Home » Modeling » GMF (Graphical Modeling Framework) » Drag-drop from Project Explorer to Diagram
Drag-drop from Project Explorer to Diagram [message #199979] Mon, 04 August 2008 01:15 Go to next message
I am trying to implement drag and drop from model nodes in the Project
Explorer tree (generated with GMF's navigator generator) into an open
GMF model diagram. For example:
project
- foo.model
- Component A
- Component B
- Child C
- another.model
If I have foo.model_diagram or another.model_diagram currently open, I'd
like to be able to drag and drop any of the Components or Children onto
the window.
So far I have worked out that I need to add a DragSourceListener onto
the Project Explorer window (somehow), and a resulting
DropTargetListener onto the ViewPart, using a custom Transfer class
based likely on SimpleObjectTransfer. Is this right?
How can I reference the Project Explorer window to register an
additional DragSourceListener? Or am I going the wrong way about this
(mixing GMF/GEF with SWT/Eclipse)?
Is there an example I could build upon? The Logic example allows for
drag-dropping items within the Outline view, but doesn't link up with
the Navigator or allow drag-drop from outline view to current view window.
Currently I can handle IResource drag-drops (ResourceTransfer) (I
think), but these aren't helpful because the data is set to null when
dragging one of the model components, so I can't see what was actually
dragged.
Thanks for any help.
Jevon
Re: Drag-drop from Project Explorer to Diagram [message #200049 is a reply to message #199979] Mon, 04 August 2008 06:09 Go to previous messageGo to next message
Hello Jevon,
This functionality can be generated by GMF for you. You have to set "shortcutsProvidedFor"/"containsShortcutsTo"
properties in accordance with http://wiki.eclipse.org/GMF_GenModel_Hints#GenDiagram
and regenerate diagram code. As a result "shortcut" to the dropped element
should be created on underlying diagram on D&D from the model navigator to
the diagam.
Alex Shatalin
Re: Drag-drop from Project Explorer to Diagram [message #200254 is a reply to message #200049] Tue, 05 August 2008 01:30 Go to previous messageGo to next message
Wow, thanks Alex! That works perfectly!
Jevon
Alex Shatalin wrote:
> Hello Jevon,
> "shortcutsProvidedFor"/"containsShortcutsTo" properties in accordance
> with http://wiki.eclipse.org/GMF_GenModel_Hints#GenDiagram and
> to the diagam.
> Alex Shatalin
Re: Drag-drop from Project Explorer to Diagram [message #207586 is a reply to message #200254] Wed, 01 October 2008 02:26 Go to previous messageGo to next message
Originally posted by: manojm.blr.interrasystems.com
Hi!
I am also facing kind of same problem.
I want to implement DnD, from different medel to GMF editor.
Could you please help?
Manoj
> Jevon
>> Hello Jevon,
>> navigator to the diagam.
>> Alex Shatalin
Re: Drag-drop from Project Explorer to Diagram [message #207627 is a reply to message #207586] Wed, 01 October 2008 08:16 Go to previous messageGo to next message
Hello Manoj,
You can use GMF-generated as an example of D&D implementation and try doing
the same in with different model view/editor..
Alex Shatalin
Re: Drag-drop from Project Explorer to Diagram [message #207635 is a reply to message #207627] Wed, 01 October 2008 09:50 Go to previous message
Thanks Alex,
But how should I make my editor aware of the fact, that the dropped
element is from other model?
Please provide me some clue.
Manoj
> Hello Manoj,
> doing the same in with different model view/editor..
> Alex Shatalin
Previous Topic:Scheme editor, ecore to gmf
Next Topic:How to create Share EditingDomain: Should all the metamodelType be replaced by specializationType in
Current Time: Thu Jul 17 19:54:09 EDT 2025
Powered by FUDForum. Page generated in 0.03750 seconds
