Home » Modeling » Epsilon » [Eugenia] Unable to generate GMF files
[Eugenia] Unable to generate GMF files [message #18867] Wed, 27 May 2009 14:58 Go to next message
Hi all Eclipse fans!
I installed actual Eugenia (0.8.5) from repository into Eclipse Galileo
Modeling Bundle (RC1, Linux 64-bit).
When I try to generate GMF files from Ecore then I received this error:
Internal error:
java.io.FileNotFoundException: /px/model/juni1.ecore [No such file or
directory]
at java.io.FileInputStream.open[Native Method]
at java.io.FileInputStream.<init>[FileInputStream.java:137]
org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.creat eInputStream[FileURIHandlerImpl.java:105]
org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterIm pl.createInputStream[ExtensibleURIConverterImpl.java:301]
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load[Resour ceImpl.java:1254]
at org.eclipse.epsilon.emc.emf.EmfModel.loadModel[EmfModel.java :216]
This error is probably caused because Eclipse try to open Ecore file with
relative filename (and miss workspace prefix - something like
$HOME/workmodel/...).
My dirty workaround is linking project directory (.../px) to filesystem
root (fortunatelly I'm on Linux) and then GMF generation works ok.
Thanks for fixing this small bugs and happy modeling
Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #18891 is a reply to message #18867] Thu, 28 May 2009 05:16 Go to previous messageGo to next message
Hi Ivo(sh),
Thanks for reporting this regression. Could you please open a new bug
while we are looking into this?
Dimitris
> Internal error: java.io.FileNotFoundException: /px/model/juni1.ecore [No
> such file or directory]
> at
> at
> at
> with relative filename (and miss workspace prefix - something like
> Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #18935 is a reply to message #18891] Thu, 28 May 2009 07:40 Go to previous messageGo to next message
Hi Ivo(sh),
I've entered the bug myself so please ignore my previous request
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278190
It's now been fixed and the changes have been committed to the SVN. A
new interim version will follow soon under
http://download.eclipse.org/modeling/gmt/epsilon/interim/
Dimitris
Dimitris Kolovos wrote:
> Hi Ivo(sh),
> Cheers,
> Dimitris
>> Galileo Modeling Bundle (RC1, Linux 64-bit).
>> [No such file or directory]
>> at
>> at
>> at
>> filesystem root (fortunatelly I'm on Linux) and then GMF generation
>> works ok.
>> Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #18957 is a reply to message #18935] Thu, 28 May 2009 08:45 Go to previous messageGo to next message
On an update to this, the interim version 0.8.5.200905281248 that fixes
this is now available in
Dimitris
> Hi Ivo(sh),
> Cheers,
> Dimitris
>> Hi Ivo(sh),
>> Cheers,
>> Dimitris
>>> at
>>> at
>>> at
>>> works ok.
>>> Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #20275 is a reply to message #18957] Mon, 08 June 2009 18:39 Go to previous messageGo to next message
Hi Dimitros,
I forget to thank You for quick fixing ... I'm sure that lightning is your
only slower brother :-).
Last days I investigate Epsilon step-by-step and I'm finding a lot of
great ideas here, great work
Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #20303 is a reply to message #20275] Tue, 09 June 2009 04:43 Go to previous message
Thanks Ivosh. Looking forward to hearing more from you as your
investigation progresses.
Dimitris
Ivosh Musil wrote:
> Hi Dimitros,
>> fixes this is now available in
> your only slower brother :-).
> Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #568539 is a reply to message #18867] Thu, 28 May 2009 05:16 Go to previous message
Hi Ivo(sh),
Dimitris
> at
> at
> at
> Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #568562 is a reply to message #18891] Thu, 28 May 2009 07:40 Go to previous message
Hi Ivo(sh),
Dimitris
> Hi Ivo(sh),
> Cheers,
> Dimitris
>> at
>> at
>> at
>> works ok.
>> Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #568582 is a reply to message #18935] Thu, 28 May 2009 08:45 Go to previous message
Dimitris
> Hi Ivo(sh),
> Cheers,
> Dimitris
>> Hi Ivo(sh),
>> Cheers,
>> Dimitris
>>> at
>>> at
>>> at
>>> works ok.
>>> Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #569169 is a reply to message #18957] Mon, 08 June 2009 18:39 Go to previous message
Hi Dimitros,
Ivo(sh)
Re: [Eugenia] Unable to generate GMF files [message #569265 is a reply to message #20275] Tue, 09 June 2009 04:43 Go to previous message
Dimitris
Ivosh Musil wrote:
> Hi Dimitros,
> Ivo(sh)
Previous Topic:Problem with Operation self.libraries complains
Next Topic:Problem with Operation self.libraries complains
Current Time: Mon Jul 21 20:56:52 EDT 2025
Powered by FUDForum. Page generated in 0.12651 seconds
