Home » Language IDEs » C / C++ IDE (CDT) » CDT-error generating new project, openSuse10.1
CDT-error generating new project, openSuse10.1 [message #199306] Thu, 09 August 2007 11:32 Go to next message
hello,
after long troubles with my old installation (on a 64bit linux) I
installed openSuse linux 10.1 and eclipse totally new.
After that I got eclipse3.1.1 for java.
According to the installation instructions from Max Berger
(max@berger.name) I installed the plug-in for C/C++, CDT 3.1.2, via
"help/software updates/find and install/search for new features/Callisto
Discovery Site".
Everthing seemed ok, but when I now want to generate a new C++ project, I
get the following error message:
Plug-in "org.eclipse.cdt.make.ui" was unable to instantiate class
"org.eclipse.cdt.make.ui.wizards.NewMakeCCProjectWizard".
The button "Details>>" in the message window tells me:
What is missing and how to repair it?
I am a newcomer and welcome any help.
Nikosch
Re: CDT-error generating new project, openSuse10.1 [message #199314 is a reply to message #199306] Thu, 09 August 2007 12:03 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
You have a mismatch of versions:
For
Eclipse 3.1.x, you need CDT 3.0.x
Eclipse 3.2.x, you need CDT 3.1.x
Eclipse 3.3.x, you need CDT 4.0.x
HTH
Derek
nikosch wrote:
> hello,
> Discovery Site".
> I get the following error message:
> java.lang.NullPointerException
> Nikosch
Re: CDT-error generating new project, openSuse10.1 [message #199445 is a reply to message #199306] Mon, 13 August 2007 05:55 Go to previous message
I too have 64bit Suse 10.1 and it makes no problems when using own java/eclipse
* Make sure to use a 64bit Java >= 1.5 from Sun (java --version) and not that gnu java 1.4
* You have to install a own Eclipse - the SuSE rpms are too old - Use Europa
* Make sure to install the 64 binary. The CDT Linux bundle download seems still not to offer
the 64 bit version. You have to download the Europa classic und then install the CDT plugin.
* Sounds complicated but ist not. :)
Fabian
Previous Topic:Indexer slows down eclipse???
Next Topic:Integration of C Compiler to Eclipse
Current Time: Tue Jul 22 02:50:07 EDT 2025
Powered by FUDForum. Page generated in 0.05974 seconds
