Home » Archived » BIRT » JOnAS - IReportEngineFactory - NullPointerException
JOnAS - IReportEngineFactory - NullPointerException [message #199993] Thu, 09 November 2006 11:20 Go to next message
Originally posted by: don_gatos.hotmail.com
I have a problem when I'm deploying my ear to JOnAS application server
v4.6.6.
I tested the same ear in jboss and it works fine.
I'm using birt v2.1.1.
The problem is that
Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
returns null.
I know that it's a common problem but I can't find the solution.
Thanks for your help!
war structure:
/WebContent
/Images
/Reports
/WEB-INF
/lib
/platform
/configuration
/plugins
Files in lib:
axis.jar
axis-ant.jar
chartengine.api
com.ibm.icu_3.4.4.1.jar
commons-cli-1.0.jar
commons-codec-1.3.jar
commons-discovery-0.2.jar
coreapi.jar
dataadapterapi.jar
dteapi.jar
engineapi.jar
flute.jar
jaxrpc.jar
js.jar
modelapi.jar
org.eclipse.emf.common_2.2.0.v200606051102.jar
org.eclipse.emf.ecore.xmi_2.2.0.v200606051102.jar
org.eclipse.emf.ecore_2.2.0.v200606051102.jar
saaj.jar
sac.jar
scriptapi.jar
viewservlets.jar
wsdl4j-1.5.1.jar
files in configuration:
config.ini
files and folders in plugins:
com.lowagie.itext
org.apache.batik
org.apache.batik.pdf
org.apache.commons.codec
org.apache.derby.core
org.apache.xerces
org.eclipse.birt.data.oda_2.1.1.v20060922-1058
org.eclipse.birt.report.data.oda.jdbc_2.1.1.v20060922-1058
org.eclipse.birt.report.data.oda.sampledb_2.1.1.v20060922-10 58
org.eclipse.birt.report.engine.fonts_2.1.1.v20060926-0959
org.eclipse.core.runtime.compatibility.registry_3.2.0.v20060 602
org.mozilla.rhino
org.w3c.sac
org.eclipse.birt.chart.device.extension_2.1.1.v20060921-1226 .jar
org.eclipse.birt.chart.engine.extension_2.1.1.v20060926-0959 .jar
org.eclipse.birt.chart.engine_2.1.1.v20060922-1058.jar
org.eclipse.birt.chart.reportitem_2.1.1.v20060921-1226.jar
org.eclipse.birt.core_2.1.1.v20060926-0959.jar
org.eclipse.birt.data_2.1.1.v20060922-1058.jar
org.eclipse.birt.report.data.adapter_2.1.1.v20060922-1058.ja r
org.eclipse.birt.report.data.oda.xml_2.1.1.v20060926-0959.ja r
org.eclipse.birt.report.engine.emitter.html_2.1.1.v20060926- 0959.jar
org.eclipse.birt.report.engine.emitter.pdf_2.1.1.v20060926-0 959.jar
org.eclipse.birt.report.engine_2.1.1.v20060926-0959.jar
org.eclipse.birt.report.model_2.1.1.v20060926-0959.jar
org.eclipse.core.contenttype_3.2.0.v20060601a.jar
org.eclipse.core.jobs_3.2.0.v20060601a.jar
org.eclipse.core.runtime.compatibility_3.1.100.v20060601a.ja r
org.eclipse.core.runtime_3.2.0.v20060601b.jar
org.eclipse.datatools.connectivity.oda.consumer_3.0.2.200608 301.jar
org.eclipse.datatools.connectivity.oda.flatfile_3.0.2.200608 311.jar
org.eclipse.datatools.connectivity.oda_3.0.2.200608301.jar
org.eclipse.emf_2.2.0.v200606051102.jar
org.eclipse.equinox.common_3.2.0.v20060601a.jar
org.eclipse.equinox.preferences_3.2.0.v20060601.jar
org.eclipse.equinox.registry_3.2.0.v20060601.jar
org.eclipse.osgi_3.2.0.v20060601.jar
org.eclipse.update.configurator_3.2.0.v20060511.jar
This is the servlet:
public class ReportServlet extends javax.servlet.http.HttpServlet
implements javax.servlet.Servlet {
private static final long serialVersionUID = 1L;
private static Properties reportClasses = new Properties();
private static final String reportClassesFile =
"reportClasses.properties";
private static final String REPORT_TYPE_HTML = "html";
private static final String REPORT_TYPE_PDF = "pdf";
/* (non-Javadoc)
* @see javax.servlet.GenericServlet#init()
public void init() throws ServletException {
super.init();
BirtEngine.getInstance(getServletContext());
loadReportClasses();
private static void loadReportClasses() {
try {
ClassLoader cl = Thread.currentThread().getContextClassLoader();
InputStream in = cl.getResourceAsStream(reportClassesFile);
reportClasses.load(in);
in.close();
} catch (IOException e) {
e.printStackTrace();
/* (non-Javadoc)
* @see javax.servlet.GenericServlet#destroy()
public void destroy() {
super.destroy();
BirtEngine.destroyBirtEngine();
private static IReport getReport(String reportName)
throws Exception{
