FONT><A=20
href=3D' http://aim.xyzcompany.com,http://exceptions.aim.xyzcompany.c om,ht=
tp://beans.aim.xyzcompany.com"/'><FONT=20
face=3D"Courier =
New"> http://aim.xyzcompany.com,http://exceptions.aim.xyzcompany.c om,http:=
//beans.aim.xyzcompany.com"/</FONT></A><FONT=20
<parameter=20
name=3D"wsdlServicePort"=20
value=3D"AIMWebServices2"/><BR> =
<parameter=20
name=3D"className"=20
value=3D"com.xyzcompany.aim.AIMWebServices2"/><BR> &n=
bsp; =20
<parameter name=3D"wsdlPortType"=20
<parameter=20
name=3D"typeMappingVersion" =
value=3D"1.2"/><BR> =20
<operation xmlns:operNS=3D"</FONT><A =
href=3D"http://aim.xyzcompany.com"><FONT=20
face=3D"Courier New">http://aim.xyzcompany.com</FONT></A><FONT=20
face=3D"Courier New">" xmlns:retNS=3D"</FONT><A=20
face=3D"Courier New">" xmlns:rtns=3D"</FONT><A=20
href=3D"http://beans.aim.xyzcompany.com"><FONT=20
face=3D"Courier New">http://beans.aim.xyzcompany.com</FONT></A><FONT=20
face=3D"Courier New">" name=3D"getInsuredByID" =
qname=3D"operNS:getInsuredByID"=20
returnQName=3D"retNS:getInsuredByIDReturn" returnType=3D"rtns:Insured"=20
soapAction=3D""><BR> =
<parameter=20
xmlns:pns=3D"</FONT><A href=3D"http://aim.xyzcompany.com"><FONT=20
face=3D"Courier New">" xmlns:tns=3D"</FONT><A=20
href=3D"http://www.w3.org/2001/XMLSchema"><FONT=20
face=3D"Courier New">http://www.w3.org/2001/XMLSchema</FONT></A><FONT=20
face=3D"Courier New">" qname=3D"pns:insuredId"=20
type=3D"tns:string"/><BR> =
<fault=20
xmlns:fns=3D"</FONT><A href=3D"http://aim.xyzcompany.com"><FONT=20
href=3D"http://exceptions.aim.xyzcompany.com"><FONT=20
face=3D"Courier =
New">http://exceptions.aim.xyzcompany.com</FONT></A><FONT=20
face=3D"Courier New">" name=3D"AIMServiceFatalException" =
qname=3D"fns:fault"=20
class=3D"com.xyzcompany.aim.exceptions.AIMServiceFatalException "=20
type=3D"tns:AIMServiceFatalException"/><BR> &nb=
sp;=20
</operation><BR> <operation=20
xmlns:operNS=3D"</FONT><A href=3D"http://aim.xyzcompany.com"><FONT=20
face=3D"Courier New">" name=3D"createInsured" =
qname=3D"operNS:createInsured"=20
returnQName=3D"retNS:createInsuredReturn" returnType=3D"rtns:InsuredPK"=20
<parameter=20
face=3D"Courier New">" qname=3D"pns:insured"=20
type=3D"tns:Insured"/><BR> =
<fault=20
face=3D"Courier =
sp;=20
</operation><BR> <parameter=20
name=3D"allowedMethods" value=3D"createInsured=20
getInsuredByID"/></FONT></FONT></DIV>
New"> =20
<typeMapping xmlns:ns=3D"</FONT><A =
face=3D"Courier New">" qname=3D"ns:BaseBean"=20
type=3D"java:com.xyzcompany.aim.beans.BaseBean"=20
serializer=3D"org.apache.axis.encoding.ser.BeanSerializerFactory "=20
deserializer=3D"org.apache.axis.encoding.ser.BeanDeserializerFactory "=20
encodingStyle=3D""/><BR> =
<typeMapping=20
xmlns:ns=3D"</FONT><A href=3D"http://beans.aim.xyzcompany.com"><FONT=20
face=3D"Courier New">" qname=3D"ns:Insured"=20
type=3D"java:com.xyzcompany.aim.beans.Insured"=20
<typeMapping=20
face=3D"Courier New">" qname=3D"ns:InsuredPK"=20
type=3D"java:com.xyzcompany.aim.beans.InsuredPK"=20
<typeMapping=20
face=3D"Courier =
face=3D"Courier New">" qname=3D"ns:AIMServiceFatalException"=20
type=3D"java:com.xyzcompany.aim.exceptions.AIMServiceFatalException "=20
