Home » Eclipse Projects » Eclipse Platform » .config folder in installation directory
.config folder in installation directory [message #199724] Mon, 23 February 2004 06:28 Go to next message
Originally posted by: th.huebner.sap.corp
It's desired that the .config folder always is created in installation
directory?
If this folder doesn't exist it will be create with new start of Eclipse.
In the case that only the administrator can write in installation directory
the
develeoper must have administrator rights on his machine to create the
..config folder.
I think it does not make sense that the developer must have administrator
rights
to work with Eclipse. In Eclipse 2.1.x the config folder was created in the
workspace folder, which could be user specified.
Best regards
Thomas
Re: .config folder in installation directory [message #199734 is a reply to message #199724] Mon, 23 February 2004 08:01 Go to previous message
Originally posted by: pascal.rapicault.ibm
You apparently did not try to make your install read only ;-)
Indeed the .config folder will be created in a subfolder of the
user.home if it can't get written in the install folder.
You can also specify it using -configuration.
PaScaL
Thomas Hübner wrote:
> directory?
> the
> .config folder.
> rights
> Best regards
> Thomas
Previous Topic:CVS Compare work one way but not the other
Next Topic:Re: [eclipse-dev] hand over system properties ( java -Dx=y ) to e clipse exe?
Current Time: Tue Jul 22 02:43:18 EDT 2025
Powered by FUDForum. Page generated in 0.04991 seconds