String reportClassName = reportClasses.getProperty(reportName);
Class reportClass = Class.forName(reportClassName);
return (IReport) reportClass.newInstance();
/* (non-Java-doc)
* @see javax.servlet.http.HttpServlet#doGet(HttpServletRequest request,
HttpServletResponse response)
protected void doGet(HttpServletRequest request, HttpServletResponse
response)
throws ServletException, IOException {
String reportName = request.getParameter("ReportName");
IReport report = null;
try{
report = getReport(reportName);
} catch (Exception e) {
throw new ServletException(e);
report.setReportName(reportName);
report.setRequest(request);
String reportType = request.getParameter("ReportType");
if(REPORT_TYPE_PDF.equalsIgnoreCase(reportType)){
report.setReportType(IReport.PDF_FORMAT);
response.setContentType( "application/pdf" );
response.setHeader ("Content-Disposition","inline;
filename=report.pdf");
} else {
report.setReportType(IReport.HTML_FORMAT);
response.setContentType("text/html");
try{
report.generate(response.getOutputStream());
And this is the BirtEngine class:
public class BirtEngine {
private static IReportEngine birtEngine = null;
private static Properties configProps = new Properties();
private final static String configFile = "BirtConfig.properties";
public synchronized static IReportEngine getInstance(ServletContext sc){
if (birtEngine == null){
loadEngineProps();
EngineConfig config = new EngineConfig();
if (configProps != null) {
String logDirectory = configProps.getProperty("logDirectory");
String logLevel = configProps.getProperty("logLevel");
Level level = Level.OFF;
if ("SEVERE".equalsIgnoreCase(logLevel)) {
level = Level.SEVERE;
} else if ("WARNING".equalsIgnoreCase(logLevel)) {
level = Level.WARNING;
} else if ("INFO".equalsIgnoreCase(logLevel)) {
level = Level.INFO;
} else if ("CONFIG".equalsIgnoreCase(logLevel)) {
level = Level.CONFIG;
} else if ("FINE".equalsIgnoreCase(logLevel)) {
level = Level.FINE;
} else if ("FINER".equalsIgnoreCase(logLevel)) {
level = Level.FINER;
} else if ("FINEST".equalsIgnoreCase(logLevel)) {
level = Level.FINEST;
} else if ("OFF".equalsIgnoreCase(logLevel)) {
level = Level.OFF;
} else if ("ALL".equalsIgnoreCase(logLevel)){
level = Level.ALL;
config.setLogConfig(logDirectory, level);
config.setEngineHome("");
// System.out.println("real path: " + sc.getRealPath("/WEB-INF"));
// config.setEngineHome(sc.getRealPath("/WEB-INF"));
IPlatformContext context = new PlatformServletContext(sc);
config.setPlatformContext(context);
try {
Platform.startup(config);
} catch (BirtException e) {
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_E NGINE_FACTORY);
birtEngine = factory.createReportEngine(config);
return birtEngine;
public static synchronized void destroyBirtEngine() {
if (birtEngine == null) {
return;
birtEngine.shutdown();
Platform.shutdown();
birtEngine = null;
/* (non-Javadoc)
* @see java.lang.Object#finalize()
protected void finalize() throws Throwable {
super.finalize();
/* (non-Javadoc)
* @see java.lang.Object#clone()
public Object clone() throws CloneNotSupportedException {
throw new CloneNotSupportedException();
private static void loadEngineProps() {
try {
InputStream in = cl.getResourceAsStream(configFile);
configProps.load(in);
in.close();
This is the error:
2006-11-09 12:38:11,359 : INFO : main : AbsApplicationModifier.modify :
Processing Application testBirt.ear
2006-11-09 12:38:11,359 : INFO : main : WebAppModifier.modify :
Processing WebApp testBirtWeb.war
2006-11-09 12:38:40,156 : SEVERE : main : ApplicationContext.log :
StandardWrapper.Throwable
at com.gscapusio.test.birt.BirtEngine.getInstance(BirtEngine.ja va:72)
com.gscapusio.test.birt.servlets.ReportServlet.init(ReportSe rvlet.java:33)
at javax.servlet.GenericServlet.init(GenericServlet.java:256)
at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil .java:243)
at javax.security.auth.Subject.doAsPrivileged(Subject.java:500)
org.apache.catalina.security.SecurityUtil.execute(SecurityUt il.java:275)
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Secu rityUtil.java:161)
