Home » Newcomers » Newcomers » How to line-wrap/word-wrap?
How to line-wrap/word-wrap? [message #198108] Tue, 06 March 2007 14:27 Go to next message
Is there a way to have Eclipse line-wrap/word-wrap? [It's very hard to
read a piece of code coherently if you have to scroll horizontally as
well as vertically.]
Cheers
James
Re: How to line-wrap/word-wrap? [message #198173 is a reply to message #198108] Wed, 07 March 2007 02:51 Go to previous messageGo to next message
> Cheers
> James
http://ahtik.com/blog/2006/06/18/first-alpha-of-eclipse-word -wrap-released/
bartek michalik
Re: How to line-wrap/word-wrap? [message #198323 is a reply to message #198173] Wed, 07 March 2007 14:13 Go to previous messageGo to next message
> bartek michalik
Thanks, but no thanks. A non-functional alpha release that hasn't been
updated for 9 months, isn't my idea of a practical solution. Sorry.
Re: How to line-wrap/word-wrap? [message #198353 is a reply to message #198323] Wed, 07 March 2007 15:34 Go to previous messageGo to next message
>> bartek michalik
well i don't know other solution
please take a look at https://bugs.eclipse.org/bugs/show_bug.cgi?id=35779
and wikipage addressed in on of the coments
best regards
bartek michalik
Re: How to line-wrap/word-wrap? [message #198360 is a reply to message #198323] Wed, 07 March 2007 15:42 Go to previous messageGo to next message
>> bartek michalik
The Eclipse editor is not the right tool if word wrap is a requirement.
Re: How to line-wrap/word-wrap? [message #198387 is a reply to message #198323] Wed, 07 March 2007 16:59 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
James,
SWT StyledText component lying under TextEditor can be set an option
SWT.WRAP, which is definitely not alpha, works well, but has still low
functionality. It is a basic word wrap. Try out this example:
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.StyledText;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
public class Snip {
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
StyledText text = new StyledText (shell, SWT.WRAP);
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
>> bartek michalik
Re: How to line-wrap/word-wrap? [message #199296 is a reply to message #198353] Tue, 13 March 2007 15:18 Go to previous messageGo to next message
> best regards
> bartek michalik
Thanks for the help bartek.
Re: How to line-wrap/word-wrap? [message #199304 is a reply to message #198360] Tue, 13 March 2007 15:26 Go to previous messageGo to next message
Thanks for the advice Steve. I have voted on this bug.
Re: How to line-wrap/word-wrap? [message #199312 is a reply to message #198387] Tue, 13 March 2007 15:33 Go to previous messageGo to next message
Jacek Pospychala wrote:
> James,
> import org.eclipse.swt.widgets.Display;
> public class Snip {
> public static void main(String[] args) {
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
Hi Jacek
Sounds interesting, but not sure it's what I want. Does this 'component'
add word-wrapping ability to normal Eclipse editor?
Re: How to line-wrap/word-wrap? [message #199843 is a reply to message #199312] Fri, 16 March 2007 02:59 Go to previous messageGo to next message
James,
if you try this code you can have a look how does basic SWT word-wrap
look like. Text is wrapped like in Windows Notepad - to not exceed the
visible area. You cannot for example set a certain column to be wrapped.
The StyledText is a widget used in standard text editor, so in your own
editor you only have to set SWT.WRAP flag.
>> James,
>> public class Snip {
>> shell.pack();
>> shell.open();
>> display.sleep();
>> display.dispose();
> Hi Jacek
Re: How to line-wrap/word-wrap? [message #200315 is a reply to message #199843] Sun, 18 March 2007 17:54 Go to previous messageGo to next message
Hi Jacek
I really appreciate you trying to help me, but I'm afraid I still don't
under stand. Where ... do I 'set SWT.WRAP flag'?
I have looked through the 'Preferences...' options in Eclipse and can
find no such setting.
James
> James,
Re: How to line-wrap/word-wrap? [message #200569 is a reply to message #200315] Mon, 19 March 2007 23:13 Go to previous message
> Hi Jacek
> Thanks
> James
James,
Jacek's suggestion was a code-level option, to apply if you were writing
your own editor or modifying the Eclipse source. And even with that,
from what little I've read, it will not work seamlessly with the Eclipse
Java editor - there are problems with the interaction with line-based
editor features like decorators, etc.
The Bugzilla report that was posted earlier in this thread goes into the
details of why this is such a can of worms and not as simple as it seems
on the surface.
Hope this helps,
Eric
By the way, are you the same James Robertson of Smalltalk fame?
>> James,
>> wrapped. The StyledText is a widget used in standard text editor, so
>> in your own editor you only have to set SWT.WRAP flag.
Previous Topic:Convert C++ to java
Next Topic:make it shorter
Current Time: Tue Jul 22 04:02:09 EDT 2025
Powered by FUDForum. Page generated in 0.09787 seconds
