Home » Language IDEs » Java Development Tools (JDT) » Classpath and ClassLoader
Classpath and ClassLoader [message #198502] Mon, 14 March 2005 14:59
I'm developing an editor plugin. Inorder to edit a file using my editor,
the user is expected to create a Java Project. Under this project, the
user can created a file with my specific extension. The test configuration
i'm using is as follows:
1. I have a Java Project. It's build path has the following entries:
a. the source directory
b. the default JRE
c. An additional "Class Folder". This folder will not contain any
classes, but instead project related resources such as XML files. I called
this folder Config. This folder could also be linked to any external
folder.
During execution plugin may need to read XML files by file name (specified
by the user) and the plugin assumes that these files reside in the Config
folder, or any other folder in the classpath.
Intuitively, the Project's build path is not the same as a plugin's
runtime classpath, right. So, how can i get the Project Builder's
Classloader (IF such a classloader does exist) from inside my plugin so
that i can locate the required resource, which is in the Config folder in
the project's build path?
i'm trying to do something similar (and as simple as) to the following
inorder to find the XML file:
Get Java builder classloader.
InputStream stream = classloader.getResourceAsStream("/"+configFileName);
Any help is greatly appreciated. I'm totally new to JDT plugin components.
Sapna George
Previous Topic:How do i programmatically add an external folder to Project Classpath?
Next Topic:automatic creation of ant build files
Current Time: Fri Jun 27 22:11:28 EDT 2025
Powered by FUDForum. Page generated in 0.22733 seconds
