Home » Eclipse Projects » Eclipse Platform » Exception
Exception [message #199049] Sat, 21 February 2004 16:00
I am working with Eclipse 2.1.x for the past 1 yr. I am trying to move to
Eclipse 3.0 M7 but I can't get my plugin to work with 3.0 M7. The views are
shown properly but when I click on a wizard button to bring up a wizard, I
get the following exception... my plugin has org.eclipse.ui as one of the
required plugins which has a dependency on org.eclipse.ui.workbench (export
= true). I even added org.eclipse.ui.workbench explicitly in my plugin.xml
as one of the required plugin.
java.lang.NoClassDefFoundError:
org/eclipse/ui/internal/model/WorkbenchAdapter
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java(Compiled Code))
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.define
Class(DefaultClassLoader.java(Inlined Compiled Code))
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClass
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findCl
assImpl(DefaultClassLoader.java(Compiled Code))
ass(DefaultClassLoader.java(Compiled Code))
org.eclipse.osgi.framework.adaptor.BundleClassLoader.findLoc alClass(BundleCl
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseCl
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleL
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java(Compiled Code))
org.eclipse.osgi.framework.adaptor.BundleClassLoader.loadCla ss(BundleClassLo
at java.lang.ClassLoader.loadClass(ClassLoader.java(Compiled Code))
com.ibm.rational.dct.ui.wizards.ProviderWizardPage.<init>(ProviderWizardPage
..java:160)
com.ibm.rational.dct.ui.wizards.LoginWizard.addPages(LoginWi zard.java:82)
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:468)
at org.eclipse.jface.window.Window.create(Window.java:341)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:855)
at org.eclipse.jface.window.Window.open(Window.java:616)
Any help would be appreciated...
Balaji
Previous Topic:ISynchronizer
Next Topic:jface, action, drop_down
Current Time: Sat Jul 26 00:58:06 EDT 2025
Powered by FUDForum. Page generated in 0.05160 seconds
