view.getContainer not setted : consequence of using phatom nodes ?? [message #198365] |
Tue, 22 July 2008 09:17 |
Originally posted by: zippo29.hotmail.fr
Hi!
I have used phatom nodes in my project as following:
- I have a NodeA that contains NodeB that contains NodeC
- I created a diagram where A contains B via a compartment
- When I double clik on B I open a sub-editor.
- I wanted in my sub-editor a figure B_bis that represents B the root
element of my sub diagram. In B_bis there is a compartment where I drag
and drop Cs.
- I did this by :
1) defining a phantom node B_bis in the gmfmap that is supposed to
welcome C elements
2) I make the B_bis refrence the B element in the main editor via
the "referenced child" property.
3) I did some hand code modification in the sub-editor plug-in to
display the B_bis element:
- I changed the BCanonicalEditPolicy to call
getSemanticChildren() instead of getB_1000SemanticChildren()
- I make getSemanticChidlren add the B_bis to the list of
children before calling getB_1000SemanticChildren() in the B visualID case
- I changed the BVisualIDRegistry to make it return
B_bisvisualID in the the BvisualID case.
Nota: This is how they did in uml2 tools to display a visual element to
store package imports
The problems I have is that when I try to drag Cs they are added to the
semantic model but not the graphical one.
I tried to debug and and discovered that in
getBCsCompartment_VIDSematincChildren() it returns an empty list because
the containerView is not setted.
I commented the test and everything works fine but I think it will cause
me some problems in the future.
Does someone have an explanation ? And/Or a solution get rid of this in
better way than just commenting the code ?
Thanks in advance.
FUDForum. Page generated in 0.04970 seconds
