org.eclipse.ui.ide [message #199406] |
Wed, 14 March 2007 14:36 |
Originally posted by: gblin.aegonusa.com
Hi all. I am attempting to install a plug-in that requires the
org.eclipse.ui.ide (3.0.2) plug-in. Unfortunately, I am unable to locate
this plug-in in order to download it. Can someone tell me where I can
obtain this plug-in?
Thanks in advance for your assistance.
Re: org.eclipse.ui.ide [message #199419 is a reply to message #199406] |
Wed, 14 March 2007 14:42 |
Originally posted by: jakub.jurkiewicz.gmail.com
AFAIK it is a part of Eclipse platform, so you should find it in
<path_to_eclipse>/plugins
regards,
Jakub Jurkiewicz
Re: org.eclipse.ui.ide [message #199470 is a reply to message #199406] |
Wed, 14 March 2007 16:22 |
Originally posted by: wharley.bea.com
"GB" <gblin@aegonusa.com> wrote in message
news:67b3bd12d9d0604a7406e9ba18752bc0$1@www.eclipse.org...
org.eclipse.ui.ide is part of Eclipse. But if your plug-in specifically
requires version 3.0.2, that may mean it needs to run on Eclipse 3.0, rather
than a more recent version. Old versions of Eclipse are available from
http://archive.eclipse.org/eclipse/downloads/index.php. However, you will
probably be a lot happier if you can find an up-to-date version of the
plug-in you're trying to install; Eclipse has improved quite a lot in the
years since 3.0.
FUDForum. Page generated in 0.07729 seconds