encodingStyle=3D""/><BR> =20
</service><BR></deployment></FONT ></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><STRONG>/WEB-INF/server-config.wsdd =
(generated by=20
Eclipse)</STRONG></FONT></DIV>
encoding=3D"UTF-8"?><BR><deployment xmlns=3D"</FONT><A=20
face=3D"Courier =
face=3D"Courier =
New">"><BR> <globalConfiguration> <BR> =20
<parameter name=3D"sendMultiRefs" value=3D"true"/><BR> =
<parameter=20
name=3D"disablePrettyXML" value=3D"true"/><BR> <parameter=20
name=3D"adminPassword" value=3D"admin"/><BR> <parameter=20
name=3D"attachments.Directory"=20
/><BR> =20
<parameter name=3D"dotNetSoapEncFix" value=3D"true"/><BR> =
<parameter=20
value=3D"false"/><BR> =20
<parameter name=3D"sendXMLDeclaration" value=3D"true"/><BR> =20
<parameter name=3D"attachments.implementation"=20
value=3D"org.apache.axis.attachments.AttachmentsImpl"/> <BR> =
<parameter=20
name=3D"sendXsiTypes" value=3D"true"/><BR> =20
<requestFlow><BR> <handler=20
type=3D"java:org.apache.axis.handlers.JWSHandler"><BR > &nbs=
p;=20
<parameter name=3D"scope" value=3D"session"/><BR> =20
</handler><BR> <handler=20
p;=20
<parameter name=3D"scope" =
value=3D"request"/><BR> =20
<parameter name=3D"extension" value=3D".jwr"/><BR> =20
</handler><BR> =20
</requestFlow><BR> </globalConfiguration> <BR> <h=
andler=20
name=3D"LocalResponder"=20
type=3D"java:org.apache.axis.transport.local.LocalResponder "/><BR>&nbs=
p;<handler=20
name=3D"URLMapper"=20
type=3D"java:org.apache.axis.handlers.http.URLMapper"/> <BR> <h=
andler=20
name=3D"Authenticate"=20
type=3D"java:org.apache.axis.handlers.SimpleAuthenticationHandler "/><B=
R> <service=20
use=3D"literal"><BR> <operation name=3D"getInsuredByID"=20
qname=3D"ns1:getInsuredByID" returnQName=3D"ns1:getInsuredByIDReturn"=20
returnType=3D"ns2:Insured" soapAction=3D"" xmlns:ns1=3D"</FONT><A=20
face=3D"Courier New">" xmlns:ns2=3D"</FONT><A=20
face=3D"Courier New">"><BR> <parameter =
qname=3D"ns1:insuredId"=20
type=3D"xsd:string" xmlns:xsd=3D"</FONT><A=20
href=3D'http://www.w3.org/2001/XMLSchema"/'><FONT=20
face=3D"Courier New">http://www.w3.org/2001/XMLSchema"/</FONT></A><FONT=20
face=3D"Courier New">><BR> <fault=20
qname=3D"ns1:fault"=20
type=3D"ns3:AIMServiceFatalException" xmlns:ns3=3D"</FONT><A=20
href=3D'http://exceptions.aim.xyzcompany.com"/'><FONT=20
face=3D"Courier =
New">http://exceptions.aim.xyzcompany.com"/</FONT></A><FONT=20
face=3D"Courier New">><BR> </operation><BR> =
<operation=20
name=3D"createInsured" qname=3D"ns4:createInsured"=20
soapAction=3D""=20
xmlns:ns4=3D"</FONT><A href=3D"http://aim.xyzcompany.com"><FONT=20
face=3D"Courier New">" xmlns:ns5=3D"</FONT><A=20
qname=3D"ns4:insured"=20
type=3D"ns5:Insured"/><BR> <fault=20
qname=3D"ns4:fault"=20
type=3D"ns6:AIMServiceFatalException" xmlns:ns6=3D"</FONT><A=20
face=3D"Courier =
<parameter=20
getInsuredByID"/><BR> =20
<parameter name=3D"typeMappingVersion" value=3D"1.2"/><BR> =
<parameter=20
name=3D"wsdlPortType" value=3D"AIMWebServices2"/><BR> =
<parameter=20
value=3D"com.xyzcompany.aim.AIMWebServices2"/><BR> =20
<parameter name=3D"wsdlServicePort" =
value=3D"AIMWebServices2"/><BR> =20
face=3D"Courier =