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Secu rityUtil.java:114)
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:1085)
at org.apache.catalina.core.StandardWrapper.load(StandardWrappe r.java:925)
org.apache.catalina.core.StandardContext.loadOnStartup(Stand ardContext.java:3880)
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4141)
org.objectweb.jonas.web.catalina55.JOnASStandardContext.star t(JOnASStandardContext.java:221)
org.apache.catalina.core.ContainerBase.addChildInternal(Cont ainerBase.java:759)
org.apache.catalina.core.ContainerBase.access$000(ContainerB ase.java:121)
org.apache.catalina.core.ContainerBase$PrivilegedAddChild.ru n(ContainerBase.java:143)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBas e.java:737)
at org.apache.catalina.core.StandardHost.addChild(StandardHost. java:524)
org.objectweb.jonas.web.catalina55.CatalinaJWebContainerServ iceImpl.doRegisterWar(CatalinaJWebContainerServiceImpl.java: 570)
org.objectweb.jonas.web.AbsJWebContainerServiceImpl.register War(AbsJWebContainerServiceImpl.java:839)
org.objectweb.jonas.web.AbsJWebContainerServiceImpl.deployWa rs(AbsJWebContainerServiceImpl.java:1290)
org.objectweb.jonas.web.wrapper.catalina55.CatalinaJWebConta inerServiceWrapper.invoke(CatalinaJWebContainerServiceWrappe r.java:157)
org.objectweb.jonas.web.wrapper.catalina55.CatalinaJWebConta inerServiceWrapper.deployWars(CatalinaJWebContainerServiceWr apper.java:123)
org.objectweb.jonas.ear.EarServiceImpl.deployEar(EarServiceI mpl.java:974)
org.objectweb.jonas.ear.EarServiceImpl.doStart(EarServiceImp l.java:1281)
org.objectweb.jonas.service.AbsServiceImpl.start(AbsServiceI mpl.java:80)
org.objectweb.jonas.service.ServiceManager.startServices(Ser viceManager.java:336)
at org.objectweb.jonas.server.Server.start(Server.java:532)
at org.objectweb.jonas.server.Server.main(Server.java:181)
at org.objectweb.jonas.server.Bootstrap.main(Bootstrap.java:97)
Re: JOnAS - IReportEngineFactory - NullPointerException [message #200025 is a reply to message #199993] Thu, 09 November 2006 13:43 Go to previous messageGo to next message
I think you may find the reason for this exception in your application
server's error log. One of the reasons for the NullPointerException can
be that the framework was not started successfully. Please check if you
see any stack traces (mostly for the method Platform.startup) in the
application server's error log.
Deepa
Gaston Scapusio wrote:
> v4.6.6.
> The problem is that
> returns null.
> war structure:
> /WebContent
> /Images
> /Reports
> /WEB-INF
> /lib
> /platform
> /configuration
> /plugins
> Files in lib:
> axis.jar
> axis-ant.jar
> chartengine.api
> commons-cli-1.0.jar
> coreapi.jar
> dataadapterapi.jar
> dteapi.jar
> engineapi.jar
> flute.jar
> jaxrpc.jar
> js.jar
> modelapi.jar
> saaj.jar
> sac.jar
> scriptapi.jar
> viewservlets.jar
> wsdl4j-1.5.1.jar
> config.ini
> com.lowagie.itext
> org.apache.batik
> org.apache.xerces
> org.mozilla.rhino
> org.w3c.sac
> /* (non-Javadoc)
> super.init();
> try {
> ClassLoader cl =
> in.close();
> /* (non-Javadoc)
> super.destroy();
> throws Exception{
> /* (non-Java-doc)
> request, HttpServletResponse response)
> response) throws ServletException, IOException {
> try{
> } else {
> try{
> sc){
> loadEngineProps();
> level = Level.INFO;
> level = Level.FINE;
> level = Level.OFF;
> level = Level.ALL;
> try {
> return birtEngine;
> return;
> birtEngine = null;
> /* (non-Javadoc)
> super.finalize();
> /* (non-Javadoc)
> try {
> ClassLoader cl =
> in.close();
> This is the error:
> : Processing Application testBirt.ear
> java.lang.NullPointerException
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: JOnAS - IReportEngineFactory - NullPointerException [message #200048 is a reply to message #200025] Thu, 09 November 2006 14:26 Go to previous message
Deepa,
It doesn't throw errors. This is way I don't know what to do.
Gaston
Previous Topic:NULL pointer when trying to saveas() report
Next Topic:Deploy problem to EAServer 5.2
Current Time: Mon Jul 21 21:36:03 EDT 2025
Powered by FUDForum. Page generated in 0.07747 seconds
