Home » Modeling » TMF (Xtext) » [MWE2] Problem loading models
[MWE2] Problem loading models [message #1221385] Tue, 17 December 2013 10:21 Go to next message
I'm trying to use MWE2 to run a transformation workflow which is simple enough: load a .gmfgen model and generate code from an Xtend template.
For the first step, I'm using the provided "Reader" component:
Workflow {
	component = org.eclipse.emf.mwe.utils.Reader {
		uri = "/org.eclipse.papyrus/plugins/uml/diagram/org.eclipse.papyrus.uml.diagram.component/model/ComponentDiagram.gmfgen"
		modelSlot = "inputGmfgen"
When running this simple wf, I get:
Couldn't load resource under /org.eclipse.papyrus/plugins/uml/diagram/org.eclipse.papyrus.uml.diagram.component/model/ComponentDiagram.gmfgen : org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/gmf/2009/GenModel' not found.
Fair enough. I then add a preceding custom-written component to load the GMFGen EPackage. Its implementation only does this:
public class LoadGmfgenComponent extends AbstractWorkflowComponent {
	protected void invokeInternal(WorkflowContext ctx, ProgressMonitor monitor, Issues issues) {
		EPackage.Registry.INSTANCE.put(GMFGenPackage.eNS_URI, GMFGenPackage.eINSTANCE);
The workflow now looks like this:
Workflow {
	//0. Load GMFGen
	component = org.eclipse.papyrus.test.framework.m2t.xtend.LoadGmfgenComponent {}
	//1. Load GMFGen file
And now I get:
Missing serialized package: /models/gmfgen.ecore
at org.eclipse.gmf.codegen.gmfgen.impl.GMFGenPackageImpl.loadPackage(GMFGenPackageImpl.java:7694)
at org.eclipse.gmf.codegen.gmfgen.impl.GMFGenPackageImpl.initGen(GMFGenPackageImpl.java:1238)
at org.eclipse.gmf.codegen.gmfgen.impl.GMFGenPackageImpl.init(GMFGenPackageImpl.java:1254)
...which is a first since calling GMFGenPackage.eINSTANCE from any platfom-running code would not throw this. I haved added the dependency containing this package (org.eclipse.gmf.codegen), and it doesn't change anything.
Thus, I can't load my input model to my MWE2 workflow. Any ideas?
Thanks a lot in advance for the help!
Juan
Re: [MWE2] Problem loading models [message #1221391 is a reply to message #1221385] Tue, 17 December 2013 10:27 Go to previous messageGo to next message
Hi have a look at the standalonesetup component. It is meant for
registering packages
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: [MWE2] Problem loading models [message #1222025 is a reply to message #1221391] Thu, 19 December 2013 09:15 Go to previous message
Thanks, just what I need! Here's the link whoever needs it:
http://download.eclipse.org/modeling/emft/mwe/javadoc/2.5/org/eclipse/emf/mwe/utils/StandaloneSetup.html
and my example:
bean = org.eclipse.emf.mwe.utils.StandaloneSetup {
		platformUri = '..'
		scanClassPath = true
		uriMap = {
			from = 'platform:/plugin/org.omg.utp/model/utp_1-2.profile.uml'
			to = 'platform:/resource/org.omg.utp/model/utp_1-2.profile.uml'
		registerGeneratedEPackage = 'org.eclipse.gmf.codegen.gmfgen.GMFGenPackage'
		registerGeneratedEPackage = 'org.eclipse.emf.codegen.ecore.genmodel.GenModelPackage'
Previous Topic:Possibly solved? EMF Compare - "resolution of uriFragment... failed"
Next Topic:2.5 incompatibility
Current Time: Sun Jul 13 11:48:05 EDT 2025
Powered by FUDForum. Page generated in 0.24348 seconds
