Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo
Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo [message #18955] Wed, 28 May 2008 07:31
Hi Michal,
My guess is that Buckminster got confused by updates to your target
platform or that you've used different runtimes on the same workspace.
This is a known bug. You will get around it by either using a fresh
workspace or by simply removing the
<workspace>/.metadata/.plugins/org.eclipse.buckminster.core folder. That
folder will rebuild itself on demand.
Thomas Hallgren
Mikhail Kadan wrote:
> Hi.
> I've updated Buckminster an hour ago (it is "1.0.0.r09309" now) and I
> get this error when I try to resolve "org.eclipse.search":
> Errors and Warnings
> [0002] : More then one version of component
> org.eclipse.core.resources:osgi.bundle$3.3.1.R33x_v20080205# OSGi is
> known to Buckminster
> org.eclipse.ui:osgi.bundle$3.3.1.M20071128-0800#OSGi is known to
> Buckminster
> org.eclipse.jface.text:osgi.bundle$3.3.2.r332_20071017-0800# OSGi is
> Buckminster
> I looked in my target platform, but saw only one version of each of
> this components. What's the problem?
> Thanks.
> 2008/5/27, Thomas Hallgren <thomas@tada.se <mailto:thomas@tada.se>>:
> No, you should be able to use 3.3.x. But you need to update our
> Buckminster to the latest one. For some reason the mirroring is
> really slow today so it's not yet available.
> - thomas
> Hi Mikhail,
> What platform are you using? Is it an Eclipse 3.3.x or
> 3.4.x? And
> what is the version on your
> org.eclipse.buckminster.core.feature?
> Hi.
> I use:
> Eclipse Platform
> Version: 3.3.2
> Build id: M20080221-1800
> org.eclipse.buckminster.core.feature 1.0.0.r09178
> On that link (post #10)
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=229930 I read it
> has a bug in PDE concerning my issue :-) Do I have to revert
> to Eclipse 3.3.1 or even earlier? I cannot use 3.4 version
> because our corporate policy doesn't allow using unstable
> versions.
> Thanks.
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org <mailto:buckminster-dev@eclipse.org>
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo
Next Topic:Including Orbit jars in Buckminster built update site
Current Time: Tue Jul 15 16:55:03 EDT 2025
Powered by FUDForum. Page generated in 0.05617 seconds
