Home » Modeling » Epsilon » SVN without subversive?
SVN without subversive? [message #19044] Tue, 02 June 2009 10:30 Go to next message
Hi there again,
I was just wondering whether it was possible to use the development
Epsilon from the SVN without having to first load Eclipse to pick up the
plugins, and then spawn another child Eclipse to make use of them? E.g.,
use another SVN client (e.g., tortoise) to download them into the Eclipse
plugins directory, so on initial startup it sees them (I've had a go at
this but failed :) )
This is only a small query, and I'm able to work -- but was just wondering
anyway as my poor laptop is begging for some more memory :)
Edd
Re: SVN without subversive? [message #19279 is a reply to message #19044] Tue, 02 June 2009 10:41 Go to previous messageGo to next message
Hi Edd,
Unfortunately, I'm not aware of a way to do this.
However, except for the stable update site, there is also the interim
update site which we update a lot more often (e.g. after fixing a bug or
adding a minor new feature):
http://download.eclipse.org/modeling/gmt/epsilon/interim/
Dimitris
Edward Turner wrote:
> Hi there again,
> Eclipse plugins directory, so on initial startup it sees them (I've had
> a go at this but failed :) )
> wondering anyway as my poor laptop is begging for some more memory :)
> Edd
Re: SVN without subversive? [message #19367 is a reply to message #19279] Wed, 03 June 2009 05:06 Go to previous message
Hi Edd,
You cannot do what you suggest directly because the plugins won't be
packaged in a form that Eclipse recognises. However, you should be able
to download from SVN, export the plugins, copy them into your
Eclipse/plugins (or better Eclipse/dropins) and restart Eclipse. If you
install them into dropins, make sure to deinstall any Epsilon plugins
previously installed through the update site.
Steffen
Dimitris Kolovos wrote:
> Hi Edd,
> or adding a minor new feature):
> Cheers,
> Dimitris
>> Hi there again,
>> the plugins, and then spawn another child Eclipse to make use of
>> them? E.g., use another SVN client (e.g., tortoise) to download them
>> into the Eclipse plugins directory, so on initial startup it sees
>> them (I've had a go at this but failed :) )
>> Thanks,
>> Edd
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Re: SVN without subversive? [message #568680 is a reply to message #19044] Tue, 02 June 2009 10:41 Go to previous message
Hi Edd,
Dimitris
> Hi there again,
> Edd
Re: SVN without subversive? [message #568702 is a reply to message #19279] Wed, 03 June 2009 05:06 Go to previous message
Hi Edd,
Steffen
> Hi Edd,
> Cheers,
> Dimitris
>> Hi there again,
>> Thanks,
>> Edd
Previous Topic:EVL and EMF editor integration ?
Next Topic:EVL and EMF editor integration ?
Current Time: Thu May 08 21:06:42 EDT 2025
Powered by FUDForum. Page generated in 0.07381 seconds