face=3D"Courier New">><BR> <parameter =
name=3D"wsdlTargetNamespace"=20
value=3D"</FONT><A href=3D'http://aim.xyzcompany.com"/'><FONT=20
value=3D"AIMWebServices2Service"/><BR> <typeMapping=20
encodingStyle=3D"" qname=3D"ns7:BaseBean"=20
type=3D"java:com.xyzcompany.aim.beans.BaseBean" xmlns:ns7=3D"</FONT><A=20
href=3D'http://beans.aim.xyzcompany.com"/'><FONT=20
face=3D"Courier New">http://beans.aim.xyzcompany.com"/</FONT></A><FONT=20
face=3D"Courier New">><BR> <typeMapping=20
encodingStyle=3D"" qname=3D"ns8:Insured"=20
type=3D"java:com.xyzcompany.aim.beans.Insured" xmlns:ns8=3D"</FONT><A=20
encodingStyle=3D"" qname=3D"ns9:InsuredPK"=20
type=3D"java:com.xyzcompany.aim.beans.InsuredPK" xmlns:ns9=3D"</FONT><A=20
encodingStyle=3D"" qname=3D"ns10:AIMServiceFatalException"=20
xmlns:ns10=3D"</FONT><A =
face=3D"Courier =
face=3D"Courier New">><BR> </service><BR> <service =
name=3D"AdminService" provider=3D"java:MSG"><BR> <parameter=20
name=3D"allowedMethods" value=3D"AdminService"/><BR> =
<parameter=20
name=3D"enableRemoteAdmin" value=3D"false"/><BR> <parameter=20
name=3D"className" value=3D"org.apache.axis.utils.Admin"/><BR> =20
<namespace>http://xml.apache.org/axis/wsdd/</namespace><BR>&n=
bsp;</service><BR> <service=20
name=3D"Version" provider=3D"java:RPC"><BR> <parameter=20
name=3D"allowedMethods" value=3D"getVersion"/><BR> =
<parameter=20
value=3D"org.apache.axis.Version"/><BR> </service> <BR> =
;<transport=20
name=3D"http"><BR> <requestFlow><BR> =
<handler=20
type=3D"URLMapper"/><BR> <handler=20
type=3D"java:org.apache.axis.handlers.http.HTTPAuthHandler"/> <BR> =
;=20
</requestFlow><BR> <parameter name=3D"qs:list"=20
value=3D"org.apache.axis.transport.http.QSListHandler"/> <BR> =20
<parameter name=3D"qs:wsdl"=20
value=3D"org.apache.axis.transport.http.QSWSDLHandler"/> <BR> =20
<parameter name=3D"qs.list"=20
<parameter name=3D"qs.method"=20
value=3D"org.apache.axis.transport.http.QSMethodHandler"/> <BR> =20
<parameter name=3D"qs:method"=20
<parameter name=3D"qs.wsdl"=20
value=3D"org.apache.axis.transport.http.QSWSDLHandler"/> <BR> <=
/transport><BR> <transport=20
name=3D"local"><BR> <responseFlow><BR> =
<handler=20
type=3D"LocalResponder"/><BR> =20
</responseFlow><BR> </transport> <BR></deployment><=
/FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"Seng Phung-Lu" <</FONT><A=20
href=3D"mailto:sengpl@ca.ibm.com"><FONT face=3DArial=20
size=3D2>sengpl@ca.ibm.com</FONT></A><FONT face=3DArial size=3D2>> =
wrote in message=20
</FONT><A href=3D"news:fculg0$k0t$1@build.eclipse.org"><FONT =
fa
Re: WTP Issue - Axis WS deployment locks up Eclipse 3.3 [message #200292 is a reply to message #200151] |
Sun, 23 September 2007 16:21 |
------=_NextPart_000_000B_01C7FDDC.36F72EF0
I have opened a bug on the Eclipse Bugzilla site - bug # 204204 as I am =
getting no where with this issue. I have had it work ok at first say w/ =
a WS containing a couple of methods. Then I start adding methods or =
additional jars that may be in needed in WEB-INF/lib for the project. =
Right-click on the java bean class and start the whole generation =
seqeuence again...only to then have it lock up in the Axis deployment =
phase.
