Home » Language IDEs » C / C++ IDE (CDT) » Removing Build Options In CDT
Removing Build Options In CDT [message #198295] Thu, 26 July 2007 10:12 Go to next message
Originally posted by: marcusobrien.cyantechnology.com
I have sucessfully added a toolchain, and some tools
(compiler/linker/assembler) to the CDT using the extension point
(org.eclipse.cdt.managedbuilder.core.buildDefinitions). They are based upon
the existing MinGW tools.
My compiler for example uses the superclass
cdt.managedbuild.tool.gnu.c.compiler.mingw.base. This ID in the
managedbuilder.gnu.ui plugin represents the MinGW C Compiler, this in turn
uses the superclass cdt.managedbuild.tool.gnu.c.compiler. The gnu C Compiler
has many build options, most of which I want to keep.
However I want to remove some options, so I can either...
1. Use the applicabilityCalculator option to implement the
IOptionApplicability, to make it not visible
2. Delete the option altogether from CDT (thus affecting all compilers)
3. Re-implement the entire toolchain (ie dont use
cdt.managedbuild.tool.gnu.c.compiler.mingw.base superclass)
Looking at options 1 and 2, I will have to make sure my customers always get
their CDT version from me (which will include my changes), option 3 I have
had very limited sucess. So my question is can I remove some options for my
tool, without affecting the underlying CDT by implementing an interface
somewhere that doesn't require a change to the CDT ?
Marcus.
Re: Removing Build Options In CDT [message #198326 is a reply to message #198295] Thu, 26 July 2007 10:25 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
Option #1 does what you want. You just supply it as an additional class with
your plugin. No changes to CDT required.
Derek
CDT wrote:
> Marcus.
Re: Removing Build Options In CDT [message #198439 is a reply to message #198326] Fri, 27 July 2007 06:35 Go to previous messageGo to next message
Hello Derek,
Thanks for the response, hopefully you can help me out a bit, how will I
tell the option in the toolchain, the name of the applicabilityCalculator
class I add to my plugin without changing the CDT tool setting (and therefore
changing the cdt plugin.xml) ?
Is there a way of using an ID somehow ?
Marcus.
> class with your plugin. No changes to CDT required.
> CDT wrote:
>> based upon the existing MinGW tools.
>> turn uses the superclass cdt.managedbuild.tool.gnu.c.compiler. The
>> gnu C Compiler has many build options, most of which I want to keep.
>> compilers)
>> always get their CDT version from me (which will include my changes),
>> option 3 I have had very limited sucess. So my question is can I
>> remove some options for my tool, without affecting the underlying CDT
>> by implementing an interface somewhere that doesn't require a change
>> to the CDT ?
>> Marcus.
Re: Removing Build Options In CDT [message #198482 is a reply to message #198439] Fri, 27 July 2007 11:14 Go to previous messageGo to next message
marcus wrote:
> Hello Derek,
> therefore changing the cdt plugin.xml) ?
> Marcus.
What you do is in your toolchain, you redefine the option for that tool
by making it inherit from the original option, i.e. you set the
superClass in the definition for your new option to be the ID of the
original option. Then in your new option you specify the
applicabilityCalculator. The result is that the option is replaced by
your new definition, whose applicabilityCalculator hides it.
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
no completion while using CDT and Qt4.1.0 [message #198530 is a reply to message #198439] Sun, 29 July 2007 16:40 Go to previous messageGo to next message
Originally posted by: olivier57b.yahoo.fr
hello,
the title of this post is clear.
I manage to compile Qt projects but I have no completion, and if I
double-click on "QApplication" in the outline view, I have the error
message: "no include file found".
do you have ideas on how to configure eclipse?(eclipse europa)
thank you,
lolveley.
Re: no completion while using CDT and Qt4.1.0 [message #198547 is a reply to message #198530] Sun, 29 July 2007 16:46 Go to previous messageGo to next message
lolveley a écrit :
> hello,
> thank you,
> lolveley.
I specify that I have a file which begins with "#include
<QApplication>", after it is a basic file ("hello world").
Re: no completion while using CDT and Qt4.1.0 [message #198596 is a reply to message #198530] Mon, 30 July 2007 05:13 Go to previous messageGo to next message
lolveley wrote:
> hello,
> thank you,
> lolveley.
You need to make the Qt headers known to the C++ indexer. Go to
Project->Properties->C++ Include Paths and Symbols, and add all the
directories in QTINSTALLDIR/include as an 'external include path'.
Eike
Re: Removing Build Options In CDT [message #198609 is a reply to message #198482] Mon, 30 July 2007 06:12 Go to previous message
Hello Chris,
Many thanks, this is exactly what I wanted.
Marcus
> marcus wrote:
>> Hello Derek,
>> will I tell the option in the toolchain, the name of the
>> applicabilityCalculator class I add to my plugin without changing the
>> CDT tool setting (and therefore changing the cdt plugin.xml) ?
>> Marcus.
> tool by making it inherit from the original option, i.e. you set the
> Chris Recoskie
> IBM Toronto
Previous Topic:Unable to use C/C++ Postmortem debugger
Next Topic:Performance problems with CDT 4.0
Current Time: Sun Aug 31 17:40:55 EDT 2025
Powered by FUDForum. Page generated in 0.03289 seconds
