3M7,some error.............. [message #198246] |
Fri, 20 February 2004 02:09  |
Originally posted by: dyroro.netscape.net
Hi,all
I use the new UI, when I open the Preferences Dialog and set some
attribute, workbench->Editors:Close editors automatically,and then click
the OK button, but the dialog is not closed. and the .log file:
!ENTRY org.eclipse.ui 4 4 2 20, 2004 16:05:32.281
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2 20, 2004 16:05:32.281
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.ui.internal.dialogs.EditorsPreferencePage.perfor mOk(EditorsPreferencePage.java:139)
org.eclipse.ui.internal.ide.dialogs.IDEEditorsPreferencePage .performOk(IDEEditorsPreferencePage.java:206)
org.eclipse.jface.preference.PreferenceDialog.okPressed(Pref erenceDialog.java:779)
org.eclipse.jface.preference.PreferenceDialog.buttonPressed( PreferenceDialog.java:223)
org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.bu ttonPressed(WorkbenchPreferenceDialog.java:75)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:402)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2029)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:619 )
at org.eclipse.jface.window.Window.open(Window.java:599)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:72)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:423)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1550)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1526)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:257)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Re: 3M7,some error.............. [message #198544 is a reply to message #198246] |
Fri, 20 February 2004 10:58  |
Log the bug report with the reproducebable test case against Platform UI.
Darins
"Scott Ding" <dyroro@netscape.net> wrote in message
news:c14f2j$26d$1@eclipse.org...
> Hi,all
> !STACK 0
> at
rencePage.java:139)
> at
> at
a:779)
> at
..java:223)
> at
> at
> at
:72)
> at
> at
tem.java:490)
> at
tionItem.java:423)
> at
> at
java:257)
> at
> at
> at
..java:25)
FUDForum. Page generated in 0.29413 seconds
