Home » Modeling » GMF (Graphical Modeling Framework) » How to cener a label into a figure
How to cener a label into a figure [message #198091] Mon, 21 July 2008 10:09 Go to next message
Originally posted by: PetkoSAP.gmail.com
Hi there,
I have a figure descriptor with a child element Ellipse and the ellipse
has a child element a label. I set up that the Ellipse appears as circle
and I would like to have the label being in the center of the circle. If I
add a flow layout and put the alignment to center I only get the lable
vertically centered but not horizontally. Could anybody help?
Greets, Petko
Re: How to cener a label into a figure [message #198109 is a reply to message #198091] Mon, 21 July 2008 11:25 Go to previous message
I think, you could use a stackLayout and the labelAlignement to
center it (try WrappingLabel if if doesn't work with a label).
Or, you could see in the TOPCASED project (http://www.topcased.org).
we have implemented a CenterLayout which works like the StackLayout but
the objects are centered and keep their optimal size.
Petko Ivanov a écrit :
> Hi there,
> I add a flow layout and put the alignment to center I only get the lable
> Greets, Petko
Previous Topic:Label not centered
Next Topic:Blinking Effect for a ConnectionEditPart
Current Time: Sun Jul 27 06:11:16 EDT 2025
Powered by FUDForum. Page generated in 0.03700 seconds
