How to run Birt report in batch with parameter [message #198775] |
Fri, 09 March 2007 19:56 |
Originally posted by: angela.huang.tax.sccgov.org
I need to run the trust_item_detail_by_reason_code.rptdesign
with params (see example below). It did not work with the -params
option. The outputs are all the same as if it did not take the params.
Can someone help? Thanks in advance.
java -cp $BIRTCLASSPATH -DBIRT_HOME="$BIRT_HOME"
org.eclipse.birt.report.engine.api.ReportRunner -o
$OUTPUT_DIR/trust_item_detail_by_reason_code19.pdf -f PDF -params
rsnid_rs=19,rsnid_rs_type=decimal,__isdisplay__rsnid_rs='BAN KRUPTCY'
$BIRT_HOME/reports/trust_item_detail_by_reason_code.rptdesig n
o $OUTPUT_DIR/trust_item_detail_by_reason_code25.pdf -f PDF -params
rsnid_rs=25,rsnid_rs_type=decimal,__isdisplay__rsnid_rs='CAN CELLED
WARRANT' $BIRT_HOME/reports/trust_item_detail_by_reason_code.rptdesig n
FUDForum. Page generated in 0.07238 seconds
