Home » Newcomers » Newcomers » getFontRegistry problem
getFontRegistry problem [message #199999] Sat, 17 March 2007 03:07 Go to next message
Originally posted by: waynel.mannywhere.com
HI!!
I am trying to use the the Jface Fontregistry and no matter what I do I
keeping get the same failure.
To make sure it isn't my code I went to
http://www.java2s.com/Code/Java/SWT-JFace-Eclipse/SWTFontReg istryExample.htm
and got their example and it fails in the same place as my code.
import org.eclipse.jface.resource.FontRegistry;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.FontData;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class FontRegistryExample {
Display display = new Display();
Shell shell = new Shell(display);
FontRegistry fontRegistry;
public FontRegistryExample() {
init();
shell.pack();
shell.open();
//textUser.forceFocus();
// Set up the event loop.
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
// If no more entries in event queue
display.sleep();
display.dispose();
private void init() {
shell.setLayout(new GridLayout(2, false));
fontRegistry = new FontRegistry(display);
fontRegistry.put("button-text", new FontData[]{new FontData("Arial",
9, SWT.BOLD)} );
fontRegistry.put("code", new FontData[]{new FontData("Courier New",
10, SWT.NORMAL)});
Text text = new Text(shell, SWT.MULTI | SWT.BORDER | SWT.WRAP);
text.setFont(fontRegistry.get("code"));
text.setForeground(display.getSystemColor(SWT.COLOR_BLUE));
text.setText("public static void main()
{\n\tSystem.out.println(\"Hello\"); \n}");
GridData gd = new GridData(GridData.FILL_BOTH);
gd.horizontalSpan = 2;
text.setLayoutData(gd);
Button executeButton = new Button(shell, SWT.PUSH);
executeButton.setText("Execute");
executeButton.setFont(fontRegistry.get("button-text"));
Button cancelButton = new Button(shell, SWT.PUSH);
cancelButton.setText("Cancel");
cancelButton.setFont(fontRegistry.get("button-text"));
new FontRegistryExample();
The code always fails at
with this error
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/core/commands/common/EventManager
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at FontRegistryExample.init(FontRegistryExample.java:41)
at FontRegistryExample.<init>(FontRegistryExample.java:21)
I would apprieciate any help its beginning to get on my nerves.
Re: getFontRegistry problem [message #200038 is a reply to message #199999] Sat, 17 March 2007 08:34 Go to previous messageGo to next message
Wayne,
Are you running standalone or as an Eclipse/OSGi application? If
standalone, do you have the jar containing EventManager on the
classpath? If OSGi, do you have the right plugin dependencies set in
your plugins MANIFEST.MF?
Wayne LaRochelle wrote:
> HI!!
> I keeping get the same failure.
> import org.eclipse.swt.widgets.Display;
> init();
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
> FontData("Arial", 9, SWT.BOLD)} );
> New", 10, SWT.NORMAL)});
> SWT.WRAP);
> public static void main(String[] args) {
> with this error
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
Re: getFontRegistry problem [message #200062 is a reply to message #200038] Sat, 17 March 2007 11:16 Go to previous messageGo to next message
HI!! ED
Thanks for responding. I am converting a number of museum exhibits from
OpenGL to java so we can put them on the Internet.
I am using Eclipse3.2.2 and am currently testing from within Eclipse,
the plan is to eventually turn the code into an application.
1: which jar contains the EventManager
2: for a standalone application the references all say I need jface.jar
but I can't find it anywhere.
WAYNEL
Ed Merks wrote:
> Wayne,
>> HI!!
>> init();
>> shell.pack();
>> shell.open();
>> display.sleep();
>> display.dispose();
>> SWT.WRAP);
>> with this error
Re: getFontRegistry problem [message #200085 is a reply to message #200062] Sat, 17 March 2007 12:26 Go to previous messageGo to next message
Wayne,
EventManager is in org.eclipse.core.commands*.jar. You should find
org.eclipse.jface*.jar in the plugins folder of your eclipse installation.
user@domain.invalid wrote:
> HI!! ED
> from OpenGL to java so we can put them on the Internet.
> jface.jar but I can't find it anywhere.
> Thanks
> WAYNEL
> Ed Merks wrote:
>> Wayne,
>>> HI!!
>>> do I keeping get the same failure.
>>> init();
>>> shell.pack();
>>> shell.open();
>>> display.sleep();
>>> display.dispose();
>>> FontData("Courier New", 10, SWT.NORMAL)});
>>> SWT.WRAP);
>>> with this error
Re: getFontRegistry problem [message #200100 is a reply to message #200085] Sat, 17 March 2007 13:23 Go to previous message
HI!!
that was it.
Thank you very much
WAYNEL
Ed Merks wrote:
> Wayne,
>> HI!! ED
>> Thanks
>> WAYNEL
>> Ed Merks wrote:
>>> Wayne,
>>>> HI!!
>>>> init();
>>>> shell.pack();
>>>> shell.open();
>>>> display.sleep();
>>>> display.dispose();
>>>> SWT.WRAP);
>>>> with this error
Previous Topic:swt not found
Next Topic:Build numbers
Current Time: Tue Jul 22 02:34:49 EDT 2025
Powered by FUDForum. Page generated in 0.06830 seconds
