Home » Archived » IAM (Eclipse Integration for Apache Maven) » IAM doesnt run surefire-report:report correctly
IAM doesnt run surefire-report:report correctly [message #18922] Mon, 18 May 2009 21:13 Go to next message
IAM doesnt run "surefire-report:report" the same way as it executes from
the command line.
The problem arises when tests fail. The point of the report is to tell you
what tests failed. But IAM seems to stop the build early, because the
tests failed. So you dont get a report. :(
When I run maven from command line, this does not happen.
Re: IAM doesnt run surefire-report:report correctly [message #18944 is a reply to message #18922] Tue, 19 May 2009 06:05 Go to previous message
This looks like caused by a regression on the maven embedder used by IAM
to run the goals.
It would help if you could test from the commandline using the maven
version available at [1].
There are some instructions at [2]
[1]
http://code.google.com/p/q4e/downloads/detail?name=apache-ma ven-2.1-659802-Q4E-bin.zip&can=2&q=
[2] http://code.google.com/p/q4e/wiki/ReportingBugs
> the command line.
Re: IAM doesnt run surefire-report:report correctly [message #569058 is a reply to message #18922] Tue, 19 May 2009 06:05 Go to previous message
to run the goals.
[1]
> the command line.
Previous Topic:IAM doesnt run surefire-report:report correctly
Next Topic:Classpath container suddenly vanished and I cannot get it back
Current Time: Thu Jul 17 20:47:55 EDT 2025
Powered by FUDForum. Page generated in 0.27757 seconds