"mark" <mcs130@gmail.com> wrote in message =
news:fcus5q$vu5$1@build.eclipse.org...
And my machine was not locked up, only Eclipse processes were locked =
up. Memory usage was not maxed out. CPU use was about 25%.
JDK 1.5.0_10
Tomcat 5.5.25
a.. Created a new Dynamic Web project=20
b.. Called Source folder JavaSource instead of src=20
c.. Added a package to JavaSource=20
d.. Added a class to that package=20
e.. Added TWO methods one taking a String as a parameter and the =
other taking a simple custom object called Insured=20
f.. Right clicked on the class (java file), Web Services -> Create =
Web Service=20
g.. Using Bottom up Java Bean Web Service=20
h.. Only the "overwrite files w/o warning" check box is checked=20
i.. Slider is set to "Start Service"=20
default=20
page=20
l.. Click Start server page, Conole view shows server started...=20
enabled...I select Next or Finsih and...=20
n.. everything locks up...the message at the bottom of the dialog =
box says: Deploying Web service to Axis run-time environment...=20
Java - =
Java - =
a.. At this point, I can no longer get back into the IDE of =
course...I have to do an End Process, which then brings both of them =
down. The Tomcat process javaw.exe is of course still running, so I =
have to go kill that manually too.
MThis whole thing has me totally stumped. I cannot get a stack trace =
or anything at this point. I am running on Win XP Pro/SP2, 2GB RAM
<!-- Use this file to deploy some handlers/chains and services =
<!-- Two ways to do this: =
<!-- java org.apache.axis.client.AdminClient deploy.wsdd =
<!-- after the axis server is running =
<!-- or =
<!-- java org.apache.axis.utils.Admin client|server deploy.wsdd =
soapAction=3D"">
</operation>
</operation>
getInsuredByID"/>
</service>
</deployment>
value=3D"false"/>
<requestFlow>
</handler>
</handler>
</requestFlow>
<fault =
</operation>
<fault =
</operation>
getInsuredByID"/>
<typeMapping =
<typeMapping =
<typeMapping =
<typeMapping =
</service>
</service>
</service>
<requestFlow>
<handler =
</requestFlow>
</transport>
<responseFlow>
</responseFlow>
</transport>
</deployment>
> Mark,
> is this severe failure reproducible given the steps you describe? I =
that=20
>=20
or=20
>=20
you=20
>=20
>=20
> Seng
>=20
>=20
>=20
> mark wrote:
>> Hello,
>>=20
Eclipse=20
>> 3.3 Europa. I am using JDK 1.5.0_10, Tomcat 5.5 and have =
everything set up=20
class w/=20
that I=20
as=20
Start=20
Finish=20
message=20
then the=20
>> entire IDE locks up (Task Manager shows "Not Responding"), nothing =
is=20
Eclipse=20
left by=20
>> experienced something like this. It appears that the deployment =
step where=20
WS which=20
>>=20
>>=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I have opened a bug on the Eclipse =
Bugzilla site -=20
bug # 204204 as I am getting no where with this issue. I have had =
it work=20
ok at first say w/ a WS containing a couple of methods. Then I =
start=20
adding methods or additional jars that may be in needed in WEB-INF/lib =
for the=20
project. Right-click on the java bean class and start the whole =
generation=20
seqeuence again...only to then have it lock up in the Axis deployment=20
phase.</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"mark" <<A =
href=3D"mailto:mcs130@gmail.com">mcs130@gmail.com</A>>=20
wrote in message <A=20
href=3D"news:fcus5q$vu5$1@build.eclipse.org">news:fcus5q$vu5$1@build.ecli=
pse.org</A>...</DIV>
