Beehive Application Wizard Startup [message #198316] |
Mon, 10 October 2005 12:33 |
Originally posted by: rajesh.rajan.ge.com
Following is the version for the series packages required for Beehive
that i have installed.
JDK 5.0
WTP 1.0 M3
EC 3.1.0M5a
Pollinate M3 ( Does not work with the zip file, importing through update
site works)
GEF 3.1.0
When tried to create new Beehive Project, Following Exception appears. Any
quick resoultion.
java.lang.RuntimeException: graph is not fully connected
org.eclipse.draw2d.internal.graph.TightSpanningTreeSolver.so lve(TightSpanningTreeSolver.java:150)
org.eclipse.draw2d.internal.graph.TightSpanningTreeSolver.vi sit(TightSpanningTreeSolver.java:68)
org.eclipse.gef.examples.pde.PluginDependenciesView.createPa rtControl(PluginDependenciesView.java:148)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:310)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:185)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:559)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:26 6)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:51 4)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1064)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1013)
org.eclipse.ui.internal.PartStack.presentationSelectionChang ed(PartStack.java:745)
at org.eclipse.ui.internal.PartStack.access$0(PartStack.java:73 1)
at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.jav a:115)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:126)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:267)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:276)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$2.handleEvent(DefaultTabFolder.java:80)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:866)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:851)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 59)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va:3137)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:19 21)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:288)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2921)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2554)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1601)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1565)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:315)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:230)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:371)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:160)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:330 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
-Rajesh
FUDForum. Page generated in 0.05205 seconds
