Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo [message #18930] |
Wed, 28 May 2008 07:28 |
------=_Part_12291_14245575.1211974084885
Content-Type: text/plain; charset=UTF-8
Content-Disposition: inline
Hi.
I've updated Buckminster an hour ago (it is "1.0.0.r09309" now) and I get
this error when I try to resolve "org.eclipse.search":
Errors and Warnings
[0002] : More then one version of component
org.eclipse.core.resources:osgi.bundle$3.3.1.R33x_v20080205# OSGi is known to
Buckminster
org.eclipse.ui:osgi.bundle$3.3.1.M20071128-0800#OSGi is known to Buckminster
org.eclipse.jface.text:osgi.bundle$3.3.2.r332_20071017-0800# OSGi is known to
Buckminster
Buckminster
I looked in my target platform, but saw only one version of each of this
components. What's the problem?
Thanks.
2008/5/27, Thomas Hallgren <thomas@tada.se>:
> No, you should be able to use 3.3.x. But you need to update our Buckminster
> to the latest one. For some reason the mirroring is really slow today so
> it's not yet available.
> - thomas
> Mikhail Kadan wrote:
>> Hi Mikhail,
>> What platform are you using? Is it an Eclipse 3.3.x or 3.4.x? And
>> what is the version on your org.eclipse.buckminster.core.feature?
>> Hi.
>> I use:
>> Eclipse Platform
>> Version: 3.3.2
>> Build id: M20080221-1800
>> org.eclipse.buckminster.core.feature 1.0.0.r09178
>> On that link (post #10)
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=229930 I read it has a bug
>> in PDE concerning my issue :-) Do I have to revert to Eclipse 3.3.1 or even
>> earlier? I cannot use 3.4 version because our corporate policy doesn't allow
>> using unstable versions.
>> Thanks.
>> _______________________________________________
>> buckminster-dev mailing list
>> buckminster-dev@eclipse.org
>> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Content-Type: text/html; charset=UTF-8
Hi.<br><br>I've updated Buckminster an hour ago (it is "1.0.0.r09309" now) and I get this error when I try to resolve "org.eclipse.search":<br><br>Errors and Warnings<br> [0002] : More then one version of component org.eclipse.core.resources:osgi.bundle$3.3.1.R33x_v20080205# OSGi is known to Buckminster<br>
[0002] : More then one version of component org.eclipse.ui:osgi.bundle$3.3.1.M20071128-0800#OSGi is known to Buckminster<br> [0002] : More then one version of component org.eclipse.jface.text:osgi.bundle$3.3.2.r332_20071017-0800# OSGi is known to Buckminster<br>
[0002] : More then one version of component org.eclipse.jface.text:osgi.bundle$3.3.2.r332_20071017-0800# OSGi is known to Buckminster<br> [0002] : More then one version of component org.eclipse.ui:osgi.bundle$3.3.1.M20071128-0800#OSGi is known to Buckminster<br>
<br>I looked in my target platform, but saw only one version of each of this components. What's the problem?<br><br>Thanks.<br><br><br><div><span class="gmail_quote">2008/5/27, Thomas Hallgren <<a href="mailto:thomas@tada.se">thomas@tada.se</a>>:</span><blockquote class="gmail_quote" style="margin-top: 0; margin-right: 0; margin-bottom: 0; margin-left: 0; margin-left: 0.80ex; border-left-color: #cccccc; border-left-width: 1px; border-left-style: solid; padding-left: 1ex">
No, you should be able to use 3.3.x. But you need to update our Buckminster to the latest one. For some reason the mirroring is really slow today so it's not yet available.<br><br> - thomas<br><br> Mikhail Kadan wrote:<br>
<blockquote class="gmail_quote" style="margin-top: 0; margin-right: 0; margin-bottom: 0; margin-left: 0.80ex; border-left-color: #cccccc; border-left-width: 1px; border-left-style: solid; padding-left: 1ex"><div><span class="e" id="q_11a2ad6fb5ed3e4e_1"><br>
<br> Hi Mikhail,<br> What platform are you using? Is it an Eclipse 3.3.x or 3.4.x? And<br> what is the version on your org.eclipse.buckminster.core.feature?<br><br><br> Hi.<br><br> I use:<br><br> Eclipse Platform<br>
Version: 3.3.2<br> Build id: M20080221-1800<br><br> org.eclipse.buckminster.core.feature 1.0.0.r09178<br><br> On that link (post #10) <a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=229930" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">https://bugs.eclipse.org/bugs/show_bug.cgi?id=229930</a> I read it has a bug in PDE concerning my issue :-) Do I have to revert to Eclipse 3.3.1 or even earlier? I cannot use 3.4 version because our corporate policy doesn't allow using unstable versions.<br>
<br> Thanks.<br></span></div><span class="q"> ------------------------------------------------------------ ------------ <br><br> _______________________________________________<br> buckminster-dev mailing list<br><a href="mailto:buckminster-dev@eclipse.org" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">buckminster-dev@eclipse.org</a><br>
<a href="https://dev.eclipse.org/mailman/listinfo/buckminster-dev" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">https://dev.eclipse.org/mailman/listinfo/buckminster-dev</a><br> <br></span></blockquote>
<div><span class="e" id="q_11a2ad6fb5ed3e4e_4"><br> _______________________________________________<br> buckminster-dev mailing list<br><a href="mailto:buckminster-dev@eclipse.org" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">buckminster-dev@eclipse.org</a><br>
<a href="https://dev.eclipse.org/mailman/listinfo/buckminster-dev" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">https://dev.eclipse.org/mailman/listinfo/buckminster-dev</a><br></span></div></blockquote>
</div><br>
------=_Part_12291_14245575.1211974084885--
FUDForum. Page generated in 0.06220 seconds