tried:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>And my machine was not locked up, =
only Eclipse=20
CPU use=20
<UL>
project</FONT>=20
instead of=20
src</FONT>=20
<LI><FONT face=3DArial size=3D2>Added a package to JavaSource</FONT> =
<LI><FONT face=3DArial size=3D2>Added a class to that package</FONT> =
object=20
called <EM>Insured</EM></FONT>=20
file), Web=20
Services -> Create Web Service</FONT>=20
Service</FONT>=20
<LI><FONT face=3DArial size=3D2>Only the "overwrite files w/o =
warning" check box=20
is checked</FONT>=20
Service"</FONT>=20
with=20
methods shown checked, document/literal (wrapped) is the "Style and =
use"=20
radio button by default</FONT>=20
stops on=20
the Start Server page</FONT>=20
shows=20
server started...</FONT>=20
<LI><FONT face=3DArial size=3D2>Now there is a Back, Next, Finish, =
and Cancel=20
button all enabled...I select Next or Finsih and...</FONT>=20
the bottom=20
of the dialog box says: Deploying Web service to Axis run-time=20
environment... </FONT>
aim/deploy.wsdd=20
aim/deploy.wsdd=20
<UL dir=3Dltr>
back into the=20
IDE of course...I have to do an End Process, which then brings both =
of them=20
so I=20
have to go kill that manually too.</FONT></LI></UL>
stumped. I=20
on Win=20
XP Pro/SP2, 2GB RAM</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial color=3D#ff0000><EM><STRONG>some perhaps =
useful file=20
<DIV><FONT size=3D2><FONT face=3D"Courier New"><?xml =
version=3D"1.0"=20
<DIV><FONT size=3D2><FONT face=3D"Courier New"><!-- Use this file =
to deploy=20
some handlers/chains and services =2 0
this: & nbsp; & n=
bsp; &n bsp; &n b=
sp; &nb sp; &nb s=
p; &nbs p;=20
<DIV><FONT size=3D2><FONT face=3D"Courier New"><!-- =
java=20
deploy.wsdd   ; =20
face=3D"Courier New"> <!--   ; after the =
axis server=20
is=20
nbsp; =20
or &nbs p; &nbs p=
nbsp; & nbsp; & n=
bsp; &n bsp; =20
java=20
face=3D"Courier New"> <!--   ; from the =
same=20
runs &n bsp; =
--><deployment=20
face=3D"Courier =
<parameter=20
face=3D"Courier =
<parameter=20
<parameter=20
bsp; =20
<parameter=20
<parameter=20
<fault=20
face=3D"Courier =
sp;=20
<parameter=20
type=3D"tns:Insured"/><BR> =20
<fault xmlns:fns=3D"</FONT><A =
face=3D"Courier =
sp;=20
New"> =20
<typeMapping xmlns:ns=3D"</FONT><A=20
<typeMapping=20
<typeMapping=20
<typeMapping=20
face=3D"Courier =
(generated by=20
version=3D"1.0"=20
face=3D"Courier =
face=3D"Courier =
<parameter=20
/><BR> =20
<parameter name=3D"dotNetSoapEncFix" value=3D"true"/><BR> =20
<parameter name=3D"enableNamespacePrefixOptimization"=20
value=3D"false"/><BR> <parameter =
name=3D"sendXMLDeclaration"=20
value=3D"true"/><BR> <parameter =
value=3D"org.apache.axis.attachments.AttachmentsImpl"/> <BR> =20
<parameter name=3D"sendXsiTypes" value=3D"true"/><BR> =20
p;=20
p;=20
</handler><BR> =20
andler=20
p;<handler=20
andler=20
R> <service=20
face=3D"Courier =
face=3D"Courier =
<operation=20
soapAction=3D""=20
face=3D"Courier =
<parameter=20
<parameter name=3D"wsdlPortType" =
<parameter name=3D"className"=20
<parameter=20
name=3D"wsdlServicePort" value=3D"AIMWebServices2"/><BR> =
<parameter=20
face=3D"Courier =
type=3D"java:com.xyzcompany.aim.beans.BaseBean" xmlns:ns7=3D"</FONT><A =
face=3D"Courier New">http://beans.aim.xyzcompany.com"/</FONT></A><FONT =
face=3D"Courier =
face=3D"Courier =
New">><BR> </service><BR> <service=20
name=3D"AdminService" provider=3D"java:MSG"><BR> =
<parameter=20
<parameter=20
Current Time: Sun Apr 28 17:21:03 GMT 2024
Powered by FUDForum. Page generated in 0.03805 seconds
