Home » Archived » Test and Performance Tools Platform (TPTP) » Try to remote profiling with Hyades
Try to remote profiling with Hyades [message #19002] Fri, 03 June 2005 04:22 Go to next message
Originally posted by: jimmy68.softhome.net
I try to profiling the java application running on the remote machine. On
remote machine, there is QNX for RTOS and J9 for JVM.
When you want to remote profiling using TPTP, you need to run Hyades Data
Collection Engine on remote machine. But Hyades Data Collection Engine is
not available for QNX. Is there anyway profiling the java application on
QNX remote machine using TPTP?
Thanks in advance.
Jimmy
Re: Try to remote profiling with Hyades [message #19025 is a reply to message #19002] Fri, 03 June 2005 09:14 Go to previous message
Hi Jimmy,
you can checkout the sources from CVS repository:
export CVSROOT=:pserver:anonymous@dev.eclipse.org:/home/tools
cvs co org.eclipse.hyades.datacollection
.... and build your own version for your RTOS using an
appropriate build environment.
I don't know if J9 supports all features you need.
The main issue is the JVMPI Interface i think.
Greetings
Holger
Jimmy Kim wrote:
> Hello,
> Thanks in advance.
> Jimmy
Previous Topic:TPTP launcher
Next Topic:Questions about the new AC design
Current Time: Tue Jun 17 05:26:34 EDT 2025
Powered by FUDForum. Page generated in 0.25656 seconds
